Question about Kenmore Washing Machines
Washer motor runs. washer drains. washer still
Washer motor runs. washer drains. washer still running. Will not spin.
  • 26 Answers
The spin-tube assembly needs to be replaced.
This is one of those jobs to call-in the repair professional for.
Posted on Sep 08, 2009
My washing machine will not drain...
Good Morning, Cindeyellis88:
3 weeks is a long time without a washer. Is the washer not draining for all cycles? Will it spin and not drain, or not spin AND not drain? Can you hear the motor running?
If the motor is running, and the machine will spin but not drain, you will need to open the machine and clear the hoses to and from the pump. There are YouTube videos showing how to open the machine safely.
If the pump is clogged, the problem may extend up to the tub. This happens when socks and small items go overboard.
Good Luck.
ChrMacKenzie
May 20, 2011 | Kenmore 22422 Top Load Washer
Why won't my washer won't spin or drain
If the water is not removed first, the spin will not occur. Do you hear the pump run when it starts the spin cycle? If nothing, the pump may be jammed with debris, or the motor itself may have failed. If the motor runs, but no water comes out of the drain, then look for a kinked drain hose (inside the cabinet) or possibly a stray sock lodged in the drain outlet under the outer tub. Sometimes the pump impeller will come loose from the motor shaft causing loss of pump action. Hope that some of this helps!
Apr 06, 2010 | Tecnik TKL9260 Front Load Washer
Kenmore stackable washer/dryer 417.97802792 won't drain
its your brushes on your motor or the motor itself but my guess is the brushes replace and enjoy
Jun 23, 2009 | Kenmore 98702 Stacked Washer/Dryer
GE WCXR1070T5WW washes OK but won't spin and drain
It depends on what type of pump it has.If its an electric pump it could drain without spinning,but if the pump runs off the same motor as the washer then the motor has to be running for it to drain,and it will probably spin.There is no guarantee,but the switch that closes when you shut your washers lid is probably bad.Try bypassing this switch,and see if it spins.Please if it spins replace this switch.It is a safety measure that you should really want to keep intact.
Jun 05, 2009 | Washing Machines
My washer will not spin in any cycles
i would still want to removehte motor and check for a craked motor coupling, if its cracked the tub willl not spin( or agitate) but will drain.
Mar 17, 2009 | Kenmore 24032\24036 Top Load Washer
My washer wont spin
Your symptoms that indicates a broken motor coupler. If your washer will drain and fill but has not agitation action or spinning action that would indicate a broken motor coupler. The motor coupler links the drive motor to the transmission.
Jan 31, 2009 | Frigidaire Affinity ATF7000E Front Load...
Washer does not remove water in final spin
If washer hums when it should spin, and the washer will not drain, you may have 2 issues.
First check that the drain pump, drain hose, and wall drain are free of debris.
The washer may not spin properly if the drain system is not operable.
Once you are sure the washer drain pump, drain lines, wall drain, and drain hose is okay, run a test wash.
If the washer hums but now drains, you fixed one issue.
If the washer still hums, you may have a bad belt, motor coupler, motor itself, etc...
Check parts for wear and replace as necessary.I pulled the drain impeller and found a sock from my little guy stuck in there. Fixed!
check all water outlets to make sure there is nothing blocking the pipes.
you could also go to this link it might help you out..... Washer does not remove water in final spin Google Search
Oct 24, 2017 | Maytag MAH6700AWW Neptune Front-Load...
My Admiral waher model # LNC6762B71 will not spin or drain
with the belt off the pump pulley should turn freeley if it does then with the belt off and in the spin position start the washer with the lid down the motor should run
it it does then you have a transmission problem
if the motor does not run then there is a electrial componet problem
May 17, 2008 | Admiral AW22 Top Load Washer
Drain pump starts and stops prior to final spin cycle
Jayron, is the motor jogging? start to spin, stop, start to spin stop. If so, your motor is jogging between the high and low start windings. The motor during spin should start on the high speed windings and stay there until most of the water is drained. GE came out with a new motor, harness and run cap because of this. If you have a meter, there should be a white and white/red wire going to the motor. If you have a steady 120V and it's doing this jogging, replace the motor with the kit...Let me know if this the issue, Catriver..post back.
Nov 05, 2006 | GE WWSE5200B Top Load Washer
Washing Machines Logo
61 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
