Question about Kenmore Washing Machines
Displaying error 10 , door won't open - Kenmore Washing Machines
  • 15,935 Answers
Washer dryers often have cold water valves with 3 separate solenoids. One for the main wash and rinses (which is clearly ok) and one for the condition rinse (to take the fabric conditioner down) which is probably ok too, and the 3rd one is for the dryer. It's possible this 3rd solenoid has failed.
Washer dryers need on a steady trickle of cold water running into the condenser chamber to convert the steam into water, which then gets pumped down the drain.
e10 means that there is a problem with the water supply.
a condenser dryer needs cold water to operate properly. the e10 code will appear if:
1. the water is turned off
2.the water pressure is too low.
3.the solenoid valve is open circuit
4.there is a problem with the pressure switch (least likely)
Cold valve is at the end of blue inlet pipe remove lid and you will see it.
f E10 is only appearing when trying to dry, the problem almost certainly is the condenser valve solenoid open circuit. The green solenoid on the inlet valve. Should read about 4000 ohms.
My money would be on the solenoid coil being open circuit. The coil can be canabalised from most valves although you may have to modify the connections. For simpler repairs - contact Zanussi and get the entire triple inlet water valve to swap out.
http://www.zanussi-electrolux.co.uk/files/unitedkingdom_english/0-999/zanussi%20error%20codes.swf
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
MY HY-FL7102WM WASHING MACHINE IS DISPLAYING 10 E ERROR
My machine does that when the door doesn't latch properly. Try hitting cancel, open the door, close it again and restart the load.
Nov 20, 2017 | Washing Machines
My whirlpool microwave/oven combo is displaying a "DOOR" error message, and the microwave won't work. I have replaced a 20a bus fuse and all 3 door micro switches... It is still displaying the "DOOR"
When microwaves first got popular I used to be a helper with my next door neighbor who fixed them. I does sound like you should have covered it with those switches. If you close the door very slowly, pulling back on the door see if you can hear all 3 switches clicking. You should be able to hear them easily. If you only hear the first 2 try pushing on the door to hear the 3rd. If it will click with pressure on the corners or in the middle then you door is tweaked, possibly from pulling on the door hard to open it or smacking into something on the edge. If you can hear all 3 switches and it still wont start then its going to be the sensor that receives the signal from the switches. I'm not sure how accessible those are on today's models since they make them as disposables now, back then they cost around $500 so they were serviced.
Apr 03, 2013 | Microwave Ovens
My printer ESP5210 is showing error codes 3501,3606,3507. What can i do to fix this
To resolve this error, close the printer access door. The printer will not operate while the door/cover is open.
If the error continues even after you close the printer access door, power cycle the printer:
  1. Turn off the power (press the On/Off button on the printer).
  2. Unplug the printer power cord from the back of the printer.
  3. Wait approximately 30 seconds.
  4. Plug the printer power cord into the back of the printer.
  5. Turn on the power to the printer.
for more help visit https://cbrtechsolutions.net
Sep 29, 2012 | Kodak Esp 5210 Inkjet All-in-one...
WHY MY PORTABLE DVD WON'T PLAY
It won't play for one of two reasons:
1. There is something inside the DVD player, which keeps it from playing.
2. The DVD player's battery has run out of juice and can no longer play, meaning the player needs to be replaced.
Aug 06, 2012 | Curtis Sylvania SDVD7037 7-Inch Portable...
I have a Maytag range that is displaying F9. The oven door is locked as well as the cook top that allows finding the model number. Please help if you can. I appreciate it so much.
Hi
F9 is a door lock error and to solve this issue you can hold the light switch for 15 seconds, this will reset the control. If it won't work then hold the light switch in and set the unit to clean and after a minute press cancel to cancel the clean cycle. If still it won't work then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 07, 2011 | Maytag Ovens
My Hotpoint WMF740 washing machine is displaying a 'door' error message. The machine started to make a funny noise and then stopped approx. 15 minutes from the end of a 1 hour cycle. The door opens alright...
it very well is the door switch might be stuck. The way to unstick it is to slam the door. Very often it'll jar the switch loose if that doesn't work you'll need to order one. Easy to install there are youtube videos on it. If you need the part...try here...repairclinic.com or appliancepartspro.com.
Hope this info helps a little.
Jan 04, 2018 | Hotpoint RGB745 Gas Kitchen Range
I cannot open the door after the finish of the
Hi There
I have found this for you to read.let me how it goes. Hope this was helpful.
F/dL Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Thank you for writing to fix ya.
Best Regards Richard
Dec 29, 2009 | Washing Machines
Whirlpool Duet HT
its a door lock error a door lock error occurs if the door cannot be locked it will try to lock 6 times before displaying the error
Mar 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
113 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
