Question about Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
Sears kenmore side by side, crushed ice not working
I have sears kenmore side by side, model 25359487992, the crushed ice does not work. the ice comes out in blocks, not crushed.
  • 65 Answers
SOURCE: Ice Maker Issues-only crushed ice works, cubed comes out crushed
There is a solinoid in the freezer section by the motor that turns the ice auger. Test it by selecting cubes and with the ice bucket out, open the door, hold the door switch so the lights turn out and push the dispenser button. It should make a loud snap and travel upward. If not then I would say you have a bad solinoid. If it does, then I would look at the bucket. the metal rod that runs along the side of the bucket opens a flap in the bucket that is supposed to let the full cubes drop. look for anything that might cause it to be hanging up.
Posted on Jan 27, 2009
fridgetech
  • 473 Answers
SOURCE: Kenmore Side by Side Refrigerator Ice Maker Not Working
A couple things to check here. First see if there is ice in the tray. If so chances are the ice maker will need to be replaced however these are very reliable ice makers. If no ice in the tray pull up on the ejector blade (don't worry you won't break it) turn clockwise to start the ice maker thru a cycle. The ejector blade is the long white bar with fingers on it that run the length of the tray. Once it completes a cycle it should fill with water. If no water then either the fill tube is frozen over and will need to be defrosted or the water valve is bad.
Posted on Oct 05, 2007
  • 42 Answers
SOURCE: kenmore side by side ice maker
There are as you can imagine many possible causes for you no ice condition. I will give you the most common problem for the year model you have. I hope this helps you.
You will need to remove the ice maker from the freezer compartment to check it. Once it is repaired if the following information does help, and you reinstall the ice maker, it should go through a cycle automatically within an hour of your reinstalling it in the freezer compartment.
Once you have the ice maker out of the freezer compartment you will need to remove the white cover on the end of the ice maker and look at the center of the large white gear. If the part inside the hole in the center of the gear is broken or looks twisted, you will need to replaced the module. The module is the part that has the large white gear and is held in the ice maker by 3 phillips head screws. It only comes as an assembly. You can't get just the little broken piece.
supertechks
Please don't forget to rate me
Posted on Jan 25, 2008
SOURCE: icemaker only dispenses crushed ice, not cubes
yea! I have been without cubes for 2 years. I slid out the tray, found the lever in the back where the rod went in, pulled it down, reinserted the ice tray, and IT WORKED! At first I thought I broke the lever, because I had to hold it down with a knife while I was inserting the tray, but it just must have been stuck. I am soooo happy!
Posted on Aug 10, 2008
ghappliances
  • 126 Answers
SOURCE: kitchenaid side by side model ksrs25ikss01
CHECK YOU SECOND VALVE IS WORKING IF THATS OK YOU MIGHT NEED YOUR ICE MAKER CHECKED AND SERVICED.GOODLUCK.MOHAMED
Posted on Sep 12, 2008
I have a Kenmore side by side, not sure the model, but it's probably 10 years old or so. It has an ice maker with water, cube and crushed ice dispenser. The ice maker works fine, but it will not dispense...
Most of the time the bin has been removed and not put back in properly. When this happens ice blocks the drive motor. Remove the bin and turn the auger by hand make sure it will turn and is not jammed. Now with the bin out push the light button in that turns the light out and have someone push the button for ice while the door is still open the motor should turn in the back make sure thereis no ice blocking it. If it turns nothing is wrong with the motor. The clicking sound is usually the motor jammed by ice or the auger not engaged on the motor. hope this helps good luck
Aug 15, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Crushed ice option don't work properly . samsung RS2530B
if it new call sears for service...with crushed ice the augar moter turn the other direction... it must not be turn the other way could be a switch in the control...
let me know for it help if NOT please let me know and I will be glad to do more in depth.
Sep 26, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Automatic ice dispenser on Kenmore side by side freezes up
Probably the trap door where ice dispenses out is not sealing tightly causing frost buildup
Sep 29, 2017 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Dispenses crushed ice and will not dispense ice cubes
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Aug 17, 2009 | Frigidaire FRS23H7CS Side by Side...
Ice Dispenser clogged with frozen ice
I have the same problem. Found this posting:
http://www.applianceblog.com/mainforums/sears-kenmore/10491-kenmore-ice-maker-dispenser-door-shute-clogging-missing-heating-element.html
Maybe our heater is not working?
Jul 05, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
My kenmore side by side w/ ice maker is working
Air leaking in around the door gasket or the door flam the ice comes out of.
Jul 02, 2009 | Kenmore 57029 Side by Side Refrigerator
Ice maker works but will only give crushed ice on the cube settin
little arm on side of ice bucket controls that..check it and the solenoid at back for freezer that trips it.
Jun 08, 2009 | Whirlpool ED2FHEXN Side by Side...
Ice dispenser is stuck in crush mode
Carriage that moves ice bucket rod up is frozen.It's right by the auger drive mote on the left- square hole. Remove bucket and try to free it with your finger. If no luck take hair dryer until you can move it up and down.
Nov 28, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore side-by-side only dispensing crushed ice
Hi blkshop,
Most likely the problem you are having is with the crushed ice solonoid. It is located in the back of the freezer behing the icebucket. The little metal arm from the icebucket goes into a hole, the hole is part of the solonoid. To make sure the problem is with the solonoid, first take the icebucket out and look at the little metal arm on the bottom. When you lift it, it will open for crushed or cubed ice in the bucket dispencer hole. If it works properly then the solonoid is bad.
This repair is sometimes a really hard repair, because it is so hard to get all the stuff out of the way to replace the solonoid. You have to remove the icebucket holder and most likely the icemaker, and on some models you will have to remove the fan and several other pieces to get to it. If you feel like trying the repair let me know, I can ship you the part, I keep almost everyone of those on hand, all I would need is your model and address. My number is (865)945-3808. or my email is mca0824@aol.com . Thanks and I hope this will FixYa. Michael Anderson
Sep 13, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator Logo
310 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
