I live in the Laural Mountians of PA (near 7 Springs). I want to know the antenna directrion for Pittsburgh Stations, NBC, CBS, ABC. In general Pittsburgh is 330 degrees, but I am only recieving channel 2 and 11. Zip code is 15557. Help
  • 2 more comments
  • etbeals Sep 07, 2009
    Yes, That may be true but.
    Thank you, I know where Pittsburgh is in general from my location. What I am looking for is a web site that will give me the exact degrees for my antenna direction to there tower.
  • etbeals Sep 10, 2009
    I know the general direction of the Pittsburgh stations but I am only getting channel 2. I neet the specific settings.
    Thank you
    Why would I be able to get channel 2 and 11, but not 4 (ABC)?
    I will try you suggestion and let you know
    Thank you
  • 10,515 Answers
This problem is very commonly caused by the TV being accidently reset to recognize only VHF channels up to the first 15 and then look for UHF channels. This may be labeled in the menu as "Air" or "Antenae".
You would need to go to menu for channel setup and change this setting to "cable".
If problem still persists, let me know . Also mention the Make and Model of the TV.
Thanks.
Posted on Sep 10, 2009
  • taran_2005
    taran_2005 Sep 10, 2009
    Thanks for your response!!
    Let me know the update!!
    Thanks.
    President:
  • 1,996 Answers
The only program I know of to map broadcast locations is antenna web, found here. Unfortunately, the only stations it is picking up for your zip code are in Johnstown. Once you exceed the distance of about 60 miles, they won't rate your reception as acceptable, so even if you can get reception, it's not guaranteed.
I think your best bet for Pgh. is to assume the broadcast beacons are on top of Mt. Washington, and use the compass direction to get a general focus.
If you have help, and that's really the only way to dial it in, you can orient the antenna a few degrees at a time and have someone check the signal strength for various stations, then reorient a few degrees. Eventually you'll find the best orientation for picking up the Pgh. stations you can receive. Just make a note of it. Local geographical features can affect the reception, as you probably already know.
You might ask the guy at this site to make an antenna recommendation.
Make sure the antenna is as high as you can mount it, and the cable is running directly to the box or set, and grounded if possible.
You may find this article of some help, as well.
Posted on Sep 08, 2009
  • 1 more comment
  • efs_perpends
    efs_perpends Sep 08, 2009
    I can't tell you the exact compass direction, but if you go to this site you can draw a direct line of sight between your location and Pittsburgh. North should be directly up, or vertical at 0 degrees.
    If you take a screen shot of the map (press Print screen and paste into Paint) and print it, you could use a protractor to measure the angle of degrees away from due north.
  • efs_perpends
    The other problem, I realized when researching your question, is that the stations don't want to publicly post the exact locations of the broadcast towers. At least not in any easily accessible location I could find. I'm sure everyone in Pittsburgh knows where they are, but that doesn't help you much....
    From your location, I don't think a degree or so one way or another will have as much effect as the type and size of the antennae you use to pick up the signals. A 6-8' long traditional aerial should work, I would think, depending on the amount of interference you get from the mountains there.
    I have an almost direct line of site to a broadcast tower about 60 miles from a single story rooftop, but the tower is on a peak about 9000' high, so interference isn't much of an issue.
    Good luck, anyway...
  • efs_perpends
    ps I haven't skied at seven springs or hidden valley since about 30 years ago, but it was nice to think back. Thanks for the reminder...
    President:
  • 1,865 Answers
Pittsburg is west north west of you
Posted on Sep 07, 2009
I can't get local ABC, CBS, PBS or NBC with an antenna, but I get like 10 Ion channels why? I have tried several antennas with no luck?
The signal recently changed to digital. You need a digital tuner in order to receive the new signal.
Aug 22, 2015 | Televison & Video
Does not let me get my stations
you may be on the incorrect Input channel on your TV. look for a button for Input or TV/video
Apr 17, 2014 | Westinghouse Televison & Video
I am not a cable television subscriber. Nonetheless, why can't I get my local public television station when this television set tunes in all other local television stations (local ABC, CBS, NBC, Fox...
Some flat screen tv's have two inputs, one for digital and one for analog reception. If your local public television station is analog, then you'll need a signal input on the analog input.
You might try temporarily moving the input from the digital to the analog then doing a new channel scan to see if this picks up the PBS station. You'll have to rescan again, when you move your antenna lead in back to digital.
May 16, 2011 | Televison & Video
Do I need a digtal converter box to pick up local stations via antenna?
Some local broadcasting will still be in analog but this is just jor simple programming such as college stations. To get local programming such as NBC,ABC,CBS etc. you will need to get a converter since the government has mandated all broadcast be in digital to free up air space.
Note that it may be a case by case basis for some smaller areas.
Dec 29, 2010 | GE 31GT720 31" TV
I have a CRAIG 13 INCH HIGH DEFINITION LCD TV MODEL #CLC503 I PURCAHSED AT CVS / PHARMACY I GET CBS AND ABC STATIONS GREAT BUT I CANT GET NBC??????? PLEASE ADVISE OF THIS ISSUE
NBC antena broadcasting signal is weak and it sit in pretty low ranges on the mountains tops call mountain Wilson.The broadcasting antena is weak and ur receiving antena is weak too.Tries websites like Amazon.com Ebay.com to buy a Digital antena and used it,will boot up ur tv antena receiving signal stronger and longer ranges.Than.U will able to get the NBC tv channel.
Dec 03, 2010 | Televison & Video
I have a 13' Orion tv, model #TV1326BW with rabbit ear antenna. I have connected everything correctly to the converter box for digital signals. I can pick up all stations except the local CBS affliciate....
I have the same TV & cannot get into the TV menu to program the cable... it was bought secondhand without the original remote. There are no buttons anywhere on the TV itself to bring up the menu & the universal remote's menu option doesn't do it, either... how do I set the channels?
Aug 04, 2009 | Televison & Video
Unable to get consistent reception on ABC (channel 7 NY)
The antenna may be the problem in your case but I was getting New York 7 digital with a strong signal before the transition on June 12th and now I do not get any signal. I use a rather large VHF /UHF roof antenna mounted in my attic. The compass heading for NBC NY 4.1 is 169 deg and 18 mile from my location according to antennaweb.org. I get this channel with a strong signal. Comparably ABC NY 7.1 is 170 deg and 18.7 miles from my location and I do not get a signal. Perhaps ABC NY is having some problem with the transition. It does not make sense assuming the information of antennaweb.org is correct. BTW if and outdoor or attic mounted antenna is not an option I would recommend the following antenna. I used this for my friends? setup when she was having problems with rabbit ears. It also got some pretty high user reviews and is not expensive. It is for both indoor and outdoor applications. Good Luck! http://www.monoprice.com/products/product.asp?c_id=109&cp_id=10901&cs_id=1090102&p_id=4730&seq=1&format=2
Apr 10, 2009 | RCA 20F514TD 20" TV
Cannot get local channels back after dropping cable.
Are you positive that your city has not done the Digital Conversion? Some Cities are doing it early before the February deadline. Also make sure you are tuning in to the correct channels. Meaning that if on your Cable Provider ABC was on Channel 3 that does not mean that ABC with still be on Channel 3 after you have your Cable turned off. Most of the Time the Local Stations Tag will let you know what channel its on. It will be something like "KWAS ABC 27" So on your TV you would Tune it to channel 27 to get ABC and the same fore NBC , FOX, CBS , etc...
I hope this helps Take Care =)
Dec 07, 2008 | Televison & Video
No sound on two stations
the best thing to do fine tune manualy
Sep 05, 2007 | Sansui DTV2760 27" TV
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Electro Med Services...
