Casio EXILIM ZOOM EX-Z600 Digital Camera Logo
Posted on Dec 09, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vertical Smears (bands)
Mine is an EX-Z500 and I have the same problem of vertical smears showing only on the PC monitor. What is shown on the LCD is a very bright image than what was taken. I have reset to factory defaults but nothing has happened. I am still using the same original ver. 1.0 firmware.
I think I have had my camera for over a year now. My last camera was an Olympus but before that was a Casio. I was happier with my 1st Casio so I decided to buy another one after trying the Olympus.
Appreciate all the help. Thank you.
Anonymous
Level 2:
Scholar:
  • Expert 151 Answers
  • Posted on Dec 09, 2007
Anonymous
Expert
Level 2:
Scholar:
Answers
151
Questions
0
Helped
67321
Points
384
Your camera sensor is busted, or at least the chip that detects white balance. It is a common result of mishandling or pointing the lens at a very bright light like the sun. If you have the product warranty then have it replaced. If not bring it to a camera technician and have the faulty electronics repaired...
White bands and very white exposure is the common result of a faulty white balance or auto exposure function of your camera that went bust.
1helpful
Monitor displays wide vertical stripes/bands
That is the symptom of failed T-CON board (part of the LCD panel assembly, new panel will be needed), you can try reseating the ribbon connector on the LCD panel first.
This what T-CON board looks like:
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
1helpful
Vertical BlueGreen band
check for vertical ic and replace
Today there appeared smears on the display
My grandson suggested I unplug the computer from the wall and leave it out for a while. i did, and it worked!
Dark Grey Vertical Bar
1. try connecting laptop to an external monitor and check if this vertical dark gray bar appears. if yes it means video is the problem. you need to boot in safe mode then uninstall the video driver. boot to notmal mode then download and install the latest video driver. if still same problem then replace video card. if video is built in with motherboard you need to replace motherboard.
2. when the vertical dark gray bar did not appear in the external monitor then it means issue is with the LCD panel. Do this turn off laptop. press and hold D key then press Power button at the same time or Press and hold on the Fn key then Power button check if the test will run. Color displays full screen when you keep pressing on N key when the colors appears check the vertical dark gray bar if still exist in the test, this means LCD panel and LCD cable needs to be replaced.
4helpful
2answers
Horizontal lines that look like streaks or smears going from left to right
Horizontal lines that look like streaks or smears, you need consider:
1) video card memory error cause it if the display memory on the video card
2) check RAM (clean pins and slot pin)
3) monitor power on without cable to see the menu display, it is ok if no streak, need to clean monitor cable plug.
Shimmer and bands
i experienced a tainted vertical black lines on the boths sides of my lcd screen. There was no scratch or whatsoever that could be the reason why thsi balck colored vertical lines to spread. Hope you can help me solve this problem. Thank you..
Red vertical smears on LCD display and on playback
Your camcorder is on a list with potentially defect CCD light sensors. Sony is replacing them free of charge. Go here for the link and free mailing label: http://www.imaging-resource.com/badccds.html
Why are there vertical lines or bars on the monitor screen when I record a movie?
Recording a movie of a subject that is brightly lit by the sun or some other very bright light source can cause vertical lines or bars to appear in the image during playback. This is due to a CCD phenomenon called "smearing." Note that lines or bars appear in movie images only, but not in snapshots. Smearing does not indicate malfunction of the camera.
Top Casio Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Casio Camera Expert? Answer questions, earn points and help others
