Question about Jabra BT125 Headset
How do i pair my jabra w/my phone. cant find
How do i get my jabra bluetooth into pairing mode? cant find instruction booklet
Hold down the button till the light turns solid blue, then let the phone already in bluetooth mode find the jabra, it will ask for a password, enter 0000
Posted on Sep 09, 2009
Jabra Cruiser2 Type HFS002. Need help with connecting Jabra to cell phone via bluetooth.
If you have the instruction manual on the jabra, it should tell you how to put the device in pairing mode. Once pairing is turned on you find the device name through the bluetooth settings on your phone. Click pair and they should connect.
Aug 16, 2016 | Cell Phones
Cant pair my iPhone with jabra sp5050
forget the headset
turn bluetooth off
turn the headset device off
reboot phone.
try again
Mar 04, 2014 | Jabra A320s Bluetooth Wireless Adapter
How do I sink my Jabra BT4051 with my Nokia 2720a . I do not have a manual any more.
Usually the following setup is required to Pair bluetooth headset with mobile phone. Your mobile phone should support bluetooth interface. 1. Put the headset in pairing mode ? Make sure the headset is off. ? Press the on/off/pairing button marked until the LED indicator light is solid blue. 2. Set your Bluetooth phone to ?discover? the Jabra device Follow your phone?s instruction guide. This usually involves going to a ?setup,? ?connect? or ?Bluetooth? menu on your phone and selecting the option to ?discover? or ?add? a Bluetooth device.* 3. Your phone will find the Jabra device' Your phone then asks if you want to pair with it. Accept by pressing ?Yes? or ?OK? on the phone and confirm with the passkey or PIN = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
May 12, 2010 | Jabra BT4051 Bluetooth Headset
How pair bluetooth Jabra vbt2050 with a blackberry storm 2
In order to pair a BlackBerry device with a Bluetooth device, the Bluetooth device must be in pairing mode. Most Bluetooth devices are not set to pairing mode by default. Therefore, refer to your Bluetooth device manual for instructions on how to set the device to pairing mode.
Mar 04, 2010 | RIM BlackBerry Storm2 9550 Smartphone
I can't get Jabra BT 2050 bluetooth into pairing mode. I follow the instructions but never get the solid light. What can I do?
Booklet instructions for how to pair it with a new device are wrong. It tells you holding the power button will put it into pairing mode but it does not.
Pairing mode is done by turning off the ear piece, then holding both power and answer/hangup at the same time. The LED should flash fast 3 or 4 times and then stay on solid. You might need to hold just power till the very first flash THEN begin holding answer/hangup as well as power till the LED goes constant. I’ve also had luck when frustrated by just holding all 4 buttons at once.
Oct 10, 2009 | Jabra BT2050 Bluetooth Headset
I cant pair my jabra bt125 with my nokia n97
This is one of the mistake commonly done by many people. First you need to pair. Let me walk you through. First, the headset has to be switched to pairing mode which is done by holding the on button for a while even after the headset is switched on. Then the bluetooth headset light will remain on. You switch on the phone bluetooth, search new device. Then select it and press the option for pairing. Read the instructions which come on the phone display and select accordingly. It will ask for passcode which is usually four zeros. Then it will get paired ask you whether to connect. You select connect and you are done.
Sep 02, 2009 | Jabra BT125 Headset
Need to re-pair bluetooth to phone
Go to ur phones bluetooth settings - activate pair new device - at the same time press and hold the on button on your blue tooth head set for about 10-15 seconds - this will enter the device into pair mode - on your phone - click on pair with new device etc etc, the default access code is either 0000 or 1234
Jun 29, 2009 | Jabra Bluetooth Headset with Adjustable...
Cant par my jabra bt125
First make sure your bluetooth and your phone are fully charged. Next press the on - off button in the middle of your bluetooth until it is a solid blue color. If it is flashing it is not in the pair mode. Just hold it down until it is a solid blue light.
Then set your phone to the pairing mode following your phones set up bluetooth instructions. Select the discover, search, or add function on your phone. Your phone should find the bluetooth device and ask "do you want to pair with it?" Accept by pressing yes or ok on the phone and entering the passkey or pin # of 0000 or 4 zeros.
Your phone should confirm when pairing is complete.
I discovered that I was not holding the on-off button down long enough for my bluetooth to reach the pairing mode and give me a solid blue light.
I hope this helps as I know how frustrating this can be.
Jan 15, 2009 | Jabra BT125 Headset
Problem pairing
Before you use your Jabra BT130, you need to pair it with your mobile phone.
1. Put the headset in pairing2 mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT130 Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.
3. Your phone will find the Jabra BT130 Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
Jan 27, 2008 | Jabra BT130 Wireless Headset
Chocolate phone will not discover the Jabra BT150
you use your Jabra BT150, you need to pair it with your mobile phone. 1. Put the headset in pairing2 mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on. 2. Set your Bluetooth phone to ediscoverf the Jabra BT150 Follow your phonefs instruction guide. This usually involves going to a esetup,f econnectf or eBluetoothf menu on your phone and selecting the option to ediscoverf or eaddf a Bluetooth device.* (See example from a typical mobile phone in fig. 4) 3. Your phone will find the Jabra BT150 Your phone then asks if you want to pair with it. Accept by pressing eYesf or eOKf on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing
Oct 07, 2007 | Jabra BT150 Wireless Headset
Jabra BT125 Headset Logo
785 people viewed this question
Top Jabra Radio Communications Experts
Jerry Greenberg
Jerry Greenberg
Mohammad Nawaid...
Level 1 Expert
Michial Gueffroy
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
