Question about Dryers
I have a Kenmore gas Dryer model #11072812101, it is not heating/drying most of the time, sometimes I can hear the burner ignite but not all the time. Can I fix this myself or should I buy a new dryer?
  • 5,911 Answers
The choice is yours. Spend several hundred dollars for a new appliance. Or, spend about $22 for a new igniter. The burner assembly on your dryer has an electric igniter that ignites the gas. The intermittent operation of your burner tells me that the igniter probably has become weak with age and is no longer functioning properly. The part number is 279311 and can be purchased at pcappliancerepair.com.
The way the ignition system on your dryer is supposed to work is like this:
1. Press the start button.
2. The igniter on the burner assembly begins to glow.
3. Once the igniter reaches the required current potential, the gas safety valve opens.
4. Gas is introduced into the manifold and you have ignition.
NOTE: It can take roughly 30 – 90 seconds from the time you press start to the time it takes for the gas to ignite.
This is a built in safety feature that prevents free flowing gas from entering the dryer cabinet without ignition. Such a situation could lead to an explosion.
There are two basic types of igniters:
Carborundum (Cylindrical in shape) – needs to produce 2.5 to 3.0 ampsI have a Kenmore gas Dryer model #11072812101, it - 2.gif for the gas safety valve to work.
Norton (Rectangular in shape) – needs to produce 3.2 to 3.7 amps for the gas safety valve to work.
I believe your dryer takes the Norton type igniter. In addition, just because an igniter glows, does not mean it is good. Igniters will wear out with age and the current potential will decrease to the point where it no longer will open the gas safety valve.
Now...another cause of poor heating quality and longer dry times is poorly istalled, kinked, or clogged dryer exhaust ventilation ducting. If you have not checked the dryer ducting from where it exits the dryer to the point where it leaves your home, now may be a good time to do so. A dryer needs proper ventilation in order to dry efficiently.
You can easily replace the igniter by performing the following steps:
1. UNPLUG the dryer and remove the lint screen.
2. With the lint screen removed, locate and remove the two screws and lift the top panel.
3. Unplug the door switch connector plug and any ground wire that may be installed on the casing.
4. Locate the two screws that hold the front panel in place. There should be one screw on each side in the cabinet interior.
5. With the door shut, lean against the front panel and remove the two screws that hold it in place. Once the screws are removed, grasp the front panel at the top center and lift straight up to remove.
You should now have complete access to the dryer interior. You may want to remove the dryer drum if you canot fully access the igniter. If so, release the belt tension on the drum by taking the small idler pulley on the cabinet floor and pulling the wheel to the right. While the tension is released, remove the belt from the drive motor pulley. Leave the belt wrapped around the drum and lift the entire drum with it to remove from the cabinet. You now have full access to the burner assembly to replace the igniter. All you should have to do is disconnect the connector plug and a couple of mounting screws.
Once you have the igniter installed, you need to re-install the drum and belt by following these steps:
1. With the belt still looped around the dryer drum (grooved side facing the drum - try to line the belt up with the wear marks already on the drum from the belt) lift the drum with the belt and insert the back rim of the drum onto the support rollers in the rear of the dryer first.
2. With the drum resting on the rollers, slowly turn the drum clockwise until the rollers seat into the rear drum groove. You should feel the drum drop into place once it seats correctly.
3. Hold the drum in place (you can do this by resting it against your shoulder so you have both hands free) and make sure the idler pulley is correctly installed in the cabinet floor. With the tensioner in your left hand, insert the clip end of the idler pulley into the grooves on the dryer bottom casing with the idler wheel pointing to your left. (The grooves are directly in front of the drive motor.)
4. While holding the tensioner in place, insert the belt UNDER the wheel with your right hand and pull it up and over the drive motor pulley.
If this does not explain it well enough, you can also verify by going to repairclinic.com. Click on the Repair Help link and look for the "Dryer Belt Diagrams" link under the Special Features section on the next page. Look for Whirlpool and refer to diagram H.
Once you have the belt installed, re-install the dryer front panel by holding it as you did previously. Line up the holes on the inside bottom edge of the front panel with the small mounting cleats on the front edge of the side panels. This can be done by yourself, but an assist may make it easier. Once you have the front panel in place, lean against it to hold it in place and install the mounting screws. NOTE: Don't forget to reconnect the grounding wire and door switch connector plug. Without the door switch connected, the dryer will not run. Lower the top panel back in place and reinstall the two screws.
NOTE: Placing a piece of duct tape over the dryer vent chute will help safeguard against dropping anything down in the blower fan assembly. If you drop any screws down the chute, you will need to remove the dryer back panel to retrieve them.
I know this is rather lengthy, so take your time and read thoroughly. This is not a difficult repair at all. If you still have questions, please let me know. I hope you find this helpful.
Posted on Sep 08, 2009
  • Jeff Rockwell
    Jeff Rockwell Sep 08, 2009
    NOTE: For clarification, your Kenmore dryer is manufactured by Whirlpool.
We have a sears dry model no. 1107481220 and the dryer is not drying the clothes.
Ok, first does the heat come on at all, if not,, make sure the gas if coming on, if it is, you need to check the thermostats, If its not, you need to replace the coils located on the gas valve itself it looks like this http://www.searspartsdirect.com/partsdirect/part-number/Kenmore-Parts/Dryer-Parts/694540/0026/110/Model-11074812200/0582/0151200?keySuffixId=NA&productTypeId=x&searchModelNumber=11074812200&subCompDesc=Burner%20assembly&brandDesc=KENMORE&modelDesc=GAS-DRYER&blt=11 that is the main one, and you have a second one too that should be replaced at the same time, it has 3 terminals, for a diagram of the burner assembly click on this http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11074812200/0582/0151200?searchedModel=1107481220&blt=
Jul 09, 2011 | Kenmore 74892 Gas Dryer
My model 400 series Kenmore gas dryer has a heating issue. At first start I can hear the gas heater ignite and heat the dryer. After the dryer has ran for a few minutes the burner shuts off and fails to...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Jul 05, 2011 | Kenmore Dryers
I paid to have jahn27 solve my problem with kenmore model 70172 dryer (burner cycles such that clothes don't dry. he recommended replace of both burner coils which i did but burner still cycles). how do i...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 11, 2010 | Dryers
My dryer runs but does not heat up or dry clothes. What could be the problem?
I have a Kenmore dryer and it runs but won't heat up and dry the clothes. I don't hear the ignition even turn over. Please help. I can't afford to buy a new dryer at this time.
Feb 16, 2010 | Kenmore 62602 Electric Dryer
Kenmore dryer Model #6507923 Gas sometimes won't
You may have a bad thermocouple. The thermocouple senses the heat from the flame and "tells" the control unit that the flame has lit. If it is sending no signal, the control will think it didn't light and shut off the gas to prevent an explosion. Good luck.
Jan 03, 2010 | Dryers
Kenmore ddryer 11072812101
Your dryer does not have a pilot. The dryer has an igniter on the burner assembly. When you push the start button, the igniter begins to glow. Once it reaches a certain current potential, the gas valve is opened, gas flows and you have ignition. This is a a built in safety feature of the burner assembly that prevents free flow of gas without ignition. Without it, you could have a build up of gas inside the dryer cabinet followed by the loud "phoooom!' of an explosion when it finally DOES ignite. More commonly the igniter either fails to where it does not glow, or becomes weak and will not produce the required current to open the gas valve. The following link explains a little theory about glow bar type igniters and what their current potential should be:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
I know the link is for a gas range, but the igniters in some of these appliances are identical and the theory is the same.
Another cause of an ignition failure are bad gas valve coils. There are two of them on your burner assembly. It is recommended that if one fails, you replace BOTH of them at the same time. If you go to searspartsdirect.com and type in the model number you provided, there's an excellent exploded view diagram of your burner assembly and parts. The igniter is listed as item number 4 (part #279311) and the safety valve coils are items number 13 (part #694540) and item 14 (694539).
If you can view inside your dryer under the drum, you should see an orange glow as the igniter comes on. If you do not see the glow, or if the igniter glows and there's no ignition after 90 seconds, I would recommend replacing the igniter. If the dryer ignites, then shuts off after a short period of time and will not reignite, you may have a bad coil (you may hear a rattling sound too).
I hope you find this information helpful. Let me know if you require additional assistance.
Sep 26, 2008 | Dryers
Cycles but no heat
The igniter needs to be near the burner jet in order to get a flame started when gas is provided,, the thermo fuse should be situated on the heat duct. I do not have access to Kenmore service manuals to provide any specific darwing details.. my comments are based on other brands.. I hope this helps..
Aug 30, 2008 | Kenmore Dryers
Kenmore Dryer
If this is a gas dryer, the rattling noise you hear is usually an indication of the gas valve coils failing on the burner assembly. Your dryer will normally have two of them. One is the main coil, and the other is a pilot position coil. It is recommended that you replace both of them at the same time (usually sold as a set). Searspartsdirect.com carries your parts. Just type in your model number and look under the "Burner Assembly" heading. For comparative shopping, repairclinic.com may also carry your parts. Sometimes at a cheaper price. If this is not a gas dryer, please post back with your model number, so I can assist you better. I hope this helps answer you questions.
Aug 17, 2008 | Dryers
Kenmore elite gas dryer won't fire up
replace the coils on burner valve ..they will fail sometimes after initial heat up both are in kit change both
Jun 04, 2008 | Kenmore Elite HE4 Electric Dryer
After a few heating cycles the burner does not ignite
The problem you are describing is usually associated with a bad gas valve coil. The dryer runs normally until it gets hot, then starts making a strange clicking noise. After it cools down, the dryer runs normally again. The gas valve coils (there are two of them) usually run about $20 a piece. I recommend replacing both of them at the same time just to be sure. I hope this helps.
Apr 15, 2007 | Maytag MDG3600BW Gas Dryer
Dryers Logo
447 people viewed this question
Top Dryers Experts
