Question about Hotpoint Refrigerators
Top freezer is functioning, but the refrigerator isn't.
Top freezer is functioning, but the refrigerator on bottom is not. appliance is around five years old.
  • 612 Answers
Check to see if you can feel the inside fan. The fresh food section is cooled by the freezer only. If the fan is not running the fresh food section will be warm. Also make sure the damper is open between the freezer and the fresh food section. It is controlled by one of the two knobs inside the fresh food section. The knob that turns the unit off and on is the thermostat, the other is the damper control. They are sometimes confusing the way they are named by factory.
One of these two things should be your problem
Please rate solution
Posted on Sep 07, 2009
12-14 yr old ge bottom freezer. freezer is working, fridge is warm.
not all refrigerators are the same can you look inside the fresh food section around the door or on the back of the refrigerator and provide a model number?
Appliance 911 Sea Breeze
Sep 30, 2015 | GE Refrigerators
Lights not working
Maybe those light bulbs are not for a refrigerator appliance. Go to the local Home Depot and ask for refrigerator light blubs.
Feb 03, 2013 | Samsung RF265ABBP (25.8 cu. ft.) Bottom...
Refridgerator isn't cooling, but freezer is cooling more than it should
Some fridges use the same air fridge gets its cold from freezer the duct could be frozen closed a good defrost could do the trick
Jun 30, 2012 | Maytag Appliances Magic Chef 18 cu. ft....
Freezer not freezing enough
You directed this question at me, but unfortunately this isn't my expertise and I am unable to provide you with a real solution at this time.
Hopefully one of other experts will be able to provide you with a real solution.
Thank you for using FixYa.
Jan 02, 2012 | Prestige Appliances PRT295FFCS (9.3 cu....
Refrigerator not cold enough and freezer is too cold making food very hard? water seems to leaking on bottom of freezer and refrigerator.
Refrigerators with attached freezers typically keep the two compartments at predetermined temperatures, but failure of some components can lead the refrigerator to seem warm while the freezer portion completely freezes.
Fan Issues
According to the appliance website Appliance Aid, many freezers contain a fan that blows cold air throughout the freezer and into the attached refrigerator. If this fan fails, the site explains that the freezer may become too cold; the refrigerator will not receive air circulation from the freezer, though, and will remain warmer than normal.
Air Damper
Appliance Aid also notes that most refrigerator and freezer combinations contain a damper that regulates the flow of air between the two compartments. If the damper sticks or fails to function properly, it may restrict the flow of air from the freezer to the refrigerator. The result of a failed damper would be a completely frozen freezer and a warmer than normal refrigerator.
Hope this would help.
Good day!
Sep 06, 2011 | Kenmore Refrigerators
I have a GE Profile counter depth French door refrigerator bottom freezer and I keep getting frost in the freezer. The seal on the door isn't as tight as the seal on the refrigerator but no cold air...
Where are you getting frost at? Is it on the back wall in the freezer? if so - your problem may be a defrost issue and in that case you would need to hire a professional appliance repair technician to service your refrigerator.
Please rate us 4 thumbs up!!!! Tips Provided by: GOFAR Services, LLC - We repair refrigerators and all other appliances in the Houston, Katy, Spring and Woodlands, TX areas!
Aug 29, 2011 | GE Profile PDS20SFSR Bottom Freezer...
My icebox isn't cold like it should be,and the freezer is not cold enough to make ice. But it is frosting over on the back panel on the inside of freezer. We just defrosted a lg. piece of ice on bottom...
It sounds like a defrost system failure. The following links will give you some idea on how to troubleshoot the differeent components of that system
The defrost heater is easy to check with a ohm meter. http://www.acmehowto.com/howto/appliance/freezer/check/defrostheater.php If you have continuity, then it is good.
http://www.ehow.com/how_4504020_test-refrigerator-defrost-timer.html is instructions on how to test the timer.
http://www.acmehowto.com/howto/appliance/refrigerator/check/defrosthermo.php is instruction on how to test the defrost thermostat.
You should also check to make sure the the condenser coils are clean and that air flow is good over it. I.E. the fan is operating, and not a lot of debrie on or around the condenser coils.
Hope this helps.
Jun 16, 2011 | Refrigerators
My freezer seemed to have quit so I cleaned it out made sure the air flow was good and de-iced everything. Now the bottom of the freezer freezes but the top does not nor does the ice maker work. What do...
open the freezer door,do you hear the fan blowing around?it sounds like the evap fan motor isn't running and that's why it's cold on the bottom and not the top,you have to repair this fast or you'll loose your food in the fridge,the fan is what blows the cold air from the freezer to the fridge section.
May 07, 2011 | Amana ARS266ZBS Side by Side Refrigerator
The top freezer cools like a fridge, the bottom fridge is warm
The fluxating temps bottom to top and top to bottom freezing are a result of the "air damper and baffle assy" not functioning properly. I would attempt fo make my case with LG that this started while the unit was under full warranty and persists today.
Apr 04, 2010 | LG LRTBC1825T Top Freezer Refrigerator
Kenmore top freezer/frig has water coming out underneath applianc
THE HOSE THAT COMES FROM THE FREEZER TO THE TRAY EITHER ISN,T LOCATED IN THE RIGHT POSITION OR IS DETACHED WHERE IT COMES OUT THROUGH THE WALL
Aug 11, 2009 | Refrigerators
Refrigerators Logo
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
