No Sound on Envision H22W Monitor
I just installed a 22" new monitor to my Windows XP computer. All is fine except for the missing sound (monitor has built-in speakers). What am I missing?
Thanks for sharing your expertise.
  • 6 more comments
  • Anonymous Dec 11, 2007
    no sound. have plugged into the audio in but where is the audio out?
  • Anonymous Feb 06, 2008
    no sound
  • ch3ly Mar 06, 2008
    cant here anything on the internet like music and videos
  • Anonymous Jun 01, 2008
    Same problem. No sound. Just connected the HP1702, which was working on my old HP, to a new HP 6400F.
  • Anonymous Jul 11, 2008
    all plugged in and pc says sound working but I hear nother
  • Fancy Face 1 Aug 06, 2008
    I have the same issue with my envision monitor. There is a way to turn the internal speakers off so you can use external speakers. That is what I did but can"t remember how I did it!!!
  • susanpahnke Sep 04, 2008
    I went to control panel -- selected sounds - and advance setting to select stereo monitor speakers. I have checked all the settings I know of yet I do not get any sound
  • Anonymous Apr 11, 2009
    i have the same problem T____________T
The Envision H22W has speaker grilles, but does not include speakers. Note there is no input connector for audio.
The Envision G22LWK does have built in speakers. I think they just used the same mount/frame for both models, but only the G model actually includes the speakers.
Note that the web specs and the manual for the H22W says nothing about speakers.
No doubt this is why the H22W costs appreciably less than the G model.
Posted on Sep 15, 2008
  • 33 Answers
The speakers are not amplified, so you must turn volume completely up.
Posted on Feb 18, 2008
  • Ed Paparo Feb 18, 2008
    if it did have speakers, they aren't amplified, most likely. You would have to turn up the volume. The case with the 22" V7 LCD.
Not air holes, they used the same shell for a model with speakers
Posted on Jan 20, 2008
I think it is like just air holes
Posted on Dec 27, 2007
That model does not have speakers, so no sound.
Posted on Dec 11, 2007
No you all got it wrong...they are speed holes!
Posted on Sep 06, 2008
I need a driver.
Advertise your need by any popular newspapers. so many dirivers are free of job.
Feb 16, 2016 | Envision H22W 22" Monitor
How can I find a manual in english?
Check with Envision to obtain the manual.
Jun 30, 2014 | Envision H22W 22" Monitor
Never turns on, power light flashes fast
The flourescent lamps on the sides of the LCD panel is burnt out. If you open the monitor and look at them, I will bed they will be blackend on one end. This is common and you need to find some new ones to replace. They are usually about $15 and plug into the HV little board that drives them. Hope that helps!
Feb 13, 2014 | Envision H22W 22" Monitor
Blanks after 2 seconds
The problem is in the inverter board, caused by bad capacitors that sometime bulge at the top indicating it is open. The inverter board powers the back lights behind the screen.
Feb 15, 2011 | Envision H22W 22" Monitor
How do you take the base stand off of an envision 22in lcd tv? I want to mount it to the wall?
There is a screw on the part of the base where it connects to the monitor back, it is located on the pivoting arm, remove or take loose this screw and lift the base by holding the side opposite the screw. the base should lift off with at very most just a bit of wiggling. You can now use the wall mounting screw holes located under the corners of the sticker on the rear of the monitor, they are usually covered with a perforated area.
Jan 16, 2011 | Envision H22W 22" Monitor
Was pink at bottom now a black screen. powers on for a second or two then black screen. green power light is on.
Check whether the connector has been properly connected to the computer. Also try to boot the system with safe mode option and you are geeting display, then install the appropriate display drivers will solve your problem.
Also check the DPI setting configured in dispaly properties.
Dec 15, 2009 | Envision H22W 22" Monitor
My Envision H22w Monitor has a green light that is blinking but is not working. IT was working earlier but just went off.
mine just did this tonight. envision has a 3 year warranty and mine was within that so i am rma'ing it.
Sep 29, 2009 | Envision H22W 22" Monitor
Flashing light nothing else
Doesn't sound like a virus. Sounds like a fuse or something else is out. A red light isn't good. If the monitor is ok you get an amber light. I would suggest this monitor is gone. Sorry.
Jul 20, 2009 | Envision EN9410 19" Flat Panel LCD Monitor
Can't get sound to play on my AOC LCD from my XP computer.
did you have an installation disk?? If so it may not have loaded in the setting to make the sound card accept the monitor..Or simpler--is the right wire plugged into your computer for the sound??
color codes don't always match for generics.
Oct 12, 2008 | AOC A15X221 15 in. LCD Television
Check if the sound is enabled on your PC then check for wiring that goes to the monitor.
Do you have more information or questions?
The more information you provide to us, the better we can help.
Dec 11, 2007 | Relisys TL 766 Monitor
Computers & Internet Logo
2,991 people viewed this question
David Payne
David Payne
