Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Fridge not cold, freezer is ok
Can not hear fan inside fridge no cold air
  • 93 Answers
Your evaporator fan in the freezer is bad from what you are saying. It is behind the back wall of the freezer. Easy to change and not terribly expensive.
Posted on Sep 13, 2009
Fridges stops working randomly but the freezer works. Then the fridge starts working after a couple of days
When the fridge stops working, can you hear the fan operating inside the unit? It sounds like you have a failing evaporator fan motor. This fan motor circulated cold air from the freezer to the refrigerator.
Apr 19, 2015 | Refrigerators
Bosch kann58a50gb/o8 fridge not cooling freezer seems ok
See or hear if the fan inside is working. Im not conversant with your model. Some units have 2 fans , 1 in the freezer and 1 in the fridge. Some only have1 , which will be in the freezer only. If the fan fails, the fridge cannot blow cold air into the food compartment. Generally, when an evaporator fan fails, the fridge doesn't get cold and the freezer overfreezes causing an excess ice buildup in the freezer.
Feb 23, 2015 | Bosch Refrigerators
Fridge is not getting cold even though the thermostat is at 5
Most friges take cool air from the freezer with a fan to cool the rest of the unit. I am not familar with your model but there should be a fan somewere in the back of your freezer. Also make sure you have space in back and to the sides of the fridge for air flow.
Jul 24, 2013 | Tecnik Built Under Larder Compact...
Freezer works but refirgerator is not cold
when you open the freezer door do you hear the fan blowing?if not you have a bad evap fan motor,if the fan is blowing put your hand on the back inside wall of the freezer,if you feel like snow on the back inside wall you have a defrost problem and have to find what part is bad with a meter,bad defrost thermostat,heater or board or timer,send model number next time,ice builds up on the coil and air can't blow into fridge from freezer,could have a bad damper,also if the freezer is on top you could have a blocked drain in the freezer,the air vents freeze up and the fan can't blow air from freezer into fridge because the air ducts are frooze up,all it does is the freezer gets cold,the evaporator fan blows cold air from freezer into fridge section,so either the fan motor is bad,the fan blade is damaged or something is blocking the air like a bad damper or air ducts are frozen up,send the model number and let me know what you find,do you hear the fan,any ice on back freezer wall or anything else you see and i'll try to help you out.
Jun 02, 2012 | Refrigerators
Freezer works, fridge doesn't
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Sep 27, 2009 | Refrigerators
Maytag P MFD2561HEB model the frig is not cold but the freezer is fine. How do we set the frig control?
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 16, 2009 | Refrigerators
Hi, We have a whirlpool eb22dkxfw01 bottom-freezer refrigerator. The freezer part is working OK, compressor is running, but the refrigerator part is getting rather close to room temperature, and...
need to check for ice build up in air vent. if not make sure you hear your evap fan blowing in the freezer section. this blows your cold air into the fresh food side. do you have ice build up on rear wall of freezer section?
Jun 21, 2009 | Refrigerators
THE MAIN FRIDGE IS NOT WORKING, THE TEMPERATURE SEEMS TO BE VERY WARM. THE LIGHT INSIDE THE FRIDGE IS WORKING OK AND SO IS THE SOUNDER WHEN THE DOOR IS LEFT OPEN.
Listen for the fan that is in the freezer section. The fridge part relies on the freezer fan to get it's cold air. Only the freezer section gets cold...the fan in the freezer blows cold air through ducting to the fridge to get it cool. Either the fan is bad or the air ducting to the fridge is restricted by ice. If the airway is restricted by ice then your defrost timer is bad. Good luck.
barneyluc
Oct 10, 2008 | Refrigerators
Kenmore 5355
There is a fan inside the freezer which circulates cold air through the air diffuser and then through the return duct at the bottom of the fridge. This fan may not be working. You should be able to hear it when you open the freezer door. If you cannot hear the fan going with the door open, keep the door open and press the button that switches the internal light off. The fan should run. If no fan running in freezer test for supply to fan. The fan may be faulty or the thermostat which is in line with the fan could be faulty.
Oct 29, 2007 | Kenmore 50522 / 50524 Side by Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
121 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
