Question about Yamaha HTR-5560 Receiver
Yamaha HTR 5560 receiver. Power will not come on. I hear a double click but nothing happens. Initially the issue was a message to check speaker wires. They were fine, but now it will not power up. I am guessing the power supply is bad. I found a power transformer online for this model and want to know if that is the likely problem or how to confirm it is and also how difficult it would be to replace it myself.
techman
  • 3130 Answers
SOURCE: Immediate shut
Unplug all the speaker wires first, then unplug the unit from the wall for at least 24 hours, The plug back in without the speaker wires or anything else plugged in. Then see if it goes to the protection mode. If it does not, plug in each speaker at a time, and see if any speaker, when hooked up, makes the receiver shut down. If it does shut down, My friend, I'm afraid you will need to take this unit into a repair shop, OR get a new unit. Good Luck
Posted on Jun 06, 2007
SOURCE: Yamaha HTR-5990 Receiver
I JUST EXPERIENCED THE SAME SITUATION HERE IS THE SOULTION YAMAHA SENT ME TO RESET THE SYSTEM HTR-5990 YAMAHA HTR-5990 FACTORY PRESET PROCEDURES All models require the STANDBY/ON button to be turned OFF to start the reset process. NOTE: The remote control cannot be used during the reset procedure. All necessary buttons to complete the reset process are located on the front panel of the receiver. This procedure is not intended to correct intermittent shut-off symptoms or problems MODEL: HTR-5990 (U.S.A. model/s) (BEFORE YOU CONTINUE, PLEASE READ THE ABOVE NOTES!) 1. Before you start this procedure, locate the MASTER ON/OFF button and the STRAIGHT/EFFECT button on the Front Panel of the unit. 2. MAKE SURE THAT YOUR RECEIVER’S MASTER ON/OFF HAS BEEN TURNED OFF. 3. With the Right Hand, press and hold the STRAIGHT/EFFECT button. With the Left Hand, press the MASTER ON/OFF button and HOLD both buttons for no more than “3” SECONDS, AT THE SAME TIME. SP IMP. * 8 MIN. will appear on the display, which indicates you are in the Diagnostics Mode. 4. Rotate the PROGRAM KNOB to the right (ONCE) until the display reads PRESET *CANCEL. 5. Press the STRAIGHT/EFFECT button (ONCE) and the display will change to PRESET RESET. 6. Turn the unit off by pressing the MASTER ON/OFF button. 7. Wait 5 seconds, then turn the unit on by pressing the MASTER ON/OFF button. You have now reset your component to the factory settings. NOTE: Yamaha receivers don’t have to be reset during normal operation. It is not recommended that you reset the receiver unless a setting has been changed that you are not aware of, or the receiver is not operating properly. The reset procedure will clear an incorrect setting that might be causing abnormal operation. GOOD LUCK
Posted on Jul 30, 2007
  • 4234 Answers
SOURCE: Yamaha RX-V420 No power
If the standby voltage exists, the next step is to see whether or not the clock is working. Find the main micro chip. There should be a 3 legged crystal close by. You should see this oscillate (use a scope). No oscillation = no micro control = no turn on. It is possible that the micro is bad or the crysal is bad. Also, check to be sure that the output transistors are not shorted. It is also possible that these are preventing the system from turning on.
Dan
Posted on May 12, 2008
petraman7
  • 1175 Answers
SOURCE: HTR-6130 will not turn on
Hi
Does the receiver have a switch that allows you to turn off all the speakers?
If so,turn them off and see if the problem stays.
If it still kicks off then , one of the power amp outputs has failed and it will require some fixing
Posted on Feb 04, 2009
smarthome2
  • 1114 Answers
SOURCE: HTR-5740 Subwoofer Hooking Up Issue
You can use a hi-level to low-level adapter. Just remember, the Yamaha does not send power (wattage) to the sub, just signal. You need to use a subwoofer that has an amplifier either externally or built in.
Posted on Jun 26, 2009
Do Yamaha HTR-5560 receivers have a ground wire plug in?
If your receiver has a metal cabinet you can use any of the screws that hold the cabinet on.
Oct 08, 2014 | Yamaha HTR-5560 Receiver
Yamaha 5560 no sound from front left and right speakers. There is sound from center and back surround speakers.
hi,
just check by fault switched of the frond speakers. power on the receiver play some thing listen sound is coming from the other speaker except frond. press the speaker A button in frond of the receiver. listen is it become on. if not got to the menu of ur receiver surf for speaker configuration . find out the whether the frond speaker is off. if it off turn it on.
Dec 15, 2010 | Yamaha HTR-5560 Receiver
Htr 5630 shut off in 2 sec.
Sounds like you have a bad amp IC or transistors.
When these go bad they almost always put roughly 40 volts dc from the amp power supply to the speaker terminals. The protection circuit senses this dangerous (to your speakers) dc voltage and disconnects the speaker terminals from the amp via internal relays (the ones you hear click) and puts it into protect mode. If it didn't the dc voltage would quickly toast the voice coils of the connected speaker.
Apr 18, 2010 | Yamaha HTR-6130 Receiver
Suddenly, I can only hear the sound faintly, even though it's turned up full volume on my Yamaha HTR 5560. What happened? I've played around everywhere with the converter now. Restore defaults anywhere?...
Have you checked the MUTE function?
NEVER turn the volume up more than half-way for any sound problem. Otherwise, if you suddenly find the switch that's out of position you could blow your speakers.
What converter?
What channels, what source(s)?
Feb 27, 2010 | Yamaha HTR-5560 Receiver
YAMAHA HTR 5560 KEEPS TURNING OFF
sounds like you have the polairity reversed on the speakers
and yes it does make a difference
check polairity also make sure unit is well ventelated
you wouldnt use your compouter if it was inside a card board box
so make sure the reciever can breath also
recievers get too hot and they start blowing chips off the board
Jul 25, 2009 | Yamaha HTR-5560 Receiver
Yamaha Htr-5560 Av Receiver ,will not turn on makes click-click noise only
had the same problem with a friend's 5560. it was a resistor on the rear center channel board, which is mounted right behind the middle of the heat sink. unhook the two ribbon type cables running to it from the board.
everything will work, except the rear center channel speaker. my friend never used the rear center channel anyway. in the meantime, he bought a new receiver, so i have an extra one for my workout room. woohoo. hope this helps.
Dec 12, 2008 | Televison & Video
Yahama HTR-5560
I own this unit also and have found that it is very sensitive to speaker wire shorts. Please recheck all speaker connections to make sure you have no "stray wires" touching someplace to make a short.
Oct 27, 2008 | Yamaha HTR-5560 Receiver
Yamaha av receiver rx-359
go to best buy and buy a new recever
Jan 12, 2008 | Yamaha HTR-5560 Receiver
Will not power in
IT IS THE POWER SUPPLY HAS TO BE CHANGED ONLY THING IT COS AS MUCH TO FIX AS TO BUY A NEW UNIT AS I WAS TOLD UNLESS U KNOW WHER I CAN FID A POER SUPPLY FOR THAT MODEL
Nov 16, 2007 | Yamaha HTR-5560 Receiver
Yamaha HTR-5560 Receiver Logo
223 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
