Question about Air Tools & Compressors
Air compressor trips breaker after it has built pressure.starts fine with no pressure in tank. But when it goes for it first cycle it trips the breaker (20 amp dedicated breaker)
  • dennisstable Sep 08, 2009
    Thanks for the response. That gives me some "food for thought" in that if I start using it and not let it reach max pressure (were it would shut off and than start cycling) I should be able to keep it going.
  • A Miller May 11, 2010
    I have a similar problem with a Sears 220 VAC 20 amp machine but only when it is working hard and the motor is hot. Consequently, I avoid restarts by using air continuously (as in sand blasting). I also run a fan on the machine to help get rid of heat. Actually, mine is not a breaker problem but a overload/overtemp trip on the motor. When it goes out, I must wait for the motor to cool and then I reset the motor. No answer for your problem but I hope this helps.
    President:
  • 1,167 Answers
You have air leaking back to the cylinder which means when it goes on the compression stroke the air in the tanks have gone in to the cylinder and this makes it hard for the piston to go up on the tank from the pump is a pipe that leads into a gold non return valve this has a rubber ring and a spring inside take this out and turnit over then try this obviously draining the tank if this doesnt help check the oil level and if thats ok your motor must be seizing up on bearings get back to me buddy
Posted on Sep 07, 2009
  • ollie reece-jones
    ollie reece-jones Sep 08, 2009
    yes buddy basically if its at 150psi i will reduce it till it is 100psi this will extend the compressors life as its not working as hard to reach the max pressure reduce this by where the pressure switch is un screw the little screw in the middle off the cover then take it off then under neith you will see a gold or silver nut 10mm unscrew this to decrease pressure go to 100psi
What is causing breaker to trip? Compressor runs fine until tank pressure is built up but it trips the breaker at high pressure shut off.
Never try to fool a security breaker. You could damage the compressor, if something is wrong. It could over heat and burn out. Try to fine what is wrong or if you don't mind to buy a new one, kill it with a 30 Amp circuit breaker.
Jan 16, 2015 | Cars & Trucks
My duo therm 13.5 btu rv air conditioner started making a popping sound and dimming the lights like it's trying to cycle to shut off. Well then it started triping the circuit breaker so I changed out the 2...
The best guess is that you have a bad thermostat. When the compressor shuts off it has to stay off for a long enough period of time for the low pressure high pressure to equalize. If it turns the compressor off and back on immediately it can't start against the heavy load created by these unequal pressures. If it will start every time after sitting for 10 minutes the thermostat is making it short cycle.
May 26, 2014 | Dometic Rooftop RV Air Conditioner
Air Compressor trips breaker under load. If I remove the belt the motor runs fine, spins freely as does the compressor pump. With the tank pressure empty, the compressor starts and runs fine. When it...
Most people recommend replacing the motor capacitor in this situation, since a faulty cap will reduce the starting torque. But in my case the check valve was the culprit - there was too much back pressure on the head.
Oct 22, 2013 | Campbell Hausfeld VT6290 2.0 HP 20 Gallon...
Compressor will not come on, and it is tripping my breaker
THIS IS ALL I COULD FIND ON THE INTERNET NOT SURE IF ITS GOING TO BE OF ANY HELP TO YOU.
Do you have any other electrical appliance in the circuit that might cycle on when the compressor is starting? If there isn't enough current to go around, that might be an issue.
it could be a failing pressure switch.
Check your unloader valve. I think that it has failed, and as a result, the motor can't overcome the additional load on start up.
If the compressor is blowing the breaker, you know that it's either a short of some kind, or the electrical motor is pulling more amps than the circuit can handle..
If you are sure that it's not a short, and the motor actually starts (it's not the capacitor), and the motor shaft turns easily (meaning that the power train into the compressor head is not binding in some way and overloading the motor) then it's got to be the motor that's at fault.
Try this. Unplug the compressor, drain the tank all the way down to no PSI on the gauge, close the tank drain, and plug it back in / start the compressor.
Does it start?
I suspect either you are overheating your compressor to the point where it starts to seize (thus drawing more amps and popping the breaker) or you've already damaged the motor and it's cycle gets shorter and shorter before it's overheated to the point of seizing.
OR TRY THIS LINK.
air compressor starts then trips breaker Google Search
Oct 29, 2017 | Craftsman 33 Gallon Vertical Portable Air...
Air compressor starts fine,but trips the thermal reset ,motor seems hot. It does it in every receptacal I've tried.
With no air in the tank and amp meter connected to one leg of line, start compressor and note amp draw thru cycle. It should draw low amps at first then reach rated amp draw close to end of cycle(most likely 12-15 amps). If amp draw is normal then replace thermal breaker. Older compressors have thermal breaker incorporated within winding and may not be easily replaced (but not impossible). If amp draw is higher than rated, check capacitor for proper rating and make sure that the in-tank check valve is not leaking pressure back to pump. Good holidays
Dec 29, 2010 | Hitachi EC12 Portable Electric 2hp Air...
My craftsman 1.5hp 20gallon comperssor starts fine with an empty tank, and will fill the tank, but will throw the built in breaker when it needs more pressure.
Your tank valve is stuck open. The valve is on tank where the tube from the air pump goes into the tank. It allows air into the tank but not back out the same way. When the pump stops you hear a short burst of air leaking out that releases the pressure on the piston in the cylinder. If the tank valve sticks open, the pressure in the cylinders is more than the motor can overcome to restart and the breaker pops open so the motor won't burn itself up. The valves are relatively easy to get and easier to replace.
Oct 22, 2010 | Campbell Hausfeld 20 - Gallon Air...
Second time compressor tries to fill tank blows braker
The compressor pobably has a faulty unloader valve which bleeds the pressure off that is left in the cylinder when the compressor turns off . The unloader valve allows the compressor to start the next on cycle with the cylinder empty. Trying to start the compressor with the cylinder under pressure causes too much current draw and trip the circuit breaker.
Jul 06, 2010 | Campbell Hausfeld 10 HP 120Gallon...
Craftsman 1 HP 8 gal vertical compressor.919
Sounds like the unloader valve is not working properly. The unloader typically is at the end of a tube going to the pressure switch. The unloader is tripped when the pressure switch cuts off. The purpose of the unloader is to bleed the pressure from the cylinder when the compressor cuts off so the next time the compressor cuts on it will be starting in an unloaded condition.
when the compressor cuts off you should hear a discharge of air for about 3 to 5 seconds if the switch is working properly. The unloader can be adjusted if necessary by loosening the jam nuts and adjusting the unloader towards the lever on the pressure switch.
Apr 05, 2010 | Air Tools & Compressors
Trips breaker starting under load
The problem that you describe is caused by pressure in the airline due to faulty in-tank check valve and/ or the unloader at the pressure switch. When the compressor cycles off the pressure switch releases the air that remains in the air line thru a small valve. There is a 1/4 " tube extending from the check valve to the switch. Listen for the release of air as soon as the compressor stops. There is a small metal tab that pushes on the unloader valve that may need to be adjusted. The motor does not have enough power to start pumping if there is air/backpressure in the air line. If these parts are working correctly then check the value of the start capacitor and use meter to measure. The cap should test within 95 % of stated value. Replace parts as needed. Enjoy
Dec 18, 2008 | Coleman 3HP 11 Gallon Oil Lube, Direct...
Air compressor trips motor breaker
PLEASE CHECK THE CAPACTORS ON THE MTR, THE MTR WILL BE HARDER TO START AFTER IT HAS AIR IN THE TANK
Nov 26, 2008 | Air Tools & Compressors
Air Tools & Compressors Logo
201 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
