Question about Zoom (5590-00-03) Wireless Router (G66115)
Cannot connect to internet via lan but can connect via wifi need to have my lan working i live in a apartment but i cant have a router set up
    Master:
  • 441 Answers
First need to know if the LAN has an IPsetup manually (static IP) if it's set static set it to obtain an IP automatic.If it's already set to obtain an IP automatic, try to reset the winsock and see if that will fix the problem, search google how to do that on DOS. if that did nottry to set the LAN card to work on 10mbps or 10 half duplex mode. if this won't work then the lan card might be bad.
Posted on Sep 09, 2009
How can I extend my home internet network?
Yes you can connect the LAN ports with a network cable from your 3G router to one of your old router LAN ports
Before connecting the 2nd router:
Check it does not have a conflicting IP.
Check it is in the same subnet
ie if 3G router is 192.168.0.1
Set old router to 192.168.0.10
subnet mask 255.255.255.0
gateway is 192.168.0.1
DNS 192.168.0.1
Set DHCP off on 2nd router.
Set WIFI to Same SSID, same password and authentication
ensure it is on a different channel though.(not automatic on either)
Finally just to make sure remove any WAN settings from your router, any old ADSL config etc so that it doesnt think it is a gateway.
Apr 30, 2014 | Computers & Internet
EdiMax Br-6482nS doesnt give internet
A router is only used to connect devices together in a LAN (local area network). In order to get out to the internet you also will need a modem (cable or dsl depending on your service) You will also need to pay for service through an ISP (Internet Service Provider)
May 02, 2013 | Edimax Computers & Internet
Hi i Just bought dlink 600 i am using compaq and has iphone and internet tv all of them cant connect by wifi my compaq can only connect with a cable. on my tv it says internet connection failed. and btw cm...
ok first prep. we need to configure your router. to do that we need your compaq laptop directly connected to the dlink via ethernet cable. after securing the connection, try to open a browser, whether internet explorer or mozilla firefox. go to the address bar and type in, 192.168.1.1 it would ask you now for a username. username is " admin " password is " password " if it wont let you in, try "admin" for password. if it still cant, try to live it blank and just click on login. it would take you now to the dlink router page. there you can configure your wireless connection and set your network name. make sure to click apply settings after configuring it. then try to check your wireless connectivity again. this should work.
Sep 02, 2011 | D-Link DIR-600 Router
I have a viewsonic netbook and want to go on line wireless what do i need apart from a reuter
Requirement to setup a wifi internet connection
1. Modem (Provided by ISP - Internet service provider) 2. Wifi enabled Router (It has to be setup with modem to access internet, ie Modem and router connections using an Ethernet cable) 3. Computer with Wifi LAN adapter ( For receiving wireless signals from Router)
Let me know if you need any assistance in setting up router for wifi access.
Please rate if you like my solution Thanks
Jun 23, 2011 | D-Link Computers & Internet
I have zyxel p-600 series router and i managed to connect to internet via cable (wired).then internet works on my ubuntu 10.04 but only when i write sudo dhclient in terminal. then internet works but i...
when going wifi
you have to go to internet connections or options in the control panel and click on the LAN settings button
the wifi modem will have a security code on the back and the wifi connection area code
click on the found area code on the back of the modem then enter the security code
Jun 04, 2017 | Zyxel Prestige 600WH Wireless Router...
I have bsnl broadband connection; i am using a desktop to connect the internet,but i cant able to connect other laptop with wifi. i need bellow things with step by step instruction: 1.connecting one...
Your router has an lan address or IP. Something like 192.168.1.1. This is what you must connect to. Each of the machines you want to connect must have (in this example) an IP number between 192.168.1.2 and 192.168.1.225. As long as your machines all have a unique IP they should all connect to your router. Your modem will have a gateway and typically this will be something like 10.0.0.1. So setup for one machine may look like this [192.168.1.3 subnet 255.255.255.0
To find these setting, click on your lan connection, select "properties" and choose "Internet Protocol TCP/IP". Here you will see these settings. Your router guide will give you these settings, make sure you get them from your router guide.
Mar 11, 2010 | Computers & Internet
Wifi problem of DIR-300 dlink
just open the dlink ip homepage and configure the wireless settings
sagar
Jan 27, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
Cant connect to xbox live with vzaccess!! please help...
You have two options. Number 1, plug the 360 into a LAN port on your PC and set up the LAN connection to share the internet with the VZaccess connection. This will work as long as you are connected through vzacess manager.
Option number two, get an EV-DO router, wireless or wired, and use it to connect the xbox.
If using option 1, you may have to struggle at first with the IP settings. Make sure the LAN connection AND the 360 are set up to configure IP and DNS automatically. And make sure that you set the sharing options to include http and such. more help can be found by searching in Windows Help for ICS (internet connection sharing)
Jan 11, 2009 | Microsoft Xbox 360 Console
How to install wireless router (huawei quidway wa1003a)
if you can connect to the internet when you connect the pc to whe lan port , then your internet connection is ok and all you need to set is the wireless settings in the router.
connect the pc to the router with a cable .
then , Start-> Run-> type cmd-> ok-> type ipconfig-> enter-> look on the default gateway address -> type the numbers of the default gateway in the address line in your internet explorer-> there you should check , enable and or change the wireless settings.
Mar 02, 2008 | Computers & Internet
Can't connect to internet
The issue could be with the wifi connection that your wifi adapter is connected to. If your running a windows based system, go to the system tray and right click on your wifi connection symbol (SSID) and see which network your connected to. Every LAN has its own unique name of their Local area network (LAN), if its not displaying your LAN SSID name but a different SSID name then thats the problem. If thats the case, then once again right click on the wifi connection symbol in the system tray and change the wifi connection to your SSID for "view available connection". Your wifi adapter could be picking up a wifi connection in your area and you do not have access to their LAN.
Sep 05, 2007 | Edimax (ew-7128g) 802.11g/b Wireless...
Zoom (5590-00-03) Wireless Router (G66115) Logo
305 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
