Question about Pioneer VSX-816-K/S Receiver
Sound cuts out
I have the same problem with my Pioneer VSX-816 Receiver. The sound on my Front Left and (sometimes) right keeps cutting out. I agree with another user that it happens at lower volumes and will sometimes turn back on as I increase the volume to higher levels. I'm not sure if this is a power issues or what I need to do to solve it, but the problem is intermittent.
  • 39 Answers
No, this sounds like a speaker problem to me.
It sounds like the voice coils in your speaker(s) have been fried.
What happens is the part that is burnt does not funtion, but as you increase the volume/voltage the speaker "jumps" foward to a section of voice coil that is not as damaged.
Check your speakers!
Posted on Sep 13, 2009
Reciever keeps shutting off!
If your reciever is in a tight enclosed space, than it will overheat and shut down to protect itself. Try to get some ventilation to it by either opening the cabinet door, adding a fan, or pulling it completely out of the enclosed space.
Jan 05, 2011 | Pioneer VSX-33TX Receiver
Tip
How to make a Pioneer vsx-816k/s last longer
I really don't recommend this product to anyone, or any newer pioneer products for that matter (except the elite line). This model has the "hybrid" design, which is a very flawed design. At first the speakers will start cutting in and out, and then some of them wont work at all, and then the receiver will flash "overload" and the receiver will go into a permanent protection, all because the receiver cant handle the resistance of the speakers(doesn't matter what speaker it is). Once in protect mode, press ENTER+ ADVANCED SURROUND and it will tell you what the problem is causing it to stay in protect mode. In order to keep this from happening, use external amps. Pioneer wants around 500 dollars to fix it if its out of warranty, it will cost at least 50 to fix it yourself, in most cases it will cost 150 to fix it yourself (most cases all 3 power modules will go out, or as pioneer calls them, power packs). If you have an older vsx model (50s-80s) then it is usually worth fixing. If your having problems with pioneer vsx 3600, 3700s, 3800, or 3900s, send me an email at Joshadk@embarqmail.com and i will help you the best i can
on May 16, 2010 | Pioneer VSX-816-K/S Receiver
Vsx-816-k left channel cuts in and out.
You likely have a cold solder connection on the circuit board. Inspect the board for loose connections for the left channel - use a non-conductive pointed object and poke the board on several places while the unit is power-up. Be careful not to get electrocuted. Compare it to the right channel circuit - they are almost identical. If the unit recovers the left channel while poking, then you have found the bad connection. Re-apply solder to that junction - make sure you've dis-connected the power and dis-charged all caps before you touch and repair the circuit board.
Nov 09, 2010 | Pioneer VSX-816-K/S Receiver
Receiver issues- VSX-816 K
the speaker is not broken, its the receiver, cuz i have this model, and now it just flashes a blue light on the power button and it wont turn on. I had the same problem as you before it did wat is doing now. i ran the speakers on my vsx-3900s, and they didnt mess up at all, they only did it on the vsx-816
Apr 06, 2010 | Pioneer VSX-816-K/S Receiver
Pioneer VSX-5300; sound cutting out
try open each speaker test may be speaker or wire short....if all ok check pcb solder side....
Dec 31, 2009 | Audio Players & Recorders
Pioneer VSX-816
With the receiver off, press ENTER + ADVANCED SURROUND keys continuously for 2 sec. and it will tell you the fault it encountered. Even if it has a short, it will still protect the speakers; however, it is still a good idea to disconnect all speakers before doing this.
Dec 20, 2007 | Pioneer VSX-816-K/S Receiver
Sound cuts out.
I had the same issue with the front right speaker randomly cutting out. Thought it was a loose solder joint however upon taking it apart i found that something near the back panel was shorting out. While apart i found that wiggling the rear panel would cut in and out the speaker. Also the fan would turn on when the speaker worked, which until i took it apart i didn't know it had a fan. I removed the back panel by taking out several screw the hold the cable plug-ins. once the panel was out i insulated it with electrical tape then used a utility knife to cut out all the cable connector holes. I also took out a couple screws on the main board so i could lift it a bit from the back and ran electrical tape over the solder point for the speaker connectors. Put it back together and haven't had any cut out's since. I now notice that the fan now runs all the time exept when i press mute. I also hear a single tap noise for a second when i mute or turn off the receiver. I can certainly put up with that though. Hope this helps someone else, I put up with the speakers cutting out for 6 months before i got around to taking it apart. Also those bannana plugs are a rip off, I went to future shop to buy them and couldn't beleive they were 25.00 for two pair. That would mean it would cost me 75.00 to do my 5 speakers. Thats more than i paid for my dvd player. anyhow i didn't buy them and just used bullet connectors, pack of 10 for less than 5.00, not made of gold but they work fine.
Aug 08, 2007 | Pioneer VSX-816-K/S Receiver
Pioneer VSX-816-K/S Receiver Logo
601 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
