Question about Car Audio & Video
Subwoofer rattling. I have a 15" Lanzar OPTI1535D subwoofer and it rattles when it hits hard. It kinda sounds like its coning out but the volume is not loud and the amp is turned down.
  • rustyboat May 11, 2010
    Is the rattle from the speaker or is the baffle not sturdy enough? Try listening to your speaker ouside the enclosure (it means removing the subwhoofer from the enclosure which may be permantly sealed- that's a problem). Try the speaker face up on a folded towel. Maybe the speaker baffle needs to be replaced with a sturdier(e.g. thicker, more rigid) one.
    Problem Solver:
  • 10 Answers
Make sure your sub is securely screwed to your box, boot build, whatever you have it sitting in. Remember subs are made to vibrate when working, check your screws are tight.
Posted on Sep 16, 2009
I have velodyne hgs15bg powered sub.. After a prolonged hard run, it developed a rattle at mid to higher volumes. what went wrong ??
You possibly ripped the woofer cone or welded the voice coil - something mechanical. There's only one thing in there that moves on purpose.
Mar 03, 2011 | Velodyne HGS-15 Subwoofer
When i first bought my alpine type r 12's they were perfect bass really loud but now they aren't as loud i think the cone inside messed up
If the cone messed up there would be a lot of rattling. Most likely the subs have just gotten broken in and won't sound as loud as brand new. Over time and with use a subwoofer magnet will start to weaken. When the magnet weakens it won't hit as hard anymore.
Aug 15, 2010 | Car Audio & Video
Would a Pyramid 15" subwoofer work for my Yamaha synthasiser?
Do yourself a favor do not get anything Pyramid they are cheap for a reason and you will not get good bass response from them even in a optimal enclosure.If you want nice bass for little money go with lanzar opti 1535D sub you can pick one up for around $265 and will blow away Pyramid any day.
http://review.zdnet.com/product/subwoofers/lanzar-opti-drive-opti1535d-car-subwoofer-driver/33649420
  • Custom Tooled Die-Cast Aluminum Basket
  • COC Composite Cone
  • Jumbo Dense Foam Surround
  • 3’’ High Temperature Dual 1.2 Ohm Voice Coil
  • 100 Oz x 3 High Density Barium Ferrite Magnet
  • Power Handling: 1600 Watts RMS /3200 Watts Peak
  • Frequency Response: 30 - 500 Hz
  • Impedance: Dual 1.2 Ohm Voice Coil
  • Efficiency: 88dB
  • Includes Installation Hardware and Template
  • Packaged In a Wood
  • lanzar-opti1535d.9909657.jpg lanzar-opti1535d.3004946.jpg lanzar-opti1535d.9909658.jpg lanzar-opti1535d.1054589.jpg lanzar-opti1535d.1785277.jpg lanzar-opti1535d.9909656.jpg default.jpg
    Apr 18, 2010 | Audio Pro 15PLB76 15 Inch 800 Watt Woofer...
    One of my kicker cvrs rattle really loud at high volumes
    It could be the foam edging where the speaker meets the edge of the cone. Rubber works better than foam, and I believe kicker uses foam for this model. Check for any missing screws because sometimes air leaks make that sound you hear. also try turning down the amp a little bit
    Mar 07, 2010 | Kicker CVR12 Car Subwoofer
    Bass sounds muggy it rattles alot when volume is turned up. It just started to happen. What is happening? The bass from the head unit is at -8 while the subwoofer level is a +15.
    Have you had it checked out, if it rattles when bass hits hard, it could be busted, have you had it up extremely loud before? If so, that is probably what done it, otherwise, I would call whoever you bought it from, and ask them if they know anyone who has had similar problems to yours.
    Sep 03, 2009 | Eclipse SW8102.4 Car Subwoofer
    What size enclosure (sealed)for Alpine 12"1242D(METAL Music)
  • 12" subwoofer with dual 4-ohm voice coils
  • Kevlar reinforced pulp cone with Santoprene™ rubber surround
  • cast aluminum frame with perimeter venting
  • frequency response: 25-500 Hz
  • power handling: 200-500 watts RMS (250 watts per coil)
  • peak power: 1,500 watts
  • sensitivity: 85 dB
  • top-mount depth: 7-5/8"
  • sealed box volume: 0.57-1.0 cu. ft.
  • ported box volume: 0.75-2.0 cu. ft.
  • For rock, i actually have 2 seperate 12's in slot port boxes i built facing forward. Facing forward reduces a little resonance and spl, but keeps alot of that annoying rattle off your tag lol
    Hope this helps :)
    Dec 10, 2008 | Alpine Type-R SWR-1242D Car Subwoofer
    SONY SA-WM500 SUBWOOFER
    firt you clean the subwoofer with cleaner after that, check the subwoofer srrounding, no electrical wire ,mobile phone & electrical operated items is near ur subwoofer.
    1. Do not use maximum volume of subwoofer.
    2. Use only 65-85% volume of your sub woofer.
    Sep 25, 2008 | Sony SA-WM500 Subwoofer
    Rattle Problem w/ subwoofer
    When you put the new foam, maybe the cone went off center. Get a new kit, and re-do the job with more care. Check to make sure that the spider is okay, and that the speaker coil is not warped or anything like that.
    There are speaker companies the professionaly rebuild speakers. They are better equiped and have the jiggs and facilities to properly rebuild the speaker from the coil up.
    If you really want your speakers, you should consider giving the complete set out for rebuilding and testing.
    Jerry G.
    Apr 27, 2008 | Audio Players & Recorders
    See the rear cone, spider and voice coil junction at rest and when cone is manually lifted outward/forward.Then you can easily tell if the spider has separated, as there is little pressure needed to move the cone manually, in and out of the gap. Compare that pressure to your good sub. If there is a notable difference in physical pressure to move either cone, you can rest assured that the spider is not moving or providing resistance to cone manipulation. This is a sure sign of spider/coil joint failure and can easily be sees as you conduct these tests. If that is what you see then repair it or change with new one
    Jan 25, 2008 | Altec Lansing Multimedia Computer Speakers
    Car Audio & Video Logo
    266 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
