Question about Powermatic 1791210 Model 15S Deluxe Planer
Belt for Powermatic 15" Planer (Planer Model M-0460213)
I have a refurbished Powermatic 15" planer. Best I can tell, it is Model 15, Number M-0460213. I've found a belt number of #6284811 V-Belt M59 5GA-F46 (3L590). These are a series of numbers I've found on various websites. Can I standard V belt, if so what is the belt size (in inces) that would be comparable? Or, should I stick to oredering the belt through Ppowermatic?
Steve
    Brigadier General:
  • 4,088 Answers
Order the first one through Powermatic, then order any new replacements from the number on the belt. Or you can measure the pulley belt width and use a metal tape measure to find the total length by running the tape (number side in) over each pulley rim. Then order as a standard hardware source belt. Make sure the motor is bolted down about midway in it's mounting slots when measuring.
Posted on Sep 07, 2009
I hav a Powermatic model E16 planer, the motor has been changed to 1 phase 220 amp , the speed sees too slow, what speed should the cutters turn
If it's got the 3-3/4" three-knife cutterhead, it should run pretty near to 5000 RPM. If it's got the 1-7/8" two-knife cutterhead, it should run at nearly 10,000 RPM.
That planer should take a 3600 (3450) RPM motor.
Dec 29, 2013 | Powermatic 1352001 3520B 20x35" Wood...
The infeed roller is uneven and it snipes the boards
Sniping is common, try feeding waste stock in before or after your good wood, whichever end is getting sniped. The planer will not notice the end of your wood, and cut it flat.
Oct 03, 2013 | Powermatic 1120003 PM15 Planer/Molder
Planer problems
If you're looking at the planer from the infeed side, there's a belt guard on the right side of the head. Remove it and check the condition of the drive belt. If it's broke the motor will spin without powering the cutterhead and feed rollers. The drive belt is still available as part number 22-563 on sites like http://servicenet.dewalt.com/ and www.ereplacementparts.com. Just put your model number in their search box and find the drive belt in the breakdown.
Aug 01, 2012 | Masonry Tools
My powermatic 16 inch planer model 100 planer will not start. I tripped over the chord when it was running and it would not start after that.
when you tripped over the cored you might have broken the connection in the trigger. Take apart the trigger very carefully and make sure that the waires are not broken.
Mar 16, 2011 | Garden
Have Powermatic Planer & can't get the infeed & outfeed rollers adjusted right. Takes all you have to operate it. 24" Planer less than 10 years old & probably doesn't have 200 hours total on...
The rollers may need to be reconditioned. Try cleaning with a solvent to soften them up. I hope this has been helpful please rate if this answer has been of any help. Good Luck and have a great weekend.
Apr 02, 2010 | Powermatic 1791268 201HH 22" Planer w/...
I have a180 880--- planer and realised there are
A lot of equipment is built with sealed bearings these days--just a fact of life. Good luck!
Mar 23, 2010 | Powermatic 1791259/Model 2415 3HP 1Ph 230V...
I want to wire a 3 phase planer up. I have three
install 30 amps 3phase breaker, then wire it up with royal cable 5.5mm x 4wires
Nov 25, 2009 | Powermatic 1791297/Model 209 5HP 3Ph 230V...
Trying to find a manual for a powermatic 18o planer. NOt having any luck. Thought there was a place on line to down load. HELP!!!
Try these folks. Ask for Rich Jenkins.
J Redmond Wm And Son Inc 320 Coweta Industrial Parkway, Suites A&B
Newnan, GA 30265
  • (770) 683-7297
Nov 19, 2009 | Powermatic Masonry Tools
Powermatic 1791210 Model 15S Deluxe Planer Logo
352 people viewed this question
Top Powermatic Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Powermatic Craft and Hobby Expert? Answer questions, earn points and help others
