Question about Viking VGIC485-6G Gas Kitchen Range
How to install ignitors on Viking Range - Viking VGIC485-6G Gas Kitchen Range
    Problem Solver:
  • 15 Answers
I am assuming your referring to the stove top burner ignitor. Well - I can only say on my Viking 48 inch - it was located at top RHS of the stove on the 'back wall'. I was advised by an 'come to my home tech' that it would be located at the back of my stove (ie he would have to pull out the built in unit and cost me 500$). In fact I replaced the unit in 30 minutes ... I removed the two RHS burners (one screw each), disconnected ignitor wires, removed the bracket holding the burners (one screw), followed ignitor wires to silver box covering the ignitor unit (2 screws), opened it & replaced ignitor. Forgot to say - 1st thing I did was turn off power & gas to the range
Posted on May 22, 2010
  • 42 Answers
SOURCE: Gas Viking range: VGRT3624QSS four yrs. old.
check if burners are burning ok,if correct one of the spark electrodes is faulty.
Posted on Sep 30, 2009
  • 23 Answers
SOURCE: Viking dual-fuel range ignition problem
You may have wet it somehow. There are two fixes. Leave them on for 20 minutes on high to let the ignitors dry out. If they dry and stop clicking you have solved it. If not then contact Viking 888-845-4641 and purchase a 6 point spark module. You can try to replace this yourself. With the power OFF. Remove the wires one by one placing them on the new module and then attaching it to the wall. (this is if ur spark module is located under the burners.) If it is in the rear of the unit and u can pull out your range yourself without hurting yourself then you do the same thing. Good luck. If none helps you you may need to replace all 6 burner bases or ignotrs. Also easy. Good luck.
Posted on Sep 18, 2009
bobsteelesp
  • 22 Answers
SOURCE: Have a Viking range, gas top, electric oven, neither work.
Check connector block where electric is brought into stove for loose or burnt wires. Check Breaker in house power box. Push the breaker firmly to off and then return to On position. Read owner's manual to see if ignitor circuit has a fuse and check said fuse.
Posted on Sep 12, 2009
SOURCE: burner ignitor will not turn off after the burner lights Viking
replace the electrode that's the wire or pilot tip, it has a sensor built in, when it gets hot it stops automatically. if the electrode is between the front and rear burners, there are small holes on the burners going down on the side of the burner facing the ignition. they need to be clean. try a paper clip and insert the clip in side the holes.
Posted on Dec 14, 2008
  • 15 Answers
SOURCE: How do I access a spark ignitor on a Viking gas
I am assuming your referring to the stove top burner ignitor. Well - I can only say on my Viking 48 inch - it was located at top RHS of the stove on the 'back wall'. I was advised by a 'tech' that it would be located at the back of my stove (ie he would have to pull out the built in unit and would cost me 500$). In fact I replaced the unit in 30 minutes ... I removed the two RHS burners (one screw each), disconnected ignitor wires, removed the bracket holding the burners (one screw), followed ignitor wires to silver box covering the ignitor unit (2 screws), opened it & replaced ignitor. Forgot to say - 1st thing I did was turn off power & gas to the range. Of course you need to ensure it is the correct one for your stove. The ignitor you remove should have a manufacturer part number on it. No calibration required on mine - a sealed electronic unit. Probably about 10 wires that need to be R&R'ed - they are on with reuseable fasteners.
Posted on May 24, 2010
New ignitors in Viking range oven do not heat up
You will need to measure for 110 VAC at the control switch located on the thermostat. Pleazer Appliance...
Apr 15, 2014 | Viking Kitchen Ranges
Viking range burners not getting gas
Each burner has to have verification of ignition from the spark ignitor. If all burners will not light I would say it must be the control. Here is your Viking stove manual
Nov 20, 2012 | Viking VGIC485-6G Gas Kitchen Range
One of the oven ignitors does not work
Most likely replacing the ignitor will fix it. I usually replace Viking ignitors with Maytag ones, part number 12400035 (you'll need splice wires and use included wire nuts to connect those, though). Those have a little shorter base, which does not affect anything. Replace both bake ignitors if you can, otherwise, one of the burners will ignite slower and shut off faster, resulting in uneven bake.
Jul 17, 2010 | Viking VGSC306-4B Gas Kitchen Range
How do you access the ignitor wires for the
I am assuming your referring to the stove top burner ignitor. Well - I can only say on my Viking 48 inch - it was located at top RHS of the stove on the 'back wall'. I was advised by an 'come to my home tech' that it would be located at the back of my stove (ie he would have to pull out the built in unit and cost me 500$). In fact I replaced the unit in 30 minutes ... I removed the two RHS burners (one screw each), disconnected ignitor wires, removed the bracket holding the burners (one screw), followed ignitor wires to silver box covering the ignitor unit (2 screws), opened it & replaced ignitor. Forgot to say - 1st thing I did was turn off power & gas to the range.
Apr 08, 2010 | Viking VGIC485-6G Gas Kitchen Range
Sep 12, 2009 | Viking 30" Dual-Fuel Range, VDSC3054B...
Viking 30" Range - Igniter works - but NO FLAME in oven or ranges
No pilot light need to be ignited. You may need a new ignitor. It might not be catching. If you pull the bottom oven plate off you can see the ignitor on the side of the burner and see if it is in its place or broken or just plain old. It is a simple fix. You can buy a universal ignitor or contact Viking and they will sell it to you. Its only two wires and can do it yourself if you are somewhat technical. Good luck.
Jan 09, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
Burner ignitor will not turn off after the burner lights Viking
Dec 14, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Viking stove
no the termostat but the ignitor that's the part that's nest to the broiler burner. the part that ignite the flame. when you turn on the broiler the ignitor becomes red like a glow.
Nov 25, 2008 | Viking VGIC305-4B Gas Kitchen Range
Ignitor won't shut off
The Viking manual says that an ignitor that continues to try to light even after the burner has been lit indicates improper grounding, and that an electrician should be consulted.
Perhaps you could try to replace the ignitor, and see if that fixes the problem?
I have a similar age, 6-burner 36" rangetop.
Sep 30, 2008 | Viking 48" 6 Burner, Grill Professional...
Viking VGIC485-6G Gas Kitchen Range Logo
1,811 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
paulcarew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
