Question about Maytag PYE2300AY Electric Dryer
How do I hook the electric cord to the dryer?
  • Maytag Master
  • 8,404 Answers
Most electric dryers are 220 with a neutral. Inside the machine, they use one leg and neutral to power the timer and the light both of which are normally 120 V
Do you have a volt meter? And do you have a plug in the wall into which you want to plug the dryer?
If you have a volt meter measure between any two of the three slots in (or on) the wall outlet. You will get 120 VAC or 220 VAC. Measure the remaining slot you didnt measure and any other slot. You will get the same results. at the common point where you got 120 (120 from both sides, that is neutral. Inside the dryer should be an indicator of where the hot legs gl as well as the neutral. You can check which wire supplies which blade with a simple contuinity test to be sure if there are no marks on the wire.
I hope this helps
Posted on Sep 07, 2009
I have a imperial whirlpool dryer. I thought it was electric, it has gas hook up and a electric plug as well , can it be bothZ?
Yes, it will be both. A straight electrical dryer is hooked up to 220 volts of electricity and uses that voltage to run both the motor and the heater. In a gas dryer, you only need 120 volts to run the motor and run the igniter for the gas, which provides the heat to dry your clothes. Hope this helps!
Feb 24, 2015 | Whirlpool Dryers
Tip
Electric Dryer power connections
The supply cord on an electric dryer can be 3 wire or 4 wire,
depending on the existing receptacle. All new construction
must have 4 wire receptacles for dryer hook ups.
At the back of the dryer you will see a set of three
terminals. The outside terminals are for connecting the
outside wires of the cord. In a 4wire hook up, the center
terminal is for the center, insulated, white wire, the
neutral. The bare copper or green wire of the 4wire cord
gets connected above these terminals to a lug or stud on
the body of the dryer. There may be a strap there. For a
4wire cord connection this strap is connected to the stud
only.
The change for a 3wire connection is that the center green
wire of the 3wire cord connects to the center of the three
power terminals along with the grounding strap from the
dryer body above.
on May 05, 2010 | Washing Machines
I can't tell if it is a gas dryer or electric
I believe if it's electric, you have a 220 Volt power cord. If it's gas, 110 Volt power cord. Also, look to see if there is a gas line hooked up behind the dryer.
Hope this helps!
Nov 21, 2010 | LG Dryers
Neptune MDE5500AY Electric Dryer: electrical hook up...
If this dryer doesn't have a cord, you need to go to hardware store for a dryer cord, usually 4 wires 30 amp. the black and the red wires connect to the 2 brass screws with red and black wires already on the other side of the terminals. (oh, you should use a strain relief connector to run thru the knock out (hole) for the cable. The white wire connects to silver screw, which should have a white wire on the inside connection. Now the green wire connects to the green terminal, if there is one, or any other screw that should be marked as ground on the inside somewhere.
This should do it unless you don't have the dryer receptacles wired in yet.
May 16, 2010 | Maytag Neptune MDE5500AY Electric Dryer
How do i hook up the electrical cord properly?
May 08, 2010 | Whirlpool WGD5300S Dryer
Is my dryer 220 or 110 volts
If your dryer has a standard cord (looks like a extention cord) than you can not hook it into 220, it is a gas dryer if you have that plug. If you have a electric dryer it will have a much larger plug and vcan only be plugged into 220
Jul 08, 2009 | Roper REX3614KW Electric Dryer
How to hook up a cord to the maytag neptune dryer color codes
these are single phase so just copy red to red black to black white to white and green is ground
May 04, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag De4000 Electric Dryer Wire Hookup
black and red wire, will hook to either end of terminal posts, as long as the white wire connects to the center post. the green wirewill then atach to the cabinet of the unit,( usually a green ground screw just outside the termoal box anyhow!
Apr 22, 2009 | Maytag Neptune MDE4000 Electric Dryer
Changing power cord from 4 to 3 prong
See this link and read the article carefully - if your dryer already has a 4 wire cord, it should be replaced with same type.
http://en.allexperts.com/q/Electrical-Wiring-Home-1734/replacing-power-cord-dryer.htm
Apr 13, 2009 | Maytag Neptune MDE6700A Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
