Question about Kenmore 3.5 cu. ft. Front Load Electric Washer
Lights flashing and ran without adding any water
  • ddavina Sep 08, 2009
    Thanks Localwonder:
    I didn't mention that this is happening intermittently.
    We are thinking that it may be a balance problem with larger loads.
  • 6,784 Answers
HI. This may be a damaged inlet assembly.
The water inlet valve can be identified by the water hoses connected to it at the back of the washer. Start by turning off the water supply at the valves on the wall. Disconnect both hoses from the back of the washer. Place the hoses into a bucket and turn them on to confirm that you are getting good water pressure and to clear out any debris from the line.
Inspect the filter screens on both the hoses and the inlet valve for debris build up. If you find any debris, clean it out. Use caution to avoid damaging the filter screens because the screens in the valve are not replaceable.
If debris was not present then proceed to the next step of testing the solenoids. Access to the valve may be easiest by opening the top or the back of the washer, depending upon make and model.
There are two wires connected to each solenoid on the water inlet valve. Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip-on connectors. Firmly pull the connectors off of the terminals ( Be sure to not pull the wires). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Use a continuity tester or multimeter to test for continuity. Set the multimeter to the ohms setting X1. Touch one probe to each terminal. A reading of infinity indicates a bad solenoid that must be replaced. Different brands and models will have various measurements, but the valve should show some resistance if it is functioning properly. Test the second one in the same way as the first.
If the solenoid is working properly, but water leaks through the valve even when the washer is off, then the valve itself is the problem. Debris may be preventing the valve from closing. If the valve cannot be cleaned, it will have to be replaced. The valve can also fail mechanically. So even if it passes the electrical test, it may still require replacement. If you have ruled out all other possibilities, go ahead and replace the valve.
Posted on Sep 07, 2009
Kenmore HE2 flashing lights
did the technician point out wat needs to be repaired
Aug 24, 2008 | Kenmore 46462 Front Load Washer
Lights keep flashing and door locks without finishing cycle
Kenmore HE2 Plus Front Load Washer Keeps unlocking ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
flashing prewash and add garment lights My HE2 Plus will fill with water, but when ...Kenmore HE3 2plus wont finish cycle Washer wont finish the last1 minute of cycle. ...We ran a load twice and it still did not unlock. du is the code for cannot ... Why does the door keep unlocking and locking in between the drum rotating?
Admiral, Whirlpool, Maytag - Washer Repair - Not ... - YouTube
? 5:51
https://www.youtube.com/watch?v=oBihToN6dxs
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your Admiral Top Load Washer that has these following symptoms: Not Completing all Cycles ...
Washing machines - Ariston
Jan 05, 2016 | Washing Machines
Dishwasher salt beko
Rinse aid and salt are not necessary if you use powder that is similar to the tablets. The lights are warning you that you havent added them, you know that so ignore the lights. If you live in a hard-water (limescale) area salt can be used as well as tablets or powder to make the water kinder to the machine, but most people just use tablets without rinse-aid or salt.
Dec 14, 2013 | Dishwashers
Had problem with clean bilking light. I was able to reset with your help. But it keeps coming back after every cycle. Dishes are not drying as well. How can I fix this?
The flashing light indicates there is a heater issue caused by a failure of one or more of the following: (1) The heater. (2) Door switch. (3) Water high temperature limit switch. (4) Electronic control heater relay. (5) heater wire may have loosened from heater terminal and burned off. If the heater is of the round type, test this first.
Mar 05, 2012 | Whirlpool Dishwashers
Starbucks sirena lights won't turn on
Just had this happen. Finally I let water run through the steam wand (thought it had to heat up first). Water ran through (until blue light stopped blinking) and now the other lights are blinking...we will see if it works now.
Sep 05, 2009 | Saeco Starbucks Sirena Espresso Machine
Indesit idl 40 2&3 lights flash
The problem is lack of water. Check that the water is turned on at the stop **** and make sure that the hose hasn't been traped if the dishwasher has been pulled out from it resess as happened to mine.
Jan 21, 2009 | Indesit 18 in. D41 Slim-Line Free-standing...
Cuisinart programmable espresso maker em-200C
Currently, both my manual and steam button are flashing. No idea why. Any help?
Feb 27, 2008 | Cuisinart Programmable Espresso Maker
Washing Machines Logo
106 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
