Question about Epson Stylus CX9400Fax InkJet Photo Printer
Paper jam but there is not one.
Printer states "paper jam", but there is not one.
  • 52 Answers
Open and close the door
Posted on Sep 08, 2009
My epson stylus states jam paper there is no paper in it?
It might help to know the model of your printer. Even small pieces of paper or even dust can trigger a "paper jam" indication. I've used compressed air cans to blow out the paper path.
A bad jam that you have cleared can also bend/move paper sensors so they don't register the paper anymore. You can check for that. Does paper travel through the printer if you press the paper-feed button?
Oct 21, 2015 | Epson Office Equipment & Supplies
Why do i have a false jam reading?
I understand that you're receiving what you believe to be a 'false' paper jam on your HP Photosmart C6280 All-in-One Printer. I would like to work with you today with resolving this issue. Paper jams can be real or false. The product might report a paper jam even when there is no jammed paper. A false paper jam may also be the result of having a bad paper jam at a point in time and that bad jam causing a hardware issue to the paper sensor or rollers. I am going to provide you with some additional troubleshooting steps that apply to both real and false paper jams. You did state that you already checked the paper pathway inside the printer and failed to find any evidence of paper being stuck, but please run the step-by-step troubleshooting below, even if you have already run some of the steps.
Here are the steps for clearing the path:
Photosmart c6280 False Paper Jam Messages
Try this blog for alternate clearing ideas for this printer. HP Photosmart C6280 error message Carriage Jam
Jul 02, 2014 | HP Photosmart C6280 Printer
Constant paper jams
Open the printer and with a blower clean it thoroughly.
This resolves the paper jam issue many times.
Nov 16, 2011 | IBM Infoprint 1332 Laser Printer
AFTER PAPER JAM WILL NOT PRINT
The printer could be stuck with the paper jam error due to paper still stuck inside the printer. Make sure you check under the toner, in the back of the printer and at the paper tray. If there is still paper jammed then the printer will not go to a ready state. The other problem could be that the printer sensor got damaged after removing the jammed paged. If that is the case then you will probably have to take the printer to a service provider to fix it. Here is a link with illustration on how to check and removed jammed paper. http://bit.ly/aqUrn7
Feb 20, 2010 | Lexmark E232 Laser Printer
Printer now very reluctant to pick up the paper from the tray, keeps reporting paper jam. Think this could be a problem with the rollers
The printer could be stuck with the paper jam error due to paper still stuck inside the printer. Make sure you check under the toner, in the back of the printer and at the paper tray. If there is still paper jammed then the printer will not go to a ready state. The other problem could be that the printer sensor got damaged after removing the jammed paged. If that is the case then you will probably have to take the printer to a service provider2_bing.gif to fix it. Here is a link with illustration on how to check and removed jammed paper. http://bit.ly/aqUrn7
Feb 15, 2010 | Lexmark E232 Laser Printer
My Printer Jammed
If it states that it's jammed, there must be some tiny piece of paper or lint or a foreign object still inside your printer. Check the paper path again.
Oct 08, 2009 | Canon MX300 Office All-In-One Printer
Rear Paper Jam - No paper present.
Look for a small piece of paper that may be stuck in the switch indicating a paper jam.
Jun 01, 2009 | Canon PIXMA MP610 InkJet Printer
Printer states System Error Clear paper jam but no paper is there
If you did have a jam and did not get ALL the jammed sheet out, there is still a small piece of paper in there somewhere, probably covering a sensor or micro switch. Get a torch and look carefully. If youu don't find anything you may need to disassemble the printer to find it.
May 16, 2009 | Compaq A3000 All-In-One InkJet Printer
HP 3419A
Hi Mose,
I never faced this problem any time , but could find a solution for you which i think will be helpful.
The paper jam error state occurs if the printer detects a paper at the platen after attempting to eject paper to the out tray. Clear the paper path.
<Power and Resume>
1. Turn the printer OFF and back ON to allow the printer to clear the jam.
(If the paper remains jammed, turn it back OFF and follow the remaining steps.)
2. Open the top cover and remove the OUT tray.
3. Pull the jammed paper out of the printer by grasping the middle section of the paper.
4. Remove all torn pieces from the paper path.
5. Remove any wrinkled or torn paper from the IN tray.
6. Reload the paper stack.
7. Replace the OUT tray and close the top cover.
8. Turn the printer ON.
Hope this answers your problem, Please let me know by providing your valuable feed back
Thanks,
Robosoft.
Dec 24, 2007 | HP Photosmart 375 InkJet Printer
Epson Stylus CX9400Fax InkJet Photo Printer Logo
73 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
