Question about Garden
I have an old Briggs and Stratton engine 16hpv. I
I have an old Briggs and Stratton engine 16hpv. I was cleaning the carburettor and blew out the jets with an airline and a very small spring came out from behind the fuel inlet diaphram. Although it still runs it it very 'lumpy'. Can you please tell me what spring it was as it was lost and where I can purchase a replacement also a diagram where the spring should be fitted and a service kit.
Many thanks
Frank
  • 62 Answers
I am trying to find you a spring..i have a bunch of old stuff out back. give me a couple days. It holds the diaphram steady to prevent chattering of the rubber while fuel is flowing...:)also what year is your briggs and model?
Posted on Sep 08, 2009
Riding mower wont start
if the carburettor is fine and the choke is working, check the ignition timing.
May 19, 2016 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and Stratton hunting and surging.
How about a leak down test?? sounds like blow bye. is it consuming large amounts of engine oil???
Apr 08, 2014 | Briggs & Stratton Garden
Smoking and loosing power
Blue smoke means engine worn or too much oil in sump.
Black smoke is caused by too much fuel being sucked into carburettor.
This can be caused by a dirty air filter, choke being left on after engine is started or fault in choke system if automatic choke fitted.
Feb 21, 2011 | Briggs & Stratton Briggs Stratton Intek V...
I have a briggs and stratton ride on lawn mower 14hp model 287707. engine pumping oil through breather into carburettor when running, its working but burning oil.
The float is getting stuck open which will cause the engine/sump to fill with oil and thats why you see oil comming out carby/air filter clean ya plug drain your sump turn motor over with plug out a few time to clean out check float/needle and seat in carby refil oil clean ya spark plug and off you go it will blow heaps of white smoke don't worry it is just buring th oil out if the exhaust/engine hope this helps some one
Mar 26, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Briggs & Stratton 3.5hp running problems. I am unable to get my B&S to run smoothly It starts and runs but continuously but hunts all the time and does not get up to full power. any sugestions of...
people often leave petrol in these types of engine when not in use for long periods and susequently the petrol then turns bad, the only way to resolve this is to take off the carburettor and clean out espesially the main jet
Mar 21, 2010 | Briggs & Stratton 30-Amp Extenda Panel -...
Briggs & stratton Modal No 490179 carburettor linkage
it sounds like the governer needs to be set and the carb needs to be cleaned out> I would get a carb rebuild kit and go to briggs online and look up how to set the gov dont run it till you do or you may blow the motor
Aug 31, 2009 | Briggs & Stratton Power Products 5,550...
21hp b ANd S engine keeps stalling unless choked
CARB CLEANER FOR CARS WILL WORK JUST FINE,BUT YOU MIGHT HAVE TRASH IN THE BOWL.IF SO YOU WILL HAVE TO TKE THE CARB APART
Aug 17, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
126 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
