Question about Samsung CLX-3175FN Color Laser All-in-One Printer
Printer LCD "Replace/Install Toner Waste Bin
This Samsung CLX 3175FN started having problems printing a couple weeks ago. It would print the letterhead on a page, but when it got to the body of the letter it printed a column on the left side. It looked like all the characters for the line were printed on top of each other in a column 1 character wide on the left side of the page. It was an occational problem. Most times it would print properly.
Now it refuses to print at all, and the LCD is flashing the message "Replace /install waste toner bin.
I talked to Samsung support, and they said that the main board probably needed to be replaced. The printer is out of warranty. Is that a repair that I can do, and where would I obtain a main board?
I have just now, taken the waste toner bin out, squirted in some hand soap and water. Shook vigorously and rinsed it out. the CLX-3175 is working a treat again !
Posted on Jul 31, 2010
  • 1 more comment
  • tb7071 Mar 23, 2011
    WORKED LIKE A CHARM!!!!! THANK YOU VERY MUCH!!!!!
  • aldonahawtho
    aldonahawtho Jun 25, 2012
    Thank you!!! You saved me lots of money and time! I took the bin out and shook out all the powder carefully into a plastic bag with a zip seal (take care it's a dirty job). The bin is the box next to the colour cartridges in front of the machine. Find it on the left with the letters for the colours on it. It will come out when you take cartridges out first and then pull on the small handle at the bottom left. After cleaning insert all elements in reverse order and make sure they click in place. The machine is working now without even washing the bin! Aldona
  • wong_yer
    wong_yer Sep 09, 2012
    LOVE U SO MUCH. WORKS!!!
    Scholar:
  • Samsung Expert
  • 113 Answers
The max of the OPC can go is up to 25K +/- it seems like your OPC got to replace. waster toner have to be replace every after 8 - 10K print. you do not have to replace the main board. the Waste Toner dosen't cost much but for the OPC (Image drum) it will cost alot more.
Posted on Apr 19, 2010
  • thaibao_triv Sep 09, 2011
    Loi nay rat don gian. Chi can lay 04 hop muc ra, sau do thao cai hop chua muc thai (nam phia ben tay trai cua ban) ra roi dem do bo, sau do gan lai nhu cu roi bo 04 hop muc vao la OK.
    New Friend:
After emptying into outside trash. washed with dish soap and water let dry for 20 mins and works great!
Posted on Apr 19, 2013
Replace the wast toner for the samsung clx3175
My Samsung CLX-3175 printer will not print - the message is replace/install toner waste bin. I have emptied the waste bin of all the ink and still the message will not go. I have a stack of work to do and am stuck as to what to do next! Help please
Apr 01, 2014 | Samsung CLX-3175FN Color Laser All-in-One...
Why can't I just print in black and white even though I am out of the Cyan toner for the Samsung CLX-3175FN
Dear user,
You have to select monochrome print settings first. go to properties of your printer and choose the tab where you get to select between B&W and color.
Aug 22, 2012 | Samsung CLX-3175FN Color Laser All-in-One...
My Samsung CLX-3175 printer will not print - the message is replace/install toner waste bin. I have emptied the waste bin of all the ink and replaced it and still the message will not go. I have a stack...
open the cover and now remove the waist toner container (you say it is empty) check the conection to the drum unit sometimes if the waist toner is verry full there is a pille of toner closing this connection, now clean it and all the sorounding from the toner and mount the waist container back in his possition, close the front cover and try, it should work now.
Apr 27, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
How to solve the problom of 'install/replace toner waste bin'?
Laser printers "print" by throwing toner onto a electrostatically-charged drum. The ink that sticks is then heated, and melts into the paper. The ink that does not stick falls into the "waste-bin".
Eventually, that waste-bin gets full, and needs to be removed, and emptied.
Aug 24, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
How do i print when it says replace/install toner waste bin
There is a bin in the bottom of the printer that will come out. Look at manual and you will find it.
May 27, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Wont print
Usually with most samsung printers they have a toner waste bin in the printer. As you print, the waste toner dumps into this bin and fills up over time. Your printer manual may tell you where this is, but usually its right in the front of the printer when you open it up. It usually looks like a white or black plastic bin. There should be a plug on it that you can pop off and dump out the waste toner. After doing that put it back in your printer and it should get rid of the message.
Hope this helps :)
Apr 30, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Dell 1235cn Laser All-in One Printer - Waste Toner Bin issue
Wash it out with rubbing alcohol and let dry. Apparently there is a light sensor that will throw up this error if the bin is dirty.
Mar 09, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
Samsung CLX-3175FN Color Laser All-in-One Printer Logo
6,514 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
