Washer drum out of balance... Frigidaire tumble action washer model FWTR647GHS... Major whumping/thumping during final spin... tried stopping machine to redistribute load to even it out... improved but not nearly eliminated... ran final spin with no load at all - noise was almost non-existent, but still not normal, and balance was still off... how do I restore the balance?
  • yohzheek Sep 09, 2009
    After taking off the back cover, the counter weight does not seem to be loose at all. There appears to be the slightest amount of "wiggle" where the flywheel (around which the belt runs) connects to the tub to drive it. There is almost no movement at all, but at the high speed of the final spin, I imagine it could translate into the horrible knocking that is being produced. I wondered also about the "shock absorber" type mechanisms supporting the tub from underneath (whether they may need to be replaced... the machine is around 10 years old). Do these sound like valid possibilities to explore as culprits? (Oh, and thanks much for your prompt reply before!)
  • 574 Answers
You might have a broke or loose counter weight that balances your tub.
Posted on Sep 07, 2009
  • roberta3fan Sep 09, 2009
    Yes it could be the shock absorber. that would be another things to look at.
Model fwt645rhso will agitate but won't drain out, on spin cycle washer spins one way, stops goes back the other way, but water will not drain out. Does not rapidly spin on final cycle. Any...
There's an auxiliary switch in the door lock.switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. The machine will NEVER advance to the spin cycle unless the auxiliary switch is activated as a safety feature to prevent the door from opening during a high-speed spin cycle that may result in physical injury. The drum tumbles back and forth while the machine control checks the auxiliary if activated but since it's not, the control will not command the motor speed control to spin the drum at high speed. These symptoms may indicate a faulty door lock/switch assembly and may need replacement. Click on the links below for the detailed troubleshooting instructions and replacement of the door lock/switch assembly.
Electrolux and Frigidaire Washers Door Lock/Switch Assembly Troubleshooting
Replacing the Door Lock/Switch Assembly on Electrolux and Frigidaire Washers
Jun 18, 2011 | Frigidaire GSTF1670A Front Load Washer
I am having issues with my washing machine. At it's final spin it seems to be off balance and makes loud noises
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 05, 2010 | Frigidaire Washing Machines
Frigidaire tumble action washer will not agitate or spin. Drain water fine. One of the shock absorbers is broken. would this be the problem? The belt is fine.
Yes there are several balance switches in the unit and if the shock is broken at least one switch has been activated. If you were to some how bypass the switch the unit would be very dangerous to even be near during the spin cycle as it would try to walk, tumble or jump across the room! The switch is a safety feature for all concerned.
Please get your machine repaired.
Thanks for using FixYa!
Kelly
Mar 10, 2010 | Frigidaire 14 Cycle Tumble Action Washer
Loose drum bangs during spin cycle turn by hand with nothing in drum and still bangs?
your front drum support blocks have failed. remove the tub and, replace or, rebolt them in place so they hold the drum front in place.
Jan 25, 2010 | Frigidaire 14 Cycle Tumble Action Washer
Frigidaire Tumble Action washer won't complete the final spin. leaves clothes soaking wet.
Had the same problem and fixed with ease. The problem is with the door lock. There is a secondary locking mechanism that kicks in for the final spin due to the high speed. When the secondary lock goes bad the washer will not do the final spin. The replacement part is under $40 @ AppliancePartsPros.com .
Dec 08, 2009 | Frigidaire 14 Cycle Tumble Action Washer
Model #fwtr647ghs- It washes fine bu there is a clunking sound that happens on spin cycle, like somthing is being hit
Hi I am Vortash the most likely cause of your impact sounds are the drum as it hits the side of the machine on spin .. this is a result of an uneven load and the fact that the suspension springs for the drum and support rubbers may be worn . The load evens itself out eventually and the banging stops I assume , as the centralfugal force evens the load and the drum spin becomes more balanced . Replacement or tightening of the springs is adviseable but it depend how old the machine is as to the economics of this .. regards Vortash
Jul 14, 2009 | Frigidaire ATF6000ES Front Load Washer
Frigidaire tumble action frontload washer loud knocking noises
These are the stabilising blocks. They are there to stop the knocking and noise. You should be able to buy them. Try the manufacturer or go on Yahoo or Google search for wash machine spares. Hope this helps.
May 20, 2009 | Frigidaire 14 Cycle Tumble Action Washer
When washer is in spin cycle drum is out of balance.
REMOVE THE FRONT PANEL AND SEE IF ONE OF THE SPRINGS HAS BROKEN, COME OFF AND THE TENSION OF THE BELT OR THE TENSIONER PULLEY
Apr 09, 2009 | Frigidaire FWS933F Top Load Washer
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Pounding noise after wash and final spin
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
    if this helps please give a fix ya vote
  • Jul 14, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
    Washing Machines Logo
    435 people viewed this question
    Top Washing Machines Experts
