Question about Vacuums
My Bissell TurboForce Bagless Turbo Brush doesn't work
My Bissell TurboForce Bagless Turbo Brush doesn't spin or anything else. I have it attched to the hose but can't find any switch that would divert suction to it. I have emptied the canister and cleared the hose. Any other suggestions?
Clean the filters..on atop the dustbin, inside the dustbin bottom..and over the fan below..if not sqeaky clean you loose suction
Posted on Nov 03, 2009
Bissel 3760-4 brush motor doesn't turn on
Hi Tim. I understand the brush is turning & belt is fine. You may want to remove and reseat the canister. If this doesn't work, you'll want to have one of our Authorized Service Centers inspect your vacuum.
Here's a link to assist you in locating one in your area: http://www.bissell.com/service-centers/?cid=ccsocial
Apr 19, 2013 | Bissell Lift-Off(R) Revolution(R) Turbo...
My Bissell powerforce bagless turbo roller will not stop spinning. What disengages the roller?
Hi Hiram. The brush will continue to spin when you're using the upholstery hose. You may want to set your height adjustment to the highest setting and leave the handle locked in the upright position.
Here's a quick link to downloading the User Guide if you need a copy:
http://www.bissell.com/user-guides/?cid=ccsocial
Apr 02, 2013 | Vacuums
Is the beater brush on the Bissell Helix NOT to spin on bare floor setting?
Hey Tony! The brush does continue to rotate when using the vacuum on the bare floor setting.
Feb 02, 2013 | Bissell Cleanview Helix Deluxe Bagless...
I have a bissell powerforce bagless turbo. The problem is the brush bar is not spinning. I have cleaned out all the debris on the brush itself, and taken it apart to make sure nothing is blocking the
Sorry to hear you're having difficulty with your vacuum. You may want to have a Qualified Technician at a BISSELL Authorized Service Center inspect your vacuum. Here's a quick link to locating a Service Center. http://www.bissell.com/service-centers/?cid=ccsocial
Dec 19, 2012 | Bissell Vacuums
The turbo brush attachment on my bissell cleanview helix suddenly wont spin. I bought this vacum a month ago. there is nothing wrong with the vacum otherwise.
The turbo brush may just need to be cleaned. If hair or other large debris gets wrapped around the brush, it can prevent it from spinning. Since the top of the turbo brush is clear, you can look in and see if there is a lot of hair wrapped around the brush. If so, you can open it up by removing the two screws on the bottom of the brush and popping the clear cover off, then cleaning all the debris from the brush (scissors work well if its hard to get dog hair off). Be careful to see how the brush goes back together as you take it apart.
If cleaning the brush doesn't fix it, the belt might be broken. As you're looking at the top of the brush, there is a little belt that goes from the brush itself to the large blue/green gear (it's red on some models) so that if you reach your hand in and turn the gear, the brush should spin. If this belt is broken or missing, it will need to be replaced. You can probably find a replacement belt online, or you can order a whole new turbo brush from the Bissell website for $24.99.
Feb 04, 2011 | Bissell Cleanview Helix Deluxe Bagless...
The belt on my vacuum cleaner model 6596 bissel powerforce bagless turbo keeps breaking. As soon as I put on a new belt and start it up the belt snaps. It is the durabelt meant for this vacuum model....
I would guess you aren't centering the belt correctly, thus it's edge is caught between the brush and another solid object, causing the breakage.
When you get the belt on the the brush and the brush back in place, turn the brush a few times by hand to make sure it's not catching on anything. After you get the powerhead put back together, do this again. It's a common problem if the powerhead isn't assembled correctly.
Here's a video clip from the Bissell site demonstrating changing the belt.
http://www.bissell.com/how-to-videos/replace-brush-belt-vacuums/
Jan 08, 2011 | Bissell 6596 Bagless Upright Vacuum
I have a problem with my model 6585-3 bissell upright powerforce bagless turbo with turbo brush vacuum The brush has quit spinning upon removal i noticed that one side of the brush was free to spin the...
Hair and dust build up under the end caps of the brush roll and cause friction. Replace the brush roll and belt. Be sure to clean the brush roll frequently after use.
Jun 24, 2017 | Vacuums
Bissell Lift-Off(R) Revolution(R) Turbo Upright.
If you have a rubber smell, then the belt is slipping, does the brush roll turn freely while holding the ends? If not then replace it, part #2036619, if it is ok, then the belt has strectched and is slipping under load, part # 2106679, Style 8.
Jan 20, 2008 | Bissell Lift-Off(R) Revolution(R) Turbo...
Vacuums Logo
580 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
