Question about SNK Magnavox 32MD357B_37 32 in. LCD HDTV/DVD Combo
Magnavox 32md357b has multi colored vertical lines in picture,turned off cable box,then back on,picture goes back to normal,for maybe an hour,then symptom reappears,seems like a failing board,but don't know which one.
How to fix Multi color Vertical Lines on a Vizio E470i-AO TV
Does the menu function display the same lines? What kind of cables are using ? (HDMI, Component vid, S-video, co-ax)
Were you as tenacious checking all cables/connections as you were the electronics? Lets rule out this all too often over-looked possibility.
Do you still get the lines with nothing connected to the TV? (no source connected)
Feb 28, 2016 | Vizio E-Series E470I-A0 47" LED TV...
Magnavox #32md357b/37 it has a inverted picture like a x-Ray picture tried to color on it and it won't adjust to natural color
Sounds like T'Con board fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD screen are similar, irrespective of its brand and screen size.
Feb 20, 2016 | Magnavox Televison & Video
Screen has color. but no picture. only moving multi colored vertical lines. tv does have sound, but no picture.
Unscrew the cable off the cable box on the out to TV end, then screw it back on. You may also try a different type of cable, like HDMI or component cable.
Dec 27, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
Oct 04, 2009 | Philips Magnavox 42MF521D/37 Television
Vertical colored lines on left half of screen.
I had a similar issue. Took it in and apparently i had 4 bad capacitors and after replacing those, my tv was perfect. But I think I lucked out on this one. :) try it.
Nov 02, 2008 | Televison & Video
We have a Samsun LN-T4071F LCD TV. The screen is all white and colored vertical lines. We disconnect the HDMI cable from the Dish box and the screen stays that way. We turn the TV off for a couple hours...
Do you have warranty on this unit?If warranty available contact servicer.
From your description problem is in the Digital board.
Replace digital baord.
Dont forget to Rate!
Good Luck
Dals123
Oct 22, 2008 | Samsung Televison & Video
Onkyo TX-SR605 video problems
Bypass most reviews say video area is still alittle shaky
Feb 08, 2008 | Onkyo TX-SR605 Receiver
Vertical colored lines no picture.
if the tv is less than a year old , call 1-800-SAMSUNG for warranty repair, the lcd panel is bad
Dec 17, 2007 | Samsung LNT3242H Television
SNK Magnavox 32MD357B_37 32 in. LCD HDTV/DVD Combo Logo
214 people viewed this question
Top SNK Televison & Video Experts
matt martin
matt martin
Are you a SNK Televison and Video Expert? Answer questions, earn points and help others
