Question about Epson Stylus Photo 1290 InkJet Printer
Re: epson 1290s - black smudges
Re: epson 1290s - when printing large areas of black - it smudges on to other areas of the print
    President:
  • Epson Master
  • 2,022 Answers
Make sure ur catridge is not leaking just remove the catridge and clean with tissue paper and try.
Posted on Sep 08, 2009
While printing in black, why are there faint ink smudges?
It could be the "clean print head" sponges. The area under where the print head sits is where the ink go during the head cleaning cycle. They can become saturated with ink and smear onto the print head and then onto the paper.
Mar 14, 2016 | Epson WorkForce Pro WF-4630 Wireless Color...
5x7 inch paper moves towards end of print and black ink smudges edge of paper
Check for any small paper jam. Check the rollers, also use an alcohol swab to clean the rollers and check for ink leaking. Check you ink pad, it could be time for a new one.
Jan 21, 2014 | Epson Stylus 1400 InkJet Photo Printer
My officejet pro 8500A prints black vertical lines down the page when I make a copy. I have cleaned and aligned the printheads. What else can I do?
Happened with me too. Turned out to be a small sticky smudge on the ADF glass. That is the smaller glass scan area to the left of the large glass scanning area.
When using the ADF to scan or copy, make sure the smaller glass area is clean along with the rollers.
Oct 05, 2011 | HP Officejet Pro L7580 All-In-One InkJet...
My Epson 1290s is printing with lines running through, less than a centimetre apart. the lines are always in colour, and even occur on black and white printing. the lines always appear to be magenta.
Go to your printer settings and navigate to the "Maintenance" options. Run the options for alignment and nozzle checks. If this does not work, the print heads may need to be cleaned, especially if the printer has not been used for a while. You will have to remove the ink heads and use alcohol to clean them if you feel comfortable doing so. Otherwise, it may be cheaper just to go out and buy a new printer if the print heads are defective.
Feb 28, 2011 | Epson Stylus Photo 1290 InkJet Printer
Problem with black print head only.
clean by injection siringe, if not solved you need to replace print head
Jan 07, 2010 | Epson Stylus Photo R300 InkJet Printer
Too much toner on paper which then smudges
Try reducing the print resolution using the menu buttons. Does it smudge with coloured prints? If so then the fuser unit is faulty. If it is only black that smudges it is likely to be the K Developer unit. Ensure that you are using genuine toners, not refills or third party as the quality of toner can cause similar results.
Jan 14, 2009 | Epson Aculaser C1100 Printer
Banding only when printing with black cartridge.
Print at a higher resolution. Not ideal - but if you print at a photo or photo RPM mode the printer will make more passes over the sheet... If this doesn't work, consider updating your drivers.
Steve
www.yourhandinmine.co.uk
Oct 18, 2008 | Epson Stylus Photo 1290S InkJet Printer
Epson 1290s printer
Have you set the paper size correctly? If you try to print on A4 and the printer is set to "letter" - which is the default for a number of printers. Also check that "Borderless" is selected in the driver.
Steve
Aug 29, 2008 | Epson Stylus Photo 1290S InkJet Printer
Epson Stylus CX5000 blurry or smudged printing
epson uses pigmented ink and compatibles use dyes and thus if the paper is not of good quality then you can have this problem.
do the following
change the paper and try.
As there will be ink in the head and the ink feed tubes , print some 10 -15 copies of all color prints so that the original ink starts to get into the head and then the paper.
this should solve your problem
Also use your printer every 2 -3 days if you dont have any prints then give a noozle check and then switch off the printer. This will avoid the printer from doing a head clean very time you switch on the printer and also the ink will give you more output as there is less amount of head cleaning
bye
Aug 09, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Epson Stylus Photo 1290 InkJet Printer Logo
222 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
