Knob just spins,wont work - Washing Machines
  • 725 Answers
If it's your timer knob, you will have to replace the timer. Call or email us with your model number and brand and we will send you the proper part right away. We hope this solves your washer issue for you.
Posted on Sep 07, 2009
Kenmore 80 Series washer wont turn on from the push-pull knob.
On this type of washer, you have to push it in to engage the dial and rotate it slightly clockwise then pull it out to start filling.
Feb 11, 2017 | Kenmore Washing Machines
On my ifs40 imperial fryer the pilot knob just spins around and wont send gas up to pilot orifice when i push it in
There is a little tab on the knob that is broken. Replace the knob and the fryer will work. One center screw holds the knob on the valve.
Jul 19, 2016 | Imperial IFS40 Deep Fryer
I have a 2001 alero oldsmobile. I replaced the blower knob, the blower motor an resistor an still my blower knob does not work at all please help!!!
alero's had a persistant problem of ac condesate building up inside heater box and rusting the blower drive motor shaft to the point it wont turn anymore id get a look at this first. if fan wont spin free with your fingers all them other parts arnt going to help you
Oct 24, 2014 | 2001 Oldsmobile Alero
F 21 keeps flashing and the machine is stalled and wont spin even after cleaning filter?
F21 relates to a motor or control board fault.
However, it is also caused by spikes in the mains and can be spurious.
To reset it.
Turn the appliance knob to the off or reset position, 12 o'clock.
Turn the knob to the 6 o'clock position.
Press and hold the spin button.
While holding it, turn the knob to the 7 o'clock position.
Continue holding the spin button for about 5 seconds.
Release the button.
Turn the knob to off.
When your turn it back on it should have cleared the error code
Nov 27, 2010 | Bosch Classixx WFL 2066 Front Load Washer
My machine fills but wont spin or drain
The problem will be in the timer kindly replace the timer to solve your problem
Jan 03, 2010 | Washing Machines
Washer wont work at the spin cycle phase
you nead to replace tjhe door switch.the part#for the door switch is 8318084.
Nov 14, 2009 | Whirlpool LSR5132PQ Top Load Washer
Will not spin water stays in and wont drain the tub wont spin and when you try to jiggle the knob it is derad on the spin cycle
Assuming you have agitation, the tube wont spin because the mechanism to spin is prohibited by one of these the clutch, the brake, or the pulley is not engaged as designed. They are all need to be inspected before jumping in to buy the parts for replacement. Good luck.
Jul 13, 2009 | Washing Machines
Burner knob wont turn
appliance repair and yes you can fix it you likely need an infinite switch
Apr 17, 2008 | Cooktops
Washer not spinning
my ge top load washer washes but wont spin at end of cycle to ring the clothes out. if i mess around with the switch or motor wire connections it starts to spin with some help
Jan 05, 2008 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
49 people viewed this question
Top Washing Machines Experts
