Question about Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer
Washer is 8 months old. Three bad pumps
  • 725 Answers
I would call Maytag directly and ask them to replace this washer for you or have them provide FREE to you, at least a lifetime warranty on the pump and a five year warranty on the rest of the washer parts. Sounds like you got a lemon unless you wash lots of rugs or have a hair salon. If this is the case, you won't be able to get a new warranty, but if it is NOT the case, I'd take this all the way to the head of Maytag and they should make this right for you. I hope this turns out well for you, I'd like to know the outcome. The best of luck to you!
Posted on Sep 07, 2009
Washer doesn't agitate properly. clothes wrap around agitator
turn the machine over &inspect the belt.Get the make n model # of it &go to an appliance shop give them the #'s and take machine &prop it against the wall on a tilt &loosen the bolts that hold the pump on REMEMBERING where they go loook at the way the belt is positioned &put&match the new belt where it goes,its like a figure 8 around this place &around that place &carefully take the old belt off &attach it and then but the belt on the pump that u took off &take a bar &tighten the slack up on the pump.Install the boths and there u go try it and let me know. I did it once with a Maytag washer when I was 8 months pregnant and The washer is doing just fine.
Apr 06, 2012 | Washing Machines
What is F21 ON DISPRAY NEW 3HOURS OLD
LONG DRAIN F-21
If the drain time exceeds eight minutes, "F21" will be displayed,
the water valves will turn off and the pump will stop running.
Press PAUSE/CANCEL to drain the machine. The display will be
cleared and the machine will turn off after a maximum of eight
minutes.
Possible Causes/Procedure
1. Check the drain hose and make sure it is not plugged or
kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure
the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
clean the filter behind the front panel under the door, there are three screws along the very bottom of the cover remove them and pull the panel off, hope this helps
Some models have been reported to have bad pressure switches that will also throw this error. It is best to contact your vendor, and have the unit replaced or repaired under warranty.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 02, 2010 | Whirlpool Dryers
My 39 month old pump stopped working today. Can
Any dealer can repair it. These pumps have a long life.
Dec 03, 2009 | Grundfos MQ3-45 1 HP Pressure Booster...
GE washer will NOT spin, but does all other functions.
You need to have the fan belt checked. It must have been loose or broken.
Jul 22, 2009 | GE WSXH208A Front Load Washer
Pump is not starting to pump water out of whirlpool ultimate 2
I suggest you purchase a lid switch from a local supplier of parts or call a local servie tech if it's just the lid switch it should not take a tech long to change it.
Dec 19, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
After 4 months, water pump went bad
more than likely you have a foreign object jamming the water pump nickle dime quarter etc clean the pump out it should work fine if its 4 monthes old you can call for service but if its something jamming the pump its not coverd by warrenty
Mar 17, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE washer spins slowly -Clothes still wet
Doesnt make any sense why the motor goes off and on. If I read your email correctly. some typos on your email. but, sounds like the belt is too big. Or the spring device that keeps the belt tight is not working properly. You need to make sure what ever it is that keeps that belt tight is working properly or not damaged. The belt is very important to making the spin work good. Match it up with your old belt. The old belt will be slightly longer because of being stretched over a period of time. Get your unit number and model number and go to your nearest dealer and get the correct belt.
Sep 18, 2006 | GE WSXH208A Front Load Washer
Maytag Centennial 3.2 cu. ft. SuperSize Plus Top Load Washer Logo
221 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
