Question about Maytag Neptune MAH5500B Front Load Washer
Ld help code
Motor problem
    President:
  • 1,776 Answers
The fault code "LD" indicates "long drain" condition. It's not only if the water drained, but how fast it drained. Check the drain line for kinks or obstructions. Check the pump. Remove the hoses and use a flashlight to look into the suction port. Make sure nothing is clogging the pump (like the occasional stray sock) and check the pump impeller. Make sure there are no broken/missing blades and that the impeller spins freely. If there are broken/missing blades or if you can't get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged drain line, pump, or a jammed impeller. Sorry for your trouble and I hope this helped. Best wishes.
Posted on Sep 07, 2009
My washer will not drain or spin and I get the code ld but if u mess with the motor it will run again
check the wires going to the motor they could be broken or the plug for the motor could be loose
Mar 19, 2014 | Whirlpool WTW6400SW Cabrio Washer
Will not pump out water and getting CE, OB, and LD codes.
Hello, check the fuse on the motor control board and see if it is blown. If so, You could just have a bad board, but it may be a drive motor or pump motor. The most common thing is for the pump seal to leak into the pump motor and cause a short. The CE code means the 2 boards can not communicate with each other so be sure to check the wiring connectors between them.
Thanks
May 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
LD code and will not empty. I cannot find my manual
i believe the ld is for load dispersal so check you are not overloading machine
Dec 16, 2009 | Kenmore Oasis HE 27082 Top Load Washer
We have a Kenmore Elite Calypso, it is not washing
"Ld" (Long Drain) flashes
Is the drain hose kinked or clogged?
Press STOP/CANCEL to clear the display.
• "CA" or "Cl" (Current Limit)
Is the washer overloaded?
Here is a manual:
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0102048.pdf
See page 17.
Sep 15, 2009 | Washing Machines
Calypso washer - LD Code - clothes still wet
harborstuff,
The code on your machine stands for 'Long Drain'. Ld flashes if it takes longer than 5 minutes to pump out water to a point where the operating pressure switch resets. I would bet that the bath mats left a bunch of stuff stuck in the recirculation pump hose, or pump itself, and the water cannot be drained fast enough. Check the intake and exit hoses of the recirc pump. It's easiest to get to the pump through the front panel of the machine(click here). Looks like this: click here. Hope this helps.
(Definitely get under there and check to make sure the pump hoses are not clogged. At $129 it's an expensive fix for a $10 bath mat that clogged up the hose with fuzz. 'know what I'm sayin'' :o) )
-samson39
BTW, I have the maintenance manual & have experience at replacing the recirc. pump, control board, motor board, touchpad, & lid switch so far.
Jul 23, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Calypso washer gives error code Ld or ob. won't finish load or drain
Ld=Long drain. If it takes longer than five minutes to drain the water the operating pressure switch resets. Most common problem associated with this code is a clogged or failing water pump and hoses.
ob=Off balance. Open the lid and redistribute the clothes evenly around the tub, close lid and press the start button.
Jul 14, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Calypso: LD error message
hi replace the hall sensor... this will remove ur LD error code...
thank u
rate me!!
May 24, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
LD CODE BUT NOT PUMP
CHECK THE AREA MOULDED INTO THE OUTER TUB AT THE
BOTTOM BACK WHERE THE HOSES ATTACH TO THE TUB.
A FAVORITE PLACE FOR OBJECTS TO GET CAUGHT. IF O.K., CHECK THE ELECTRICAL WIRING FROM THE PUMP
MOTOR TO THE CONTROL BOARD. THERE IS A CONNECTOR BEHIND THE FRONT PANEL AT THE BASE. MAKE SURE THE PINS IN THE CONNECTOR ARE NOT CORRODED.
IF ALL IS O.K., REPLACE THE CONTROLLER FOR THE PUMP
MOTOR.
Mar 28, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Ricoh ap3800 error code sc261
Hi there the following is taken from the service manual. Thanks J
SC 261 LD HP sensor
not switched
off (for K only)
After the laser beam pitch was
changed, it takes more than
five seconds for the HP sensor
to switch off.
• Defective motor
• Defective sensor
• Mechanical problem
when switching the
actuator
• Brown fuse (FU81) on
the Power supply unit
1. Turn the main switch off and on.
2. Check the sensor actuator position of
the LD positioning motor.
3. Replace the LD positioning motor.
4. Replace the LD home position
sensor.
5. Check and/or replace the PSU.
Jan 14, 2008 | Ricoh Aficio AP3800C Laser Printer
HELP? ob & ld codes
Ld means long drain you probally have a bad water pump.Those models have a seperate motor for pump, the shaft on the motor is a star type and has probally stripped out the pump.Replace your water pump
Jan 03, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
78 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
