Question about Symbol MC9090 Barcode Scanner
I have a mc9o9o hand held computer once the windows based porgram starts I can not get back to the desk top or to the start screen is there any set of keys to press to get it to open?
    Novelist:
  • 75 Answers
It sounds like the Terminal has been setup to run an application from start up and then taskbar and menus locked so you are unable to break out of the software.
There is usually an admin break out built into software apps, be it the Wavelink TE application or a custom app. If you don’t know the passwords though you will be stuck.
What you will need is a few files and an SD card. You can then blank out the application folder and return the terminal back to defaults. The SD card slot is located under the keypad. You need to take out the 2 screws holding the keypad in place and pull the keyboard down and then lift it off.
Once the files are placed onto the SD card refit the keyboard and cold boot the device.
Please contact us for any other assistance
http://www.biastechnology.com
helpdesk@biastechnology.com
Posted on Sep 11, 2009
I have a dell Dimension desk top and when I turn it on it has both passwords set can some one tell me how can I open my computer with out knowing the pass words please??
Depends on the windows program if you are running windows and what version, i can tell you what f key to hold when it starts, sometimes entering admin as the password under default works if not need to either hold down f2 or f9 sometimes f8 just depends, they have to be held down while powering as soon as the startup screen apears go into the settings and turn off start up password set it to admin.
Mar 07, 2016 | Dell Computers & Internet
How can i adjust horazantal and vertical screen monitor size so i may fill full screen?
In Windows:
1) Click the "Start" button lower left hand corner of the screen, or the Windows key on the keyboard,
2) Choose "Control Panel",
3) Choose "Display"
4) Choose "Change Resolution", and select one that gets you where you want.
FixedYa !
Feb 25, 2015 | HP Desk Top Access Center DK985A
When I turn my laptop on the desk top with the start button and other icons together with material I have saved on my desk top are not shown. The screen is blank and black
reboot it in safe mode and if it shows desktop restart once again
booting in safemode hold F8 while restarting your machine choose start window in safe mode and hit enter
best of luck
if problem wont solve let me know please i will tell you another way
Aug 19, 2011 | Computers & Internet
My desk top comp was purchased in 09, the last couple of months it has kept getting slower and slower, green screens will apper and I will have to restart the computer. this past week it has been...
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On.
Let windows boot in Safe Mode and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->System Restore
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
After reboot login to windows and
Go to 'Start' and then Run
write "msconfig" inside Run tab and press 'enter'
inside the 'System configuration utility' window click on 'startup' tab then uncheck all the applications except your current antivirus and press apply then 'ok' and then 'exit without restart' option.
Now right click My Computer and go to properties tab.
click 'Advanced' tab then under performance menu click on 'settings'
go to 'Advanced' click on 'change' and increase your virtual memory to 2048 in both spaces.
Now restart windows.
To quickly restart windows press CNTRL+ALt+DEL
inside task manager you will find all the open applications.
right click on each application and click on end process tree then ok
Close all your apps like this and you will find your windows a lot faster and now you can reboot or turn off your windows as usual from start button.
Next time you login to windows your issues will be resolved.
If you feel that my answers have helped you getting solution to your problems then please give a vote.
Thanks.
Apr 11, 2011 | Computers & Internet
My monitor say out of range and no in put siginal be for this it said DVI disconnected. I can plug it into 2 other computers and it works. HELP
This problem is the screen resolution that your computer is set at. Start the computer enter safe mode, press and hold F8 as windows starts. change the resolution right hand mouse click on desk top, click on properties, lower the screen resolution, and re start. I hope that helps.
Jul 12, 2009 | Star Logic 17" LCD Monitor
Can't start windows normally and restore points will not work
Start in safe mode as you have been doing,Once you get to the desk top,Click start>Run>Type Msconfig and hit ok or enter,When the configuration window opens,Select start up Normal and click apply,The computer will restart in normal mode.
May 18, 2009 | HP Compaq Presario SR1538X (PX799AA) PC...
Get me to Windows PLEASE!!!
You can try different steps, lets try to walk through each one of them.
  • Have you tried going into the safe mode ? If not, do so :
To get to Safe mode, press the F8 key when Windows starts to boot. You have to do this BEFORE you see the first "Windows" screen.
Once you are in the safe mode, try to log in and see if this works. If so let me know so we can proceed to the next step.
  • If safe mode did not allow you to enter to the desktop, then do the following:
Insert your Windows XP CD and restart the computer.
The Windows Installation wizard will appear.
find an option "Repair...."
Click on Repair.
Note : IF CD is not detected automatically, you have to re-set BIOS configuration.
Press Del or F10 (depends) when the system starts and then set the Boot Priority.
Here make sure, CD drive is before Harddrive.
Mar 25, 2009 | Microsoft Windows XP Home Edition
My computer wont start up
First try pressing F2 at start up to see if you can get to setup. Also pressing F12 may get you a boot menu. If cd is already set as first boot you may get a chance to boot from a Windows cd. The idea here is to get to a minimal Windows configuration like setup or safe mode (F8) to see if this is a hardware or operating system fault. Two common issues with eMachines are power supply problems where repetitive reboots can actually fry the motherboard or if the PC has a few years use the CMOS battery. Steve Medley
Oct 30, 2008 | E-Machines eMachines Desktop PC
Symbol MC9090 Barcode Scanner Logo
528 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
