Question about Alfresco AGBQ-42SZ (NG) Grill
Ignition switch doesn't "click" or ignite gas inside grill. How is this repaired?
  • 388 Answers
If there is no "clicking sound", it is most likely the 9V battery inside the igniter button socket is dead. Take a look at this link: http://www.ajmadison.com/ajmadison/itemdocs/AGBQ-42SZ.pdf
..it should be an easy 1,2,3 replacement of the battery.
Posted on Sep 08, 2009
Why does grill ignition click when bottom oven lit
ignition probably serves both, if clicking when not lighting, fault or sticking button
Jan 04, 2016 | Stoves Premier 720GRa Gas Double Oven
Troubleshooting nexgrill charcoal gas grill
did you replace the battery in the igniter?
less than 100 degrees indicates a safety has engaged, close gas valve, open burner valves.....wait 5 minutes. keep lid open, close burner valves, open gas valve until you hear the regulator click
turn on "ignition burner" and ignite (with switch or at specified port).
After this part is lit open other burners one at a time , waiting until each lights before opening the next.
Dec 07, 2013 | Nexgrill Charcoal and Gas Grill Combo
Ignition switch does not click to ignite, battery is new
If you do not hear a clicking sound then the ignition module may be bad.
Jul 31, 2013 | Viking VGBQ410-3RT Grill
Where is the ignite button located
Hi phillzy21
If the main grilling burners don't ignite, try lighting them several times using the snap ignition. If that doesn't work, try using a match. In humid and windy conditions, sometimes the snap ignitions do not work properly. Make sure that the hood is fully open. Also, ensure that your gas is turned on and that the valve is fully open. Next, take out both the heat distribution plates and cooking grate. Turn the grill backwards, and hit the snap igniter a few times and look for a spark. If you see a spark, the igniter is working properly.
Bud
Oct 02, 2012 | Ducane Meridian 32 Inch 5 Burner Gas Grill...
Just bought summit s 670 natural gas 89208 grill. Bought a display model because it was the last one they had. It was already assembled, so I took it home as is. Everything works great - except....the...
To determine if it is the switch, remove the wires from the back of the switch and touch them together, if the lights come on, it is the switch. You will have to contact Weber for a new switch.
Jul 17, 2011 | Weber Summit S-670 Gas Grill
Ignition and gas problem
because main gas supply is distributed from a single point to various components,i suspect an obstruction in the oriface of your grill(probably a spider web).as far as ignition,most grill ignition systems are powered by a AA or 9 volt battery.try changing and see if you have ignition
Sep 15, 2009 | Pentair Minimax NT Heater
How to replace ignition switch
where does the ignitor switch plug into ? genesis ....came unpluged
May 21, 2009 | Weber Genesis Silver B Grill
Grill not lighting
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the push button igniter next to the burner control knobs on the front of your grill.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the grill has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck
May 11, 2009 | Weber Genesis E-310 Gas Grill
I HAVE A WHIRLPOOL GAS OVEN AND GRILL AKG667 MODEL NUMBER 853566715000 WHEN THE GRILL OR OVEN ARE SWITCHED ON THE FUSE CONTINUALLY BLEW. I CHECKED THAT THE CONNECTIONS WERE OK. NOW WHEN THE...
hi thanks for the question so the igniter works but no gas most of the gas stoves have the same problem if the igniter works but no gas could still be the igniter the igniter must get almost white hot to ignite the gas if id does not the gas wont lite so the ather problem is igniter lights but no gas problem is with the 2 coils on the gas valve replace those thanks the appliance doc
Sep 17, 2008 | Whirlpool Kitchen Ranges
Alfresco AGBQ-42SZ (NG) Grill Logo
409 people viewed this question
Top Alfresco Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you an Alfresco Grilling Expert? Answer questions, earn points and help others
