Question about Optoma MovieTime DV10 Multimedia Projector
Loud humming after turning on.
Loud humming when using projector with any source other than DVD play. Seems to get a little better when putting pressure on top left front area of machine. What could be causing the noise?
I have sort of the same problem...there was a loud snap(kind of electical spark like) then the unit started humming loudly which changes sound as you move the unit around. The picture remains clear and the fan is quiet in shut down mode...still the wheel you think?
Posted on Nov 02, 2009
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 149 Answers
Normally, loud humming in the speakers is indicative of electrical noise being picked up by the audio circuit. A common cause--with 2 separate pieces of equipment joined by signal cables, is a grounding problem(the cables act like antennas). Your projector is a DLP model...inside, there is an extremely fast-spinning color wheel(rotating disc that generates the color image). My concern is that the "humming" you hear is actually the color wheel rubbing on something--especially since putting pressure on the unit relieves the noise somewhat. Was the unit jarred or impacted? Sometimes, external cables can slightly flex internal boards(and space is tight in these smaller units) and cause things to touch that wouldn't ordinarily do so.--Just some thoughts---Rick
Posted on Sep 09, 2009
Hey Guys I have a Marantz PM493 amplifier and when trying 2 play the radio through the phono sockets all I get is a loud humming noise but if I turn the volume up very loud I can faintly hear the radio...
If they are marked "phono" then these are dedicated for the use of a turntable and one which will use a magnetic cartridge. You should use ones marked "tuner" or any marked "aux". Even a "tape in" would be better.
Aug 25, 2013 | Audio Players & Recorders
Ilo DVDR05 Vibration and loud humming noise
i experienced that problem before.one cause is the cd itself.there cd's that are too thick so the motor has hard time rotating that makes vibrating sound.the other ,don't put something over your unit.the cover is touching the holder of the cd and makes a sound.just do the necessary things to be done like don't put something on top your unit.if not, then a manual analysis of the tech is the last option.
May 17, 2009 | iLO DVDR05 DVD Recorder
Dell 3300mp Projector Loud Noise
Judging by the mains hum noise and now shaking it sounds as if a motorized component has broken.
Humming could have been the initial jam, then shaking the damaged part attempting to rotate.
Maybe check your cooling fan blades?
Dec 02, 2017 | Dell 3300MP Multimedia Projector
Screen flutters when playing dvds with loud hum.plays cds ok with no hum with cover closed an screen turned off.
Unfortunately, there is nothing you can do about a problem like you're describing. The unit needs to be repaired or exchanged. If you're still within the warranty period, (the original warranty from the manufacturer or an extended warranty you purchased from the retailer) contact the relevant party to arrange repair or an exchange.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may assist you better. If there is anything more I can do to help, I will!
Feb 04, 2009 | TruTech PVS12701 Portable DVD Player
Multiple Video Sources hooked to RT2600, but only DVD shows
I own the RCA RT2600 Home Theater System. I have never set it up, it has never been used. I have someone who wants to buy just the receiver and nothing else. I am wondering what you paid for just the receiver? I don't want to break up the system but I need money right now. I am open to suggestions as to what to do and how much to sell them for.
Thank-you
connally35@aol.com
Jan 17, 2009 | RCA RT2600 System
Technika FM In-Car Transmitter loud low frequency hum
This humming noise is the cause of a bad ground. try a new grounding location. The shorter the ground wire the better. Make sure the connection is metal to metal. I have had the same problem out of competition systems. Good Luck
Jul 20, 2008 | Car Audio & Video
Sound
Connect the projector to an external amplifier and speakers.
The speaker system built in is designed for watching movies etc in a small quiet room.
Hope that helps =)
Apr 11, 2008 | NEC VT491 LCD Projector
Epson Powerlite 1815p screen projector - DVD playback video jerkiness when there is motion in the video
I am assuming that the DVD plays normally on the display of the Dell 745.
Then the issue(s) may be with the:
1. Networking configuration/set-up of the Dell and/or the Epson;
2. ethernet cable;
3. configuration/set-up of the projector or the Epson itself.
A couple of things you can try:
1. Optimize your networking throughput.
1.1 Increase your PCI Latency Timer to 128 or 255 in the Dell's BIOS/CMOS setup (if present);
1.2 Try running DRTCP.exe and/or TCPOptimizer.exe appropriate to the Dell's OS;
1.3 Disable all other networking activities on the Dell. This may include auto updates, security/antivirus checks, etc. while running the DVD;
1.4 Slim down Dell's startup programs to bare minimum;
1.5 Increase your OS' swap file to roughly double your onboard memory
2. Try running a hub midway between the Dell and the Epson.
3. Verify that it is not the Epson that is problematic by playing a video source to the projector’s Video or S-Video port. If it is, then you have narrowed down the problem to the playing capability of the Epson.
Alternately if all else fails, perhaps you can try using:
1. a DVD player to the projector’s Video or S-Video port; and/or
2. a USB external DVD drive or a CompactFlash card (with a copy of the movie) direct to the 1815p
while settling the main issue.
Hope this be of help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Jan 07, 2008 | Office Equipment & Supplies
Toshiba #62HM95
I am wondering if this sound might be your color wheel spinning. The color wheel often makes a low humming noise as it spins. Try checking to see if this is not the source of your noise. You need the color wheel to generate the colors needed to turn the B&W picture generated by the DLP into a color picture.
Thank you,
Shuttle83
Nov 08, 2007 | Toshiba 62HM95 62" HDTV
Optoma MovieTime DV10 Multimedia Projector Logo
430 people viewed this question
Top Optoma Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
