Question about Nokia E75 Cell Phone
My E75 Navigation key sticks then freezes, it would not move.
Navigation key sticks, sluggish operation then it simply would not move at all. i did turn it in to Nokia so called Care center for the 2nd time within a week time with same fault not fixed. it is still there. i think it is a hardware problem with the NAV key button itself yet they say it's a software problem, we will see.
Frozen cursor
The only reason your cursor would "freeze" is your CPU is running at 100%. Press "control-alt-delete" keys at the same time and find the process that overloading the CPU and close it.
If you cursor never moves, your glidepad is broken. Do you have a "stick" to move your cursor? Many Thinkpads do. Usually have a red cap on it and is located near the b g h keys. If the stick doesn't work either, it's the overloaded CPU problem.
Oct 24, 2013 | IBM ThinkPad T42 Notebook
The navigation keys on my nokia e75 hangs, how can i rectify this issue please?
Try resetting the phone, but first reduce the load on your memory card. Note that every phone has its own memory limit, just like computers, ok?. Now, on idle screen of your phone, type: *#7780#.Take care. Obinna
Mar 22, 2011 | Nokia E75 Cell Phone
I have a E75 handset since Oct 2009.I am facing aproblem since this morning that the phone is hanging ( screen not responding and does not take connection).I removed battery couple of times to check..still...
If your phone not responding, I think you should reset your phone. But before you do this, make sure you have put off your SIM and memory card from the phone, and make a back up of your data.
There are three steps of resetting the phone :
Nokia E75 Soft Reset:
This option restores the .ini files from the ROM.
Does not erase data (photos, videos, documents) nor applications from a third party. Key Code *#7780# (click this combination of keys on the keyboard in the mobile)
Nokia E75 Hard Reset:
This option restores the original operating system from the ROM.
Formats the C: partition and deletes all data including the memory card. Key Code *#7370# (click this combination of keys on the keyboard in the mobile)
You can also achieve Total Reset by pressing and holding down following keys: * + 3 + Green Button (call) immediately after turning the mobile on.
Note: To proceed to reset, the battery must be full and the
mobile device connected to the charger. If during the course of reset, the mobile stop receiving electricity it can ruin the internal flash memory of the mobile device and stop function.
Or you can check this sites :
http://anythingnokia.com/nokia-tips/nokia-e75-full-reset-soft-reset-and-hard-reset/
http://discussions.europe.nokia.com/t5/Eseries-and-Communicators/Reset-E75-using-7370/m-p/540002
Hope this help and be kind to rate this answer, thank you.
(^_^)
Jan 07, 2011 | Nokia E75 Cell Phone
My nokia e75! How to move some data from c phone memery
sir go to file manager and select phone memory and select the data to move and press options and select organize and click on move and select the desired location.
Dec 04, 2010 | Nokia E75 Cell Phone
Nokia e75, a few keys on the front keypad does not work
i have n75 phone key pad up down sides key not working pls help
Nov 13, 2010 | Nokia E75 Cell Phone
I have a nokia E75 and i cannot hear anything through the earpiece but it works on loudspeaker
Full format solution for NOKIA
Switch-off your phone. 1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
Mar 10, 2010 | Nokia E75 Cell Phone
How do I use a micro sd card to save photos?
Before doing the steps pls format the memory card first
To transfer pictures to memory card follow the steps below:
  1. Remove the memory card slot cover, located on the upper right side of the handset
  2. Insert a microSD memory card into the memory card slot, until it locks in place
  3. From the standby screen, press the left soft key for Menu
  4. Select My Stuff (7)
  5. Highlight Graphics, using the navigation keys
  6. Press the left soft key for Options
  7. Select Open (1)
  8. Highlight desired Photo, using the navigation keys
  9. Press the left soft key for Options
  10. Select either Move (4) or Copy (5)
  11. Select either Selected (1) or Multiple (2)
    • If Multiple, highlight each Photo, using the navigation keys
    • Press thecingular%20logo%20only.jpg key to check each Photo’s box
    • Press the left soft key for either Move or Copy
    • Highlight Memory Card, using the navigation keys
    • Press the left soft key for Select
    • Highlight the Graphics folder, using the navigation keys
    • Press the left soft key for Options
    • Select Paste to selected folder (2) to Move or Copy the Photos to the microSD memory card
  12. Highlight Memory Card, using the navigation keys
  13. Press the left soft key for Select
  14. Highlight the Graphics folder, using the navigation keys
  15. Press the left soft key for Options
  16. Select Paste to selected folder (2) to Move or Copy the Photos to the microSD memory card
  17. Remove the microSD memory card from the memory card slot
Oct 19, 2009 | Samsung SGH-A707 Cellular Phone
Sluggish Analog Response
How about changing your controler settings, you can do this in the settings menu
Nov 08, 2007 | Microsoft Xbox 360 Console
Nokia E75 Cell Phone Logo
411 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
