Question about Suncast Garden
It sputers and the plug has dark soot or resin
  • kevin846
    kevin846 May 11, 2010
    Is this the Briggs & Stratton sprint engine?
  • 389 Answers
CHANGE YOUR AIR FILTER
Posted on Sep 16, 2009
The barcode on the label is not clear
  • Clean the Printhead
  • Check Ribbon : Wax, Wax+Resin, Resin
  • Check Label : Material : Paper or Polyester
  • Increase darkness
Oct 21, 2014 | Zebra Zm400 Thermal Label Printer
Truck sputers when starting when truck plug in does not sputers
its because its cold with it plugged in it stops because it keeps the block warm which helps with the cold starting
Jan 11, 2014 | 1997 GMC Sierra
I have a brand new zebra tlp2844 I have set it up with a resin ribbon, the print quality is very poor and patchy why is this ?
There are a couple of possible solutions.
1/ Resin ribbons are meant to be used on synthetic labels onle ie vinyl or polyester. If you are trying to print on paper labels then you will get a rubbish print. you need to use either a wax ribbon or a wax resin ribbon.
2/ If you are printing onto a synthetic labels and the print is light, try increasing the "print darkness" some times called contrast or heat or printhead setting.. This can be fount in the printer set up in the labels software you are using or in the print drive under "Print Preference"
Dec 16, 2012 | Zebra TLP 2844-Z Thermal Label Printer
HI, our Zebra 4m+ is currently set to a Darkness of 30 as that seems to eb th eonly way it will print enough detail on the label. We have tried adjusting the pressure settings to no avail. Now we are...
Full resin ribbons tend to require higher darkness settins on all thermal printers.
It could be a mismatch between label and ribbon. This would need to be looked by your supplier.
May 25, 2011 | Zebra 105SL Thermal Label Printer
89 Mazda 323 is Sputering
it could be many things. fuel pump, air filter, breather filter, pvc valve, bad spark plug, plug wires, o2 sensors, just to name a few.
Sep 22, 2009 | Cars & Trucks
Spits an sputers
start with the timing.plugs wires cap and rotor.
Jun 12, 2009 | 1990 Ford LTD Crown Victoria
Temp is set at 28. printing on mylar black mark.Speed is factory setting I believe at 2 print is blurry and not dark. Using resin ribbon
I haven't tried yet but after doing extensive reading feel that the problem is in the ribbon type. I thought it was a resin wax blend but it was one that I had for awhile without any label on it and I'm thinking it may be just a wax and that is why it works on white labels but not on the poly or mylar.
Jun 03, 2009 | Zebra S4M Thermal Label Printer
Soot all over Older Ionic Breeze Quadra
Hey, if you read the instuction manual : the DON"Ts section-you will see that candles, scent producing products,cause a lot of soot in these cleaners. If you burn scented candles, or use anythind that generates airborne odors, you will need to clean the system more frequently ( every 2-3 days).
I clean mine every week-no matter what.
One of the postings, talked about a : Monthly cleaning that was performed.
You've guessed it. The thing died-arced out.
So, extra odors kill these filters.
Jan 25, 2009 | Sharper Image Ionic Breeze® Quadra® 4.0...
Black soot/film in dryer
Is this a gas dryer. If so, check the burners. It could not be combusting properly. The valves may be dirty. Get them cleaned by a professional or someone who is familiar with cleaning gas orifices.
Jan 03, 2009 | Maytag PYE2300AY Electric Dryer
Garden Logo
57 people viewed this question
Top Suncast Garden Experts
Dennis Key
Dennis Key
john h
Are you a Suncast Garden Expert? Answer questions, earn points and help others
