Question about Whirlpool Dryers
Whirlpool lg9521xt gas dryer- no heat or flame. I replaced thermal fuse and coil kit, but didn't solve problem. What's next ? The igniter ?
  • Whirlpool Master
  • 1,606 Answers
Remove the bottom panel and start dryer . If you see the red glow , then ignitor is ok . Disconnect the plug (2 or 3 wires ) going to the burner and check for 120 volts . If no red glow , replace the ignitor pt # 279311 . If not 120 volts , then , normally , thermal fuse is bad (white piece with 2 small terminals on blower box ) is bad .
Posted on Sep 07, 2009
Testimonial: "thanx, i have a VOM so i'll check it"
Gas maytag dryer not heating up
check the thermal fuse in the dryer vent duct to be open,then if not the flame eye" radiant sensor" or the high-limit thermostat both on the burner tube if the sensor doesn't see(sense) a flame the gas valve will stay shut,then check the gas valve coils,both the BOOST and SECONDARY coil valves on the gas valve body as these can open up and not gas into the burner
May 04, 2010 | Maytag Neptune MCG8000AW Gas Dryer
HOW CAN A DRYER IGNITE A FLAME AT FIRST FOR TEN MINS THEN WHEN THE DRYER WANTS TO HEAT UP AGAIN I SEE A GLOW BUT NO FLAME COMES THE SECOND TIME SHOULD I REPLACE THE THERMAL FUSE
No you should replace the coils. 3a3915a.jpgWhy? You know you are getting power to the gas assembly so that means the fuse and control are functioning. The igniter glows so that is good. The Flame detect is fine because it shuts down the glowbar when it heats up. So those pesky coils get hot and quit. They eventually cool back down and work a little more, very aggervating to diagnose but easy to fix.2b3709e.jpgNote you do not have to remove the gas assembly to replace these coils.
Apr 23, 2010 | Whirlpool Dryers
Dryer will not heat gas
Check the following areas to combat this issue. the most common problem spot will be a blown Thermal fuse.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Oct 28, 2009 | Whirlpool GGQ8831L Gas Dryer
I have a lgr4634jq1 gas dryer flame wont stay lit runs but no heat
1. Gas valve coils
2. Thermal fuse
3. Igniter
Sep 09, 2009 | Whirlpool Dryers
Whirlppol model LGV6634BWO gas, no heat
1. Gas valve coils
2. Thermal fuse
3. Igniter
Jul 26, 2009 | Dryers
Hello, My fairly new whirlpool gas dryer does not heat. I replaced the thermal fuse a month ago and the heating problem was resolved, now no heat again, thermal fuse was tested good. The igniter will turn...
Hello Friend, Your problem is very simple to fix. You're dryer needs a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new. Happy to help, Tim.
Jun 14, 2009 | Whirlpool Dryers
Gas Dryer does not continue to heat.
Check the Following to address this issue--
1. Gas valve coils
2. Thermal fuse
3. Igniter
Jun 02, 2009 | Whirlpool Dryers
No flame but igniter cycles
If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
May 28, 2009 | Dryers
Dryers Logo
167 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
