Question about Yamaha RX-Z9 Receiver
Yamaha rx-z9 can not get digital audio
My z-9 is not working properly all of a sudden. I can not get any sound from any of my optical inputs...the z9 is stuck in analog....I tried to switch to auto but it keeps saying analog..and the only speakers lit on the display are the right and left
Have You ridden the manual? There is a special procedure to assign the priority order.
Posted on Nov 20, 2012
  • 141 Answers
If your receiver is saying you only have analog, it must not be able to see the optical input. Check your optical cable, maybe it is damaged or not tight.
Posted on Sep 05, 2008
All of a sudden I have no sound at all regardless of what the input is. Any thoughts or has it just died. I've had this for many years.
RX-V540 - RX-V - AV Receivers - Audio & Visual ... - Yamaha > ... > AV Receivers > RX-V
Yamaha CorporationRX-V540. Discontinued. Natural Sound Home Theater Receiver. 0.0. (No reviews) ...The RX-V540 is a full-featured home theater receiver ready for all formats. .... their favorite stations or to have musical genres, such as all the jazz stations,
No sound on yamaha rx-530 stereo fm receiver - Fixya
Feb 13, 2015 - no sound on yamaha rx-530 stereo fm receiver nothing,just no soundcomming out of speakers ... Does your TV have any audio outputs such as RCA perhaps? .... Suddenly no sound is coming from my speakers except for my subwoofer. On certain settings some of the speakers work but not all of them.
Jan 12, 2016 | Yamaha RX-V540 Receiver
Zone 2 is mute with optical input
You can't use a digital input in zone 2. Only analog inputs can be used.
Jan 20, 2014 | Yamaha RX-V659 Receiver
The sound level from analog input is very low, good quality but low, optical connections work well. Have checked cables, tried all the analog input jacks with same result.
test analog input with another receiver ,if it comes out same low , good quality sound level ,then issue/problem is on input source not on receiver. Sometimes the way source audio was recorded causes these issue on high quality receivers...
Dec 28, 2013 | Sony STR-DE845 Receiver
Hi. I write from spain. I have the blu-ray LG
Have you tried the another optical cable? They don't tolerate dirty connections or small-radius bends in their routing. THAT (and the expense of optical cables) is why I always choose coaxial connections when possible.
Mar 02, 2011 | Yamaha RX-V363 Receiver
RX-V461 Yahama Receiver is hooked up to TV with optical THX cable but can't get sound. Tuner on receiver plays and all speakers work perfectly for radio listening.
double check input used on amp and make sure u use the auto format decoder fuction on your amp ok if it has none than turn it on optical digital ok that should work for you :)
Feb 10, 2011 | Yamaha RX-V461 AV Receiver
I have audio cables going from HD 61g887 jvc tv, to my phillips surround sound system under aux but it is not giving me sound?
you didn't mentioned the model number of your surround sound system, for a better solution its important. any why try the following.
if you are connected the analog audio output of your tv to the system using RCA cable, then go to the setup of the surround sound system and change the input assignment setting from digital to analog.
If your connected the digital output of your tv to the digital input of your surround system using optical cable then, goto the setup of your surround system and change the input assignment to digital (optical) input.
if u need any further assistance fell free to contact through fixya
Jan 20, 2011 | JVC HD-61G787 61" Television
Need help connecting to surround sound to a vizio sound bar
did u mean connecting the sound bar to ur tv.
u didn't mentioned the model number of ur sound bar.
any how ur tv has only coaxial digital audio out. no analog audio out. the sound bar may have one digital audio input (optical digital input) and 2 analog inputs. if it has coaxial input it may be very easy.find is there, if not u cant link these devices.
if u are using a satellite receiver then u can connect the optical audio out to ur sound bar's optical input or the analog audio output to any one of the analog audio input.
Dec 18, 2010 | Emerson LC320EM9 32 in. LCD HDTV
No sound when connecting optical cable from set top box to #4 optical input for cable tv on rear. The cable only works from the front input or the dvd input on the rear but that limits my sound fields. I...
Make sure your "Input Select" "Audio" portion of the main menu is set to "Auto" you may have it in analog thus only allowing audio from the front analog input. Also check your digital input select option as well. you may have it assigned to another source input. Go into the main menu of the receiver and you will find all the settings. Hope this helps. If you still have issues, post a comment and I can help you troubleshoot further.
Feb 26, 2010 | Yamaha HTR-5760 Receiver
Optical audio not working
Two inputs on this receiver (DBS and DVD) can be either optical or analog... (e.g. RCA type stereo connectors) Use the Analog/Digital button on the remote to set the proper input type for the desired input.
Feb 09, 2010 | JVC RX-D202 Receiver
Yamaha RX-Z9 Receiver Logo
234 people viewed this question
Top Yamaha Audio Players & Recorders Experts
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
