Question about Cell Phones
Nokia 6103 ,I can not hear ring tone,but I can see a blinking light,how do I turn on the ring tone a shut off the blinking light so I can hear?
My nokia e73 stopped alerting me when I get a text. the light will flash when I get a text but there is no sound. My cell rings when people call, I made sure that in settings>tones my message alert is...
for it to make noise try deleting all of ur mesages from ur inbox and out box. For the blinking to blink longer gp to ctrl panel-settings-general-personalization-notification lights-notification light-blink for-select no limit
Jun 25, 2011 | Nokia E73 Mode Cell Phone
Where or how can you turn your ringer volume up or down
Hello Hank,
When you make call use the left and right square key for increasing or decreasing volume.
Apr 15, 2011 | Nokia 2600
I have Nokia 1661-A and model: 1661-2b. When
I had the same problem with mine. when I would go to tone settings every time I tried to hit ring tone it would turn off the phone and restart, by the way in ring tone it was blank. No matter what I did it wouldn't work. So I went to settings then restore factory settings entered the code. It reset the factory settings, then when I went back to tone settings the ring tone said Nokia Tune so I hit enter and it gave a list of all other ring tones, then it worked so my phone finally rings.... Hope it works for you.
Mar 23, 2010 | Nokia 1661 Cell Phone
Select Ring Tones, it shuts off and turns on asking for sec code.
take battery and the sim card out for at least 20 min. should help
Sep 04, 2009 | Nokia 1661 Cell Phone
Nokia e50 wont notify me when i recieve a new text message
Hello there! thanks for using Fixya.com!
Try the following instructions, to personalize your Nokia E50!
Profiles
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
groups.
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
Ringing type — Select how you want the ringing tone to alert.
Ringing volume — Select the volume level of the ringing tone.
Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
Feb 15, 2009 | Nokia E50
Nokia 6103 Keypad light will not shut off
ok man,.. it's a hardware failure,, can't fix it here,. ur fone is grounded need repair your keypad module, some capacitors are busted so there is no switching point to control the lights .. go to service center...
Apr 17, 2008 | Nokia 6103 Cellular Phone
Keyboard light won't shut off
Remove and clean sim card. Replace and check. IF not cleared report to mobile phone engineer.
Mar 20, 2008 | Nokia 6103 Cellular Phone
Phone not ringing
Just recently the Innovage LED touch screen phone stopped ringing. It has worked perfectly as a home office phone since Oct. 2005. Cannot find anything in the tiny manual to correct this problem.
Dec 26, 2007 | Vtech VT-9118 Cordless Phone
Cell Phones Logo
61 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
