Question about Frigidaire GLTF2940ES Front Load Washer
Machine is leaking water from bottom - Frigidaire GLTF2940ES Front Load Washer
Check rubber bellow.
Posted on Sep 10, 2009
My Espresso Machine leaks out the bottom
thier is a puddle of water that leaks out of the bottom of machine after i brew my expresso
Dec 29, 2012 | Mr. Coffee ECMP40 Espresso Machine
Admiral washer leaking water from bottom
What is the model number of the unit?
Nov 24, 2012 | Admiral Washing Machines
Water coming out of the bottom of the machine
Sometimes, what may seem like a washing machine leaking from bottom locations is actually one that leaks slowly from other spots. Slow leaks can accumulate beneath your washing machine making it seem like you have a bottom leak. For more help identifying the exact point of the leak, see Washing machine leaking.
Bottom leaks may be better identified using a newspaper. Just dry the floor and lay the newspaper beneath the washing machine before you test for leaks. Darkened sections map out your water leak. This method is not always foolproof, however. The best diagnosis will come from a qualified service professional inspecting your machine.
If your washing machine is leaking from bottom in the rear, you may need a replacement pump and professional installation. The leak could also be caused by a faulty air dome seal or a hole in the tub. For more troubleshooting steps to tackle that leak, see Washing machine leaking from bottom. I hope that helps!
Sep 27, 2012 | KitchenAid KHWS01PMT Front Load Washer
Washer leaks out the bottom in rear of machine
Thank you for using FixYa. Does water leak out of the machine from the beggining of the cycle to the end? If it only leaks when spinning or Pumping out water and water comes from the rear bottom of the machine? This is where the drain pump is located and I would say that the leak is coming from there---either a perished hose or a loose retaining clip.
Mar 16, 2011 | LG WM2101H Front Load Washer
Water leaking from bottom ofoasis top loading machine
you may not be leaking out the bottom. Your stand pipe may be clogged. If the stand pipe has a slight clog in it, the stand pipe will over flow, and the water "looks" as if its leaking from the bottom... These pump faster than your old machine, so the pipe will back up faster... hope that helps
Jul 31, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Maytag top load washing machine leaking water from bottom
The machine is leaking water from the bottom, I think the leak is in the area near where the motor is mounted. Before we noticed the water comes from underneath the washer, we smelled like burning rubber.
Al Bana
Jun 26, 2009 | Maytag PAV2300 Top Load Washer
Washing machine is leaking water
hi there,
possible leaks can came from mehcanical shaft seal,of agitator shaft and pulley.if worn out
water leak on bottom of machine.
also on water pump inside machine,there is
also mechanical shaft seal within pulley and shaft of impeller blade.worn out also can cause leak at bottom.
maybe on inlet valve of hot and cold water
improper mounting or loosen lock cap on valve
leak can appear.
replacement of shaft seal are lots of work to do in pulling this out,but can be repair depend now on you.how you do it,this should be done by washing machine technician.have a nice day.don;t forget to rate me.thanks a lot
Apr 29, 2009 | Washing Machines
Coffee maker leaking from bottom
I have had a few of these machines leak.
I pulled off the bottom and found Mr Coffee is using low quality tubing that melts or leaks where it attaches to the heater element that boils the water. I replaced the tubes with higher quality silicone tubing that I bought directly out of China on Ebay and the problem was solved.
Dec 26, 2008 | DeLonghi Caffe Nabucco BCO70...
GE Top load washer.
Hello rschneeweis
Welcome,
Sounds like a seal or drain hose is leaking or the clamp on a hose has vibrated loose.
Water leaking out the bottom of the machine when washing machine begins agitation cycle. If the machine is turned off the water stops leaking even with the tub full of water.
Let me know if you found it and how you do.
Huuum
Please remember to leave a rating
Oct 04, 2008 | GE WBSR3140D Top Load Washer
Washer is leaking water at bottom
You should look at the machine's bottom first- try to find out from where water leaking from. In most cases it is the pump.In such a case it should be replaced. Good luck!
Jun 14, 2007 | Frigidaire FEX831CS Top Load Stacked...
Frigidaire GLTF2940ES Front Load Washer Logo
52 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
