Question about Dell Dimension E520 PC Desktop
I have a dell dimension e520 and I just bought a wd 320 gb sata hdd. When I want to install xp it stops before the welcome to setup screen and it gives me a blue screen help please
  • jhmpc09 Sep 07, 2009
    the thing is an internal sata hdd sooo.. and it stops when it says: "Windows is starting" or somethhing like that itdoesn't gve me options to format or nothing thank you for responses
  • jhmpc09 Sep 08, 2009
    bob computer where can I get thos dos sata drivers?
  • 3,153 Answers
The blue screen you are seeing is probably not the regular BSOD (blue screen of death)
Wat you need is the DOS SATA drivers for your adaptor on floppy or some other suitable form (USB formatted as a floppy)
I think you may have missed it but as the XP CD is booting at the bottom of the screen was a message that said "press F6 to install additional storage drivers"
You should have hit F6
In a little while it will then ask you for those drivers and you just point it at the floppy or other device set to act as a floppy.
Now it will load them and let you continue setup.
otherwise it will quite often fail as it may no know how to find the SATA drive.
Posted on Sep 07, 2009
  • Project NOMAD
    Project NOMAD Sep 07, 2009
    OK in case we got the wrong end of this (which i suspect we did)
    you have done the install with no problem?
    It is only on a regular start up that this appears ?
    If this is the case you may want to try safe mode boot options and try update any drivers whilst in safe mode. You may have to restart more than once.
    Also on some BIOS there is a SATA / IDE option that allows windows to think it is seeing an IDE drive. If you have any such option switch it. This type of option is available on some dell laptops and can be the only way to get XP fully running before changing it back to true SATA
    The option name itself escapes me but at least you have a little more to go on I hope.
    Scholar:
  • 121 Answers
Make sure you perform a full format if you dont have dual boot, followed by continue installing windows if it stuck, let me know.
  • Manish Choudhary
    Manish Choudhary Sep 07, 2009
    Try this out..
    Restart your computer and keep tapping F9 or look at the screen.... does it tell to press a key to go to boot menu -- if it does, press that key, it may be F2,F5 and so on. The moment you go in there use up and down arrow key to choose boot menu option and make it to CD ROM(It'll guide you). After making the necessary changes save it and restart your PC with the XP/Vista disk in and after a while it'll ask you to press enter to setup...
    Hope this helps.. let me know the status if you need any more help !!
    Thanks
  • 79 Answers
Before you get to the welcome screen, select the text option to delete the selected partition, then choose to format it in NTFS (not the quick option). The problem is that the computer can't recognise the hdd in it's current form - it need formatting by Windows as above.
Hi i bought WD 320 gb sata /8mb hard drive - the cable ribbon on my dell 4600 does not plug into it! do i need a different cable yes
Generally speaking, we have two types of hard disk interface. IDE (the old one with ribbon cable) and SATA (with a 1cm strip like cable).
As your new hard disk is SATA, you need a SATA cable to connect it to you PC.
Below are a few images which would help you.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Sep 23, 2011 | Western Digital WD Caviar Blue WD3200AAJS...
Hello, My my motherborad is ASUS p5rd1-vm;RAM1GB and hard disk is PATA 80 GB but the HDD is having some kind of problem and the windows have shown a warning about it several times. Now i want to buy a...
Yes, it's compatible with the motherboard, no, it's not compatible with the XP install disk because it doesn't have SATA support. And since Asus doesn't provides it special driver needed (one that must be put on a floppy) it means that you simply cannot install XP on this disk.
All you can do is to obtain another PATA hdd what ever its size and install XP in it. Then put the new SATA disk in and use it to store all the installed programs and all your files on it. As a bonus you won't lose them if the new PATA disk fails or XP gets corrupted.
Or install Vista or 7 instead of XP, the have support for SATA disks
Jul 28, 2011 | ASUS P5RD1-VM Motherboard
I have a Desktop comp. DELL_Dimension E520. I
You should download the drivers BEFORE you change the OS and maybe put them on a flash drive or burn them to a CD.
You can get them direct from the DELL site.
It maybe that your XP disc does not recognise a SATA drive and for that reason you should use the F6 option whilst booting from the XP setup disk and point it to the CD or flash drive.
From then on you should be able to format the disck.
Some of the dells are a little tricky that way.
You may also have to change the bios option as for sata type
I have had to do this on a few dell laptops.to down grade from vista to XP
May 28, 2010 | Dell Dimension E520 PC Desktop
Laptop shows only 4gb ram & 300 gb hdd
This is the limitation of a 32 bit (x86) Operating System. A 32 bit OS can detect upto 3GB RAM only.
You may either try installing the x64 Bit of XP Operating System or Vista Service Pack 1 or 2 for 32 bit Vista Operation System to resolve the issue.
After installing the SP 1 or 2 of the Vista OS in the Computer, the OS will detect 4GB RAM.
Good Luck!!!!!!!!!!!!!!
Oct 12, 2009 | Acer Computers & Internet
Windows can't install because it says it can't find a hard drive. Setup indicated both HD's are there and working. Installing Windows 2000 from Disc. Changed boot sequence so Rom boots first. Windows loads...
Check for sata drivers, if it is system is shipped with SATA hdd, need to install SATA Raid drivers during reinstallation .I believe that the dell system was originally shipped with Windows XP or Vista Operating system which has SATA drivers for SATA hdd. Since windows 2000 Operating system does not have SATA drivers hence unable to recognised hdd.
Aug 17, 2009 | Dell Dimension 9100 PC Desktop
Dimension 4700 with Barracuda 500Gb SATA HDD
You have to go online and search then download the drivers for preparing SATA laptop harddrives for installation of Windows XP otherwise during installation it will tell you there is no hard drive found.
Dec 12, 2008 | Dell Dimension 4700 PC Desktop
Dell Dimension 5000
you problem is most likely that your bios is out of date. download the latest bios updates for your motherboard and then when you install windows format you HDD with the ntfs system (using the long formatt system not the quick format). Then you should install the bios update. then your mboard shoud no longer have the problem of recognising your large capacity HDD. thanks
May 18, 2008 | Computers & Internet
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Dell Dimension E520 PC Desktop Logo
489 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
