Question about LG WM2277H Front Load Washer
LG DWD11151FB washing Machine problem
The machine stops and will not start **** a SE sign occurs in the display
geemarie
  • 876 Answers
SOURCE: Error code SE on LG washing machine means what?
It probably means System Error. Have you tried a simple reset. Pull the machine away from the wall carefully, make sure you do not have wet hands or feet, etc and unplug it from the wall. Leave it unplugged for 20 minutes. (Also check to see if it is plugged into an outlet with a little red button on it? is the button pushed in? It should be? ) After the wait, plug the washer back in and see what you have. I hope this helps.
Posted on Aug 15, 2008
SOURCE: LG washing machine error codes
I have today the same error code on model WD-11155FB. This code means that the speed of the electrical motor can no longer be controlled. The velocity sensor placed just behind the motor is probably damaged but it can be also the electronic board where is connected this sensor, or the wiring between these two items.
Posted on Aug 16, 2008
Brussels
  • 16 Answers
SE is a sensor problem as per LG support. I will post a follow up after I have recieved the technician in 2 days
Posted on Nov 03, 2008
SOURCE: Machine stops with SE code
That code (5E, not SE) means the drainage is clogged. The code appears after 15 minutes of trying to drain the tube (not sure that´s the word, may be turbine, barrel...). check the lateral filter (a big plastic twist-off cap) for any solid that may be clogging the drainage
Posted on Mar 21, 2009
SOURCE: LG washing machine keeps stopping and it says OE
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. Check the exit hose, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Posted on Apr 11, 2009
Machine displays UE when spinning and turns off the machine, this occurs even when the machine is empty
UE means uneven for LG washing machine. Could you please using water level to make sure it is level. May I know if the drum is stable while spinning by not giving any banging sound. Used to happen to my LG direct drive, and solved by replacing the suspension that supporting the drum holder. Now all good like new.
Dec 24, 2013 | LG Washing Machines
Washing machine SF-110LJ sign Fd on display
My washing machine Model SF-110LJ does not working and show Fd on
display. Please assist.
Nov 30, 2012 | LG Hitachi Washing Machine Lint Filter...
LG WD-14401TB SE error code
the motor position sensor or the hall sensor part number is
6501KW2002A
May 05, 2017 | LG Washing Machines
Flashing SE when switched on
SE=System Error.
Turn the machine off and unplug it from the electrical supply for about half an hour, this normally forces a machine reset.
If it fails to cure it or if the problem recurs then you'll need a specialist Samsung washing machine repairer to diagnose and fix the fault.
Jul 06, 2009 | LG Washing Machines
Error code se
can you check the temperature sensor , i know thats not the same fault , the fault to the sensor is be but check the sensor , at the bottom of the tub between the heather connections
Jun 18, 2009 | LG WM-2277HW Front Load Washer
What does SE mean on my LG Intellowasher 7kg WE-8074FHB display
Error SE is a sensor problem as per LG support.
you need to change the senser of your machine...
Good Luck!!
Mar 22, 2009 | LG Washing Machines
WD8074-FHB washing machine SE on display
LG washing machine error code SE indicates a “motor fault” although the code also says it could be a main PCB fault.
They recommend to... “try the motor first”.
It’s vague and you really need an engineer to try and sort this one.
You can’t possibly justify “trying the motor first” if you are a DIYer unless you at least know how to test a motor for faults and check its connections.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 26, 2008 | Washing Machines
Oct 19, 2008 | Washing Machines
May 22, 2008 | LG Washing Machines
LG Washing machine - Front Loader
Suggestion: Check your outlet filter, it could be blocked. I looked for this SE could not find it.
Jan 15, 2007 | LG WM1812C Front Load Washer
LG WM2277H Front Load Washer Logo
70 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
