Question about Kenmore Food Mixers
Old Kenmore mixer beaters broken
Our old Kenmore mixer has stopped beating... Machine runs but the tabs that hold the beaters in place have all broken off (broken off at the beater where it is inserted into the power head and engages the pin that drives them). {Operator error, or just very old and didn't notice before that tabs were nearly all gone}
Need to find replacement beaters, any ideas?
JB
    Top Expert:
  • Kenmore Master
  • 44,073 Answers
Fixya does not sell replacement beaters and does not recommend sources.
Posted on Jul 24, 2017
  • 274 Answers
SOURCE: Replacement beaters for hand mixer
Black and Decker now has several store outlets all over the country. They are even online. You can order directly from them. 1-800-544-6986
Posted on Jul 15, 2007
SOURCE: bravetta mixer
Call Euro-Pro Operating LLC at (800) 798-7398
Posted on Dec 04, 2007
  • 3 Answers
SOURCE: replacement beaters
See solution for Euro-Pro EP546 replacement beaters. Call them at 800-798-7398.
Posted on Feb 06, 2008
jerryg50
  • 1689 Answers
SOURCE: lost beaters
Toastmaster factory parts
http://abtecparts.com/toastmaster.htm
Jerry G.
Posted on May 29, 2008
I called west bend about mixers for my stand mixer.Model number 41036. They said this model has been discontinued and they could not help at all!!!
Posted on Oct 20, 2009
Can I get parts hot kitchen aid hand mixer model khm7twh beater won’t stay in because plastic tabs are broken that hold the beater in
Hello, Joe -
From a post on a YouTube video demonstrating a McGyver-type fix to a damaged beater ring (the plastic piece which holds a beater in place) apparently KitchenAid has discontinued the availability of the beather ring.
This is the link to the YouTube video with the McGyver-type repair demonstrated:
https://www.youtube.com/watch?v=CmS4FbROS50
The comment about the discontinued beater ring is from Dan Peters.
See the information here from KitchenAid:
http://producthelp.kitchenaid.com/Countertop_Appliances/Hand_Mixers/Hand_Mixer_Assembly_and_Operation/Beaters_fall_out
If you decide not to try the McGyver-type repair and choose to purchase a new hand mixer, you may wish to put the old mixer up for sale, to be used for repair parts (since it still has 1 good beater ring.) Or, you can send the old mixer to electronics recycling.
Best wishes.
Feb 27, 2018 | Food Mixers
K45 kitchenaid mixer quits working under load? When beating egg whites it works great but try to cream butter and the beater stops.
It will be a broken or missing pin through a gear or the planetary or something wrong with the fuse gear. It should be easy enough to find but you will need to split the gearbox cases to check.
Sep 17, 2014 | KitchenAid K45SS Classic Stand Mixer
Sunbeam beaters hitting each other
Check with Sunbeam. The beaters may have to be replaced.
Dec 11, 2013 | Cuisinart Food Mixers
The beaters touch wont hold in machine
Beaters touching can be dangerous as much as not holding in place. Check if the teeth in the beater and the machine are of the same brand and and construction. Make sure you do not use any other mix and match parts because of danger.
Nov 15, 2013 | Sunbeam Food Mixers
The mixing section has a gap in between
Do you mean the beater is not touching the bottom of the bowl? AS in there is a gap between the beater and the bottom of the bowl so it is not mixing all the ingriedients?
If you have a Tilt-head style mixer, you can adjust the beater/bowl clearance by turning out the adjusting screw. Place your bowl on the bowl screw cap, Place the flat beater on the agitator shaft and lower the head of the mixer so the beater is at the bottom of the bowl. There should be a 1/16" clearance between the bowl and the beater, if the beater is too close to the bowl turn in the adjusting screw, and if the beater is too far away turn out the adjusting screw. The adjusting screw can be located by tilting the head of the mixer back, and in the neck of the mixer you will see a flat head adjusting screw.
However if you have a bowl lift mixer and the bowl is too far from the mixer there are a few different way to fix that problem. If the bowl and beater are too far apart start by adjusting the adjustment screw. On this mixer the adjustment screw is under the head. Remove the bowl, and beater and lay the mixer on its back. You should be able to see under the head a screw sticking out, it does not have a head, but a little slot in the screw, use a flat head screw and adjust the beat 1/4 turn. Put the beater and bowl back on and test mixer to see if it the beater has a 1/16" clearance. If it doesn't adjust the screw and 1/4 turn. If after adjusting the screw the beater and bowl still have too much clearance use a mallet and tap both sides of the yoke arm up evenly until 1/16" beater to bowl clearance is met.
You can use the same dime test in the bowl to make sure you have the correct 1/16" measurement for the beater/bowl distance.
Thank you,
Colleen
MendingShed.com
800-339-9297
Apr 30, 2013 | KitchenAid Food Mixers
Beaters will not move
You have probably stripped a gear in the gear housing. Here is the breakdown of the gearbox:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212010.pdf
The newer "more improved" mixers use plastic gears and they can't take the beating, no pun intended, and fail.
The good news is that the most likely gear to fail is cheap. Here it is on amazon.com:
http://www.amazon.com/KitchenAid-W10112253-Worm-Gear/dp/B0006HLAVA
http://www.misterfixit.com
Mar 25, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Middle better comes loose
Try placing some "braces" rubber bands around the shafts of the beaters. This should tighten the hold of the shaft with the mixer and keep them more straight.
Dec 15, 2009 | Sunbeam 2346 Heritage MixMaster Series...
Kitchenaid k45ss won't turn on
if you remove the top you will find a tiny fuse wrapped in a black band on the left side from the back. It connects two white wires which power the top-side motor brush. Most likely this needs to be replaced. You can check by bypassing it with roach clips or a copper wire. Unplug the machine first and be careful!
Jan 25, 2009 | KitchenAid KT2651X Epicurean Stand Mixer
Speed of mixer
does the motor still run or does it slowly start to get less loud? or is the beater assembly that dosnt work? two different issues. if the motor runs but dosnt beat then its the planitary gears that are ground out and need replacing. if the motor slowly dies out then you need to replace the motor.
Dec 24, 2007 | KitchenAid KSM90 Ultra Power Series Stand...
Food Mixers Logo
245 people viewed this question
Top Kenmore Food Mixers Experts
Jim Thurston
john h
NOEL
NOEL
Are you a Kenmore Food Mixer Expert? Answer questions, earn points and help others
