Question about Mitsubishi ColorView XL30U Multimedia Projector
Mitsubishi hc1500 banding
Just hooked up a new mitsubishi hc1500 using new component cables, new dvd, new receiver.   When viewing, there are horizontal lines making their way up the screen.   I have eliminated the possibility of the cables, receiver, or dvd player being bad...  I can't figure out if there is a way to get rid of the banding via settings on the projector.
thanks
If you're using the VGA port, you'll see the banding because it's not really showing 720p, it's doing scaling (I'm not sure from what resolutions it's scaling). So, even though you're using VGA at 1280x720, the scaling is still going on and it's showing the banding.
You have to use HDMI to get true 720p.
Posted on Jan 30, 2008
It could be a ground loop problem try using a AC ground eliminator adapter.. I had the same problem.. this worked
Posted on Jan 09, 2009
I have a HC1500 Mitsubishi projector, I want a mainboard (motherboard) for this. Can anybody help me to find one
Mitsubishi HC1500 DLP Projector Repair Questions ... - Fixya
www.fixya.com > Forum > Multimedia Projectors > Mitsubishi
Recent Mitsubishi HC1500 DLP Projector questions, problems & answers. ... I have a HC1500 Mitsubishi projector, I want a mainboard (motherboard) for this.
I have a mitsubishi hc1500 projector and it made a popping ...
www.fixya.com/.../t5370392-mitsubishi_hc1500_projector_made_poppi...
I have a mitsubishi hc1500 projector, when i went to turn it off it made a loud ..... I have a HC1500 Mitsubishi projector, I want a mainboard (motherboard) for this.
MITSUBISHI HC1500 DLP 720p Home Theater Projector ...
www.newegg.com/Product/Product.aspx?Item...
Newegg
Rating: 5 - ‎22 reviews - ‎$949.99 - ‎Out of stock
MITSUBISHI HC1500 1280 x 720 DLP 720p Home Theater Projector 1600 ANSI Lumens 2500:1. ... If you are a high-definition video enthusiast who's looking for a more affordable way to bring a front-screen projection to your home theater or family room, the Mitsubishi HC1500 projector is
Dec 27, 2014 | Mitsubishi HC1500 DLP Projector
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Aug 17, 2007 | Mitsubishi VS-60805 60" Rear Projection...
Our dlp tv shows great color when watching tv but when we watch a dvd the red is brown and the pink is tan? HELP
if you already check your cables.. and it's still the same.. the problem is probably the VIDEO BOARD
here is a picture of what is a video board..
Nov 28, 2009 | Mitsubishi WD-73827 73" HDTV DLP TV
Must hookup DVD-VR375to tv,cablevision box & MSNtv2.
Here's How:
  1. The first step to connecting a DVD Recorder to your TV is to determine what type of connection you want to make between the TV source (Cable, Satellite, Antenna), the DVD Recorder and the TV. This is usually determined by the outputs and inputs available on the DVD Recorder and the TV.
  2. If you have an older TV that only accepts RF (Coaxial) input, then you would connect the RF output (a coaxial cable) from your TV source (in my case a Cable Box) to the RF input on the DVD Recorder. Then connect the RF output from the DVD Recorder to the RF input on the TV. This is the most basic (and lowest quality) option for connecting a DVD Recorder to any TV.
  3. If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
  4. To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
  5. To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
  6. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
  7. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
  8. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
  9. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
  10. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
  11. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Jan 20, 2009 | Air Tools & Compressors
I amm trying to set up an vsx817 pioneer receiver to play dvd
on the rear of the receiver,hook your red,yellow andwhite cable to the input labled DVD and match the corosponding colors to the DVD player output. if your using component hook up match red, green and blue on both units and also a component cable to your tv
Nov 11, 2008 | Pioneer Televison & Video
Novice installing HDTV(Samsung),DVD(Sony) no pic on TV
Purchased a newer HDMI DVD player,(Sony)as well as found that I do need the video cables.Also found that I need to change the input to component on the DVD player by using a regular coxial to at least get a display from the DVD player had I kept the older one.
Oct 08, 2008 | Televison & Video
Distorted HD picture when using Onkyo 605 receiver
use a hdmi switcher and the signal will be spilit up evenly between the two
Jan 02, 2008 | Onkyo TX-SR605 Receiver
Setting Up New Denon AVR-588 / Adding Sony DVD with Component Video cables
Make sure you have receiver switched to proper input as coax rather than digital
Dec 31, 2007 | Denon AVR588 Receiver
Video input not recognized for LD and DVD
By coaxial, do you mean the composite (yellow)? Either way you have to use the same style no matter what the cable. I mean, if you have s-video's IN to the reciever then you need S-videos OUT to the TV. ....Component IN to the reciever? then Component OUT to the TV. And so on. You cant have composite cords going into the reciever and use a component cord out to the TV (with the exception of a few models).
Sep 10, 2007 | Pioneer VSX-D912 Receiver
Mitsubishi ColorView XL30U Multimedia Projector Logo
229 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
