Question about Bosch Classixx WFL 2066 Front Load Washer
My drum does not empty of water - Bosch Classixx WFL 2066 Front Load Washer
  • 725 Answers
This could be your pump. It's probably clogged with lint or trash. We have parts so please call or email us and we will send your part to you. Hope this answers your question and repairs your Bosch washer.
Posted on Sep 07, 2009
Door will not open if machine not emptied immediately cycle ends
This is an anti-flood protection, since water would flood the kitchen if you could open the door. If the machine shuts down for some fault and leaves the drum with water in, then it is advisable to drain the drum down via the small hose at the front of the machine. Simply remove the plug and empty into a large container until the drum is empty. You can then start to work out why the cycle ceased prematurely.
Mar 08, 2015 | Miele Washing Machines
MY LG FRNOT LOAD LEAKS WASHING INTO WASHING DRUM WHEN NOT IN USE. WHATS THE PROBLEM
the water valves are clogged with grit empty machine turn off the cold water tap leave it for 3 hours check drum for water if no water in your drum do the same to your hot water the 1 that leeks water into your drum is faulty replace the faulty valve
Sep 29, 2012 | LG WM2487H Front Load Washer
LG condenser dryer, TD-C70040E. Empty water warning every 3mins!
Did you repair this problem? If yes, how?
Thank you.
Dec 11, 2009 | LG Dryers
Wont go into spin cycle
will the drum go round when on a wash. and is it drianing water out if the drum goes round its not your brushes. if it not emptying water you pump as gone and will not spin if there is water in the drum
Jun 28, 2009 | Kenmore Washing Machines
Changed brushes still wont fast spin and empty water
Let me ask you who told you to change the brushes... Im curious!
Jun 10, 2009 | Washing Machines
Water appears in drum hours after being emptied
could be several reasons...condinsation, if small amount of water moisture try leaving door ajar and see if evaporation takes care of it then you will know and it's possible that your water inlet valve has some "dirt" trapped in the seat and allowing water to seep into washer even though unit not calling for water
May 19, 2009 | Kenmore Washing Machines
Washer won't drain.
hi, to empty water manualy, lift the hose from the stand pipe, keep it above the water level, place a bowl on the floor and lower the hose into it, the water should drain out, to stop the water flow lift the hose above the drum and empty bowl, continue until empty, hope this help, thanks for using fixya
Feb 14, 2009 | GE WBSR3140DW Top Load Washer
Drum won't empty
Check drum something may be caught on heater not allowing water through quick enough, take sump hose off and look onto drum.
Dec 14, 2008 | Hotpoint WMA35 Front Load Washer
Hoover ab130 water won't empty from drum
unselect the option button "crease guard or easy iron" it will will spin normally! (ex hoover engineer)
Jan 08, 2008 | Hoover UltraCare HC6 130M Front Load...
Bosch Classixx WFL 2066 Front Load Washer Logo
48 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
