Question about Coleman Powermate Premium Plus 6250W Portable Generator
The motor runs fine but will not generate any electricity
Mising res
Posted on Mar 26, 2013
  • 491 Answers
With the generator shut off.....
At the generator side of the generator we are looking for a small + and - sign on 2 connection terminals.......you may have to take a small cover off.
What we want to do is re magnetize the generator.
With a regular 9 volt battery.....or almost any small battery will do.....momentarily add the battery power to these terminals.....just for a sec......and thats it.......it's re magnetized.
Your generator will charge now.....if it was in need of a re magnetizing.
This is the cure for 70% of no output when running generators.
Posted on Sep 07, 2009
5 Suggested Answers
knotbeerdan
  • 413 Answers
SOURCE: No electric power generated from my Coleman Powermate Maxa 5000W.
the gensets on coleman generators are definately nothing to brag about but i would start by checking the windings and make sure the brushes have a clean armature to ride on
Posted on Dec 19, 2008
CarlGehrke
  • 169 Answers
SOURCE: Coleman 5KW gen motor shuts down when A/C switch turned on
Sounds like a problem with the wiring of the outlets after the circuit breaksr. Take apart the outlet box and have a look for burned or broken wires, melted outlets, and/or small critters stuck in the wiring.
I recently had to repair a generator that had its voltage regulator taken out by a frog!
Regards,
Carl
Posted on Mar 01, 2009
  • 86 Answers
SOURCE: generator motor runs fine, not getting electrical
You may have a bad cap or two on the inside
Posted on Sep 10, 2009
  • 4 Answers
SOURCE: 5500 generator stopped producing eletric after
First check with the dealer and see if it is still under warranty. If it is not, make sure nothing is blocking the air flow around where the control modules are located. This could cause the voltage regulator and other electronic parts to overheat. Next check the brushes and make sure they are free of any dust or build up preventing them from making contact.
If everything is OK the next thing I would do is change the voltage regulator.
Posted on Nov 25, 2009
Portable 5500 watt generator no ac output
maybe it needs new brushes. you've done everything else
Aug 25, 2017 | Electrical Supplies
Pm0645250 just stopped generating power. Motor runs fine .
You need to run tests on your alternator. We have made some videos to show you how to do this on our website. It is very easy!
https://www.generatorguru.com/help-me-fix-my-generator-repair-advice/
Regards,
The Generator Guru Team
World Leading Supplier of Parts and Spares for Portable Generators
Mar 08, 2017 | Electrical Supplies
I have a nikota 3500 watt generator and I am not getting any power from the generator. Motor runs fine just no power. Is there anything I can check.
All Power America APG3535CN, 2800 Running Watts/3500 ...
www.amazon.com/...Power...Generator/.../B000U0OJ...
Amazon.com, Inc.I then call All Power and am told to give them one more day to get this worked out ....There is no styrofoam enclosure or crate to protect it, the generator is simply ...
NIKOTA 3500 WATT GENERATOR - YouTube
? 0:58
https://www.youtube.com/watch?v=NEeu9Y-0_KM
Aug 27, 2011 - Uploaded by mamasboypowersports
NIKOTA 3500 WATT GENERATOR. ... Diagnosing A GeneratorThat Has No Power Output. - Duration: 3:03. TheDIYGuyDOTnet 117,263 views.
I have a nikota 3500 watt generator and I am not getting any ...
www.fixya.com/support/t26062098-nikota_3500_watt_generator_am_not
2 hours ago - I have a nikota 3500 watt generator and I am not getting any power from the generator. Motor runs fine just no power. Is there anything I can ...
Generator outputs low variable voltage, ideas for troubleshooting ...
www.smokstak.com > ... > Generators & Motors General Discussion
Jan 20, 2016 | Electrical Supplies
The generator kicked the breaker of and was smoking and smelled like electrical
What type of load (electrical) was hooked up to this generation?? If the surge voltage and current was exceeded above the generator maximum for any length of time. There problems, it could be the regulator, insulation burnt off the windings.
I am taking a guess here. Now, 7100 Watts is it typical surge wattage. This mean that the generator will deliver 7100 Watt (voltage times current) this is know as the power factor. The actual operating load would be 6800 Watts and I would even operator the generator at its peak wattage. Something in the neighborhood of 10--15% less the peak wattage. Therefore a good positive theatrical Wattage would be 5800 to 6350 operating wattage. Then this generator would run all day.
Just remember Ohm's Law. Current plays a big factor in loading of a generator while the operation voltage is at 120 AC Volts. Example: electric motor; Now electric motor when starting will pull three time its operation current. Operating current for a 1/2 HP AC motor is 6 amperes but start this electric motor will require 18 amperes. This is one reason why they starting capacitors on smaller electric motors. Larger three phase electric motor can literal stop a generator cold...in its tracks. It put such a large demand on the generator it stops the engine powering the generator. I have seen crankshaft break because the generator could handle the heavy current load.
Remember, any time you are running a small gas powered generator. All ways figure what the load and surge current load will be before hooking up any generator. Normally this is figured in VA (volt/amps). Wish you lock. GB...stewbison
Sep 05, 2011 | Robin Subaru RGX7100 7100 Watt Gas...
Motor runs fine, but no electricity to outlets
Try turning the switch to "ON" for the power output.
Jun 23, 2009 | Coleman Powermate Powermate 5000W...
My Kohler Confidant IV generator starts and runs great for about 30 seconds and then dies,, starts right back up and does same thing, what is up with that
Kohler generators feed the generated voltage back into the control circuit board to tell it to keep the fuel pump (electric) runing and the ignition on. IF there is no voltage generated (bad brushes or?) then the symptom you describe will occur. The motor runs fine, but it isn't generating electricity.
Jim Russell
Mar 30, 2009 | Electrical Supplies
Regards,
Carl
Feb 28, 2009 | Coleman Powermate Premium Plus 6250W...
Dec 18, 2008 | Coleman Powermate Powermate 5000W...
Motor runs does not make electric
Here is an answer I posted that should help you.
Carl
Oct 19, 2008 | Coleman Powermate Powermate 5000W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
621 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Shawn DuRee
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
