Question about Maytag Dryers
Model mdg9206aww wont heat
Model mdg9206aww It won't heat up. the drum turnsbut no heat. this is a gas model.
  • 525 Answers
Firstly, ascertain that you have made a positive heat selection on the control panel temperature switch.
Below are some links, courtesy of www.repairclinic.com, that will assist you in diagnosing/repair of your dryer. You may have to enter your model number in the search box to access some of the information.
Below is a parts breakdown/disassembly procedure for your dryer.
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
More information
If your dryer doesn't heat, check these first:
Igniter
Gas valve coils
Thermal fuse
Igniter http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg9206aww-%3d%3di3018&PartID=3018 Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg9206aww-%3d%3di3479&PartID=3479
Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg9206aww-%3d%3di516650&PartID=516650 On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Other components that could keep it from heating.
Hi-Limit Thermostat
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg9206aww-%3d%3di481329&PartID=481329
Cycling Thermostat
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg9206aww-%3d%3di484291&PartID=484291
Temperature selector switch
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg9206aww-%3d%3di516542&PartID=516542
Flame Sensor
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg9206aww-%3d%3di2681&PartID=2681
Motor Centrifugal Switch
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg9206aww-%3d%3di776953&PartID=776953
Gas Valve
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg9206aww-%3d%3di1689&PartID=1689
Timer
http://www.repairclinic.com/SSPartDetail.aspx?s=t-mdg9206aww-%3d%3di516525&PartID=516525
Posted on Sep 08, 2009
My magtag (mdg9206 aww gas) cloth dryer wont heat
Posted on Dec 30, 2010
Hotpoint Dryer model DLL2650BFLWH won't blow heat
So your not getting any heat. There could be a number of different problems. I believe this is a gas dryer. You would need to remove the drum and check the ignitor. This is a little complicated and I would recommend a technician since this is a gas drier.
Oct 27, 2012 | Hotpoint Dryers
Ld lg3788w gas dryer drum won't turn
not a good model number,most likely you have a broken belt as long as it starts,heats but the drum doesn't spin,if you get a buzzing sound and it doesn't start you could have something stuck in the blower wheel,the motor is jammed or the motor is bad,you can open the door,push the door switch in,spin the drum with your other hand and have someone push the start button,if it starts you have a bad motor.
Nov 27, 2011 | Dryers
My ge dryer wont heat up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 08, 2010 | GE DWSR483GB Gas Dryer
GE Profile gas dryer won't ignite
heatman101
Jun 01, 2010 | GE Profile DPXH46EAWW Gas Dryer
My dryer (kenmore elite model 110.64992300) wont heat
heatman101
May 26, 2010 | Kenmore 64992 Electric Dryer
Drum wont rotate ''adora'' model dryer clicks like heating unit? on, but no movement
heatman101
May 21, 2010 | General Electric DHDVH66EH Dryer
Drum still turns but no heat where do i find the heater
heatman101
May 12, 2010 | Maytag PYE2300AY Electric Dryer
Dryer does not heat. Electric ignition does not "spark" lighting
Gas Dryer2_bing.gif not Working Gas Dryer Not Heating
If your dryer is electric2_bing.gif..
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
heatman101
May 04, 2010 | Speed Queen AGS28AWF Gas Dryer
Dryers Logo
850 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
