Question about Zanussi 18 in. ZSF4123 Slim-Line Free-standing Dishwasher
Zanussi zsf4123 heating problem
Hi i have changed the heating eliment in my zsf 4123 slimline dishwasher but it still dont get hot at all is there anything else i should look at to cure the problem.I had reasurance from my dealer that the thermastat is combined in the heater. can you help
    Brigadier General:
  • 4,088 Answers
Look at the wiring going to the ends of the heater to see if there is an inline thermal fuse that blows when there is trouble in the heater itself. It is about the size of a regular fuse, but may be contained in some kind of covering. It needs to be connected with crimp type connectors, because soldering can ruin the new fuse. Do you have a wiring diagram for this unit? It would help to locate the source of your problem.
Posted on Sep 07, 2009
Dishwasher going through cycle but water not getting hot zanussizsf4143
Heating Matrix faulty. This will need to be taken to a specialist for repair. or purchase new machine - would work out same cost.
Feb 16, 2010 | Zanussi 18 in. ZSF4123 Slim-Line...
Hi, my zanussi zdf221 dishwasher wont work, it makes a noise and constantly empties, any ideas please
The outlet pump is triggered by the anti flood micro switch via the polystyreene float on the base of the washer. If any water for whatever reason (leaky pipe)is on the floor the machiene automatically switches to pump out mode and only works once the water and the cause is rectified
Jan 16, 2010 | Zanussi 18 in. ZSF4123 Slim-Line...
I have a Zanussi ZSF 6160 dishwasher which is not heating the water. I've checked the PCB and visually it appears ok. How do I change the heating element?
measure the heating element resistance it should be around 25 ohm.
otherwise it is the problem.
You can replace the relay, sometimes it stop working with no external damage signs
Jan 08, 2010 | Zanussi 24 in. ZSF6160 Free-standing...
I have a Zanussi Electrolux Jetsystem Progress ZSF 6161 Dishwasher which, no matter what programme I use, stops after 2 seconds and a -10 flashes.
I have a Zanussi Jetsystem Progress ZSF 6161 Dishwasher stops after a few seconds and flashes -30 Any ideas? thanks!
Jul 28, 2009 | Zanussi Dishwashers
Zanussi ZSF 6161 Dishwasher with Error 30 Code
The light cover on the side is loose causing it to flood remove the side and tighten the light cover the tilt the dishwasher to get water out of the float tray. let the dishwasher dry out and you should be grand
Mar 22, 2008 | Dishwashers
Zanussi ZSF 6161 Dishwasher error codes
i have got an zanussi des 959 and showing falt code 5 could u help me out
Jan 19, 2008 | Dishwashers
Problems! zanussi zsf6120
You can check the heating element with an ohmmeter and it should read a few hundred ohms. Don't know about the thermostat but it should be inline electrically with the heating element and should ohm as a short when cold.
Nov 23, 2007 | Zanussi 24 in. ZSF6120 Free-standing...
Water isn't heating up and not drying
Check with a multi-meter for voltage (220/115v) on heating element's tags. If you can read this voltage on tags - you should replace the heating element In case you can't read voltage on its tags, disconnect one of the wires from its tag (you should unplug first your machine's power cable!) and test for element's resistance - If you can read its resistance, you should replace the thermostat. In case of no resistance - you should replace element and thermostat Good luck!
Mar 12, 2007 | Zanussi 18 in. ZSF4123 Slim-Line...
Zanussi 18 in. ZSF4123 Slim-Line Free-standing Dishwasher Logo
424 people viewed this question
Top Zanussi Dishwashers Experts
paulcarew
Owen Barnes
Gerard Curran
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
