Question about Refrigerators
Admiral model LFT2112ARW freezer on-top refrigerator: The refrig compartment stays just below room temp. The freezer accumulates ice. The unit is in the garage, in a non-air-conditioned space. Clearly not enough air is getting from the freezer into the refrigerator compartment, but when I clear the ice, it still has the same problem. The unit runs all the time trying to get cold. Could this be a problem with the unit never going into defrost mode? One guy told me to leave the freezer door open, especially in hot humid weather, to temporarily fix the problem, but that does not seem to work. Should I check the defrost timer or what?
  • 725 Answers
Check the defrost heater, timer and t-stat. You should probably let it thaw out completely for at least a full two days to thaw out all the ice. Then check the parts. Look at the heater to make sure it's not broken or burned out. When you decide which parts you need, please give us a call and we will send the right part to you. Hope this solves your problem and we hope to hear back from you soon.
Posted on Sep 07, 2009
For the longest time my Amana iso 9001 refrigerator and freezer were set at 2-3 and everything was really cold. Recently I had to set it at 4-5. What is the suggested setting?
You use the setting that keeps your freezer at close to zero and your fridge at around 37. Will vary depending on room ambient temp, location of unit, how full the compartments are.
Check to make sure that there is no ice accumulation in back of freezer - if so, your self defroster mechanism is not working and that will raise internal temps since the ice collected serves as an insulator.
Check the back of your freezer!!!!!!!!!!!!!!!!!
Sep 21, 2015 | Amana Refrigerators
Admiral LFT2112ARW not cooling. I have changed the defrost timer-
The condenser is the hot bit on the rear/ under the unit. Brush clean and/or vacuum it clean. The compressor should make the condenser hot but the pipework should be cool before it enters the unit.
May 02, 2012 | Refrigerators
Refrigerator keeps freezing. Temp stays at about 28 degrees. temp control on door (digital) and no matter how much you turn it up, temp stays below 30. Repair man came out and said seal was bad on...
Most likely one or both of the thermistors are bad. Usually pretty easy to find behind a vented cover about 2" X 1" on the side walls of the refrigerator and the top of freezer (if freezer is on the bottom of the unit)
May 31, 2011 | Refrigerators
Fan in freezer is making a real bad sound...... griding like it may be struggling to to stay running
This can be caused by frost accumulation on or aroundthe freezer fan Icing . And due to this no cooling will be in fridge compartment.
Unplug power and . defrost it. And after some times, switch on fridge.
This is due to auto defrost switch malfunction. keep temp setting at 5 degree and check auto defrost (if your fridge having that option) is working. If not you have to replace PCB. Thanks.
Jan 28, 2011 | Maytag Admiral Top-Freezer Refrigerator
Refrigerator cold control doesn't work; temperature stays at or below freezing. Freezer control OK.
check the damper door between the refrige and freezer compartments,its behind a plastic cover,if its iced up in the fully open condition it will allow too much cold air into the refrige,if this is the case defrost it with a hair dryer and recheck operation,otherwise the temp control in the refrige is bad
Mar 18, 2010 | Refrigerators
Top mounted freezer on refrigerator not working
Move the refrigerator to a room that is at least 50 degrees F.
Temps on most refrigerators are regulated by the fresh foods temp. If your garage is let's say 35 degrees, the fresh foods temp will most likely never raise enough to turn the refrigerator on. With the refrigerator never running, the freezer compartment will warm to 35 degrees, resulting in everything melting. Even if garage is a bit warmer, say 45, the refrig will not run long enough for the freezer to maintain a low enough temperture. If the garage temp falls to below freezing, say 20 degrees, the food in the fresh foods compartment will freeze. (outdoor beverage dispensers have internal heaters to prevent product from freezing !) Please don't rate this if not a Fix-Ya for you, as anything else lowers my score.
Jan 22, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Dorm refrigator icing up
Make sure the fridge and freezer are not packed with food. It needs a lot of breething room.Also make sure the door is seeling tight. Not a lot of room in small fridge. Good luck
Sep 06, 2008 | Frigidaire Refrigerators
Admiral refrig
thats the fan hitting ice. sounds like a defrost problem. does the back of the freezer panel have any frosty ice build up?
Aug 18, 2008 | Maytag MZD2766GES Side by Side...
GE model TFX22R ice maker problem
First clean out the condensor coils. If you have pets it should be done at least 3 times a year. The other possible problem is if the gasket in either the fridge or freezer is worn out or has a gap it will not cool properly. Check that the fan underneath the unit by the condensor coils is running when the compressor is . Some smaller refrigerators have only condensor coils on the back and no fan. These units should have room for air flow on top and sides not built in flush with cabinets. Buy a thermometer for both the fridge and freezer compartments. You run the risk of food poisoning if the fridge temp can not be kept below 40 degrees. Freezer temp should be able to keep at least 0 - 5 degrees. (Ice cream is a very good indication of proper temp. It is the first thing that melts. Ice maker is a close 2nd.)
If these things don't work call for repair. Don't risk losing all your food!
Jun 24, 2008 | Maytag MSD2756G Side by Side Refrigerator
Kenmore Side by Side Refrigerator, freezer doesn't work, refrigerator works
Unless specifically made for use in a garage most units won't work properly. The owners manual should say what the temp range for proper operation is (usually 55F is the low range). This is because the refrigerator section doesn't need to be "cooling" to maintain 37F if the temps on the outside are below 55F. These things are made to work in a 70F room and will not work properly if under 55F. Stupid thing thinks it's cold enough so it will never turn on, the refer section will stay cold/cool due to outside temps but since the compressor never runs the freezer will just be the same temp as the refer section (at best). Sorry, but in order for a freezer or refrigerator to work in an unheated space it must have the temp control device controling the freezer section NOT the fresh food section. In other words, that model will not work in a garage unless the temps are above 55F always.
Feb 06, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
118 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
