Question about Garden
I have a backyard gear wc100 water station. The attachment to hook up the hose to the faucet and the hose to the unit to wind it up has a third opening that is covered by a plastic cover. The plastic cover pops off from the water pressure when the water gets turned on. Help
arealplumber
  • 33 Answers
SOURCE: Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Posted on Dec 05, 2008
  • 11 Answers
SOURCE: faucet issue
Sounds like it was installed upside down or the cartridge is installed improperly
Posted on May 07, 2009
  • 19 Answers
SOURCE: New faucet, sprayer hooked up right, no water going into hose?
check the sprayer handle by disconnecting and blowing into it and pressing sprayer handle and/or for possible kink at main body or hose by disconnected sprayer point hose into sink and turn on water. If no water the the diverter in main body is not working properly and needs to be reassembled or replaced
Posted on Jul 07, 2009
SOURCE: water system in my Coleman pop up not working
Make sure you have a water regulator connected to the water source before connecting it to your RV or the pressure could blow out your plumbing. The force of the water coming from the faucet can be too much for any RV and a regulator can be purchased from RV dealers, camping world, and even some Wal Marts carry them.
Posted on Jul 28, 2009
SOURCE: Problem taking the top cover off the Rohl R77V3SPN one handle faucet
With a small flat blade screwdriver, carefully remove the red and white plastic button on the front of the faucet. Turn off the water supply. Then, raise the handle like you're turning on the water and move the handle slowly left and right until you can see an Allen screw through the hole where the button was. With the correct size Allen driver, remove the screw and the handle will come off the faucet.
Posted on Aug 29, 2009
Low water pressure from wand
The pressure in a watering wand extension to a garden hose is related to the water pressure from the hose itself.
The point of a watering wand is to provide a gentle and widespread flow of water. If you are looking for a powerful stream, then a different type of attachment is required.
Check to make sure that there is no leaking at the faucet, or at any connecting point. Leaks will lower water pressure at the end point.
Check to be sure the wand itself is free of dirts and clogs. If the wand is dirty or blocked, it will affect the pressure.
If there are several hoses hooked together, the water pressure is more likely to be low at the last point, the wand itself.
When the water pressure drops as a result of another use, like a shower, dishwasher, another hose faucet, then the water pressure will drop in the wand.
Aug 06, 2017 | Water Garden
When my Kenmore machine is running on the wash cycle warm/warm no water is coming at all. I could run the machine only with cold water even on the cycle warm/cold.
Most likely the hot water hose is plugged up, or least likely, the hot/cold valve is broken or plugged up.
Find a large container, or better yet, hook up a garden hose that you might try the faucet where the hot water is hooked up and see if water will come out of it when the washer hose is not hooked up there.
If it will not, you have a plugged up hot water pipe or the water heater shut off valve is closed.
If you get good water pressure and hot water from the faucet, look at the filter screens that are inside the ends of the hot water hose and see if any are plugged up.
There may be several.
If not, perhaps the inlet water solenoid has failed. That plastic part is where the hoses attach to the washer itself.
God bless your efforts.
Jan 22, 2016 | Kenmore Washing Machines
Oregon Scientific WMR86A wind sensor does not communicate to the base station. It is a new device, first time assembled.
I believe the wind sensor is a rotating cuff that has a wire which needs to input into the main reader or the wifi unit.if it's the wifi unit you need to check the receiver is picking up the signal.if it's the main readout then check the connection.if it is wireless, you may find a switch on the transmitter to change channel.this may fix the problem, especially if the receiver is near other wireless or bluetooth equipment.
Feb 19, 2015 | Oregon Scientific WMR86A Backyard Pro...
Unable to cancel min. wind chill reading wnen current display reads NA; thus 5C still shows from a day in April!
There is a reset button on each sensor unit and there is a reset on the base display. The NA means that the signal is not being sensed from the remote. If you use the reset button on the base you will lose all the historical data. The problem may be related to strong interference from something else nearby, You can bring the sensor inside to see if the base picks it up. IF it does not it may need to be replaced. I have dealt with Oregon Scientific before and they are very good with their support. http://www.oregonscientificstore.com/WMR86A-Oregon-Scientific-Backyard-Pro-Wireless-Weather-Station.product
Jun 27, 2014 | Oregon Scientific WMR86A Backyard Pro...
How do I connect the sprayer hose on single sprayer faucet ,peerless style, the pin wont go in?
What is the model number of the faucet? There was no attached pictures to this submission.
Jun 14, 2014 | Delta Faucet DELTA/PEERLESS FAUCET CO....
Leaking faucet
I've had problems with the O-rings at the head leaking, feeding back inside the corrugated hose covering, and pooling under the sink. Might be your problem as well. Verify by holding the head downward, and look for water beading out further up the hose.
Apr 04, 2014 | Grohe Ladylux Cafe Faucet with PullOut...
My old kitchenaid washing machine works fine except the cold water only trickles into the bin. Someone told me the intake filter is probably clogged. There was no filter where the hose attaches to the...
check the inlet on the machine side where the hose hooks up,not at the faucet,it should be just inside where the hose screws onto the machines valve
Aug 22, 2011 | Washing Machines
Water continues to drip into the washer when it is finished with cycle and turned off
Water valve is located at the rear of the machine with the water hoses attached to it. Disconnect power. Remove hoses and unscrew the small angled bracket attached to the valve. Replace the valve and your problem will be solved. Part Number is 2200270. This the only possible cause for the symptom you describe.
Oct 12, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Engine appears locked up as it won't wind up to start
Try turning the water almost off at the faucet and then loosening the water feed hose connection where it attaches to the washer. Sometimes the pressure in the pump is so high that it will effectively lock the engine and you need to relieve the pressure to be able to restart it. Once it does restart, get the water flow back ASAP as the water is used for cooling and it needs to be there quickly.
Aug 16, 2009 | Karcher 2500 PSI Pressure Washer
Jul 01, 2009 | Price Pfister Marielle Kitchen Faucet with...
Garden Logo
170 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
