Question about Kenmore 74992 Gas Dryer
The start botton needs to be held down for my dryer to function.
I had the whole button an switch replaced thinking that would help but it didn't. anyone know what's going on?
  • 304 Answers
Motor Number 279787 needs to be replaced.
The instant you press the button on the console, the motor should start. When it starts a mechanism in the motor operates a switch mounted on the motor (provided w/new motor). That makes a circuit which replaces the action of your finger holding the button by creating a bypass circuit. This bypass circuit takes the start switch completely out of the circuit and keeps the motor running.
Your motor is not making this bypass circuit.
Posted on Sep 07, 2009
I have Kenmore 90 plus series electric dryer that won't stay on after I let go of the start switch. I replaced the thermal fuse, it was blown. I also replaced the start switch, it only makes the dryer...
I think there is a Relay that is bad, the start switch is activating that relay, but that relay fails to stay on the way it should. Find that relay and check it and the wiring connections.
Sep 24, 2014 | Dryers
GE dryer starts but..... stops
What you describe is either a failed evenheat board or a failed motor relay.
Please post the complete model number from the machine and I can help you narrow it down. There should be a wiring diagram inside the console with voltage checks also.
Thanks/Mike
Nov 25, 2007 | Kenmore 63932 Electric Dryer
Dryer only runs when I hold down Start button works fine only if I hold the start button down This is a gas dryer
souds like the door switch is broken or malfunctioning . unplug the dryers power cord , locate switch by removing top cover no need to remove switch just yet. locate two wires coming from switch . and check function by means of a continuity tester or multi tester. touch the red test lead to one wire termial and the black test lead to the other , now set your meter to resistance reading . with switch normaly open ie; (door open) youll have high resistance reading and with dooor closed or switch held in youll have no resistance. or an audible tone on your tester. if no tone or high resitance reading occurs with door closed or switch held in the switch is bad. hope this was helpful.
Feb 11, 2013 | Dryers
Model 110 dryer we have the start button in for it to run we let go it stops
One of two things is wrong. Either the start switch has gone bad or the start winding in the motor is failing to switch over to the run winding. You'll need to get a multimeter and before starting unplug the dryer. Once thats done, get behind it, remove the back cover to the control panal and disconnect the two wires that are connected to the start button. With your meter set for checking continuity, place a meter lead on start button pins where the wires were connected, one lead on each side.With leads in place have someone press the start button, if continuity shows when pressed and stops when its not, the button is good and the motor is bad. Personally, I think the motor winding has burnt, and the motor should be replace, but I also think that the start button should be changed as well because its in direct series with the motor, and could have taken damage that may not show up until further down the road, plus its an inexpensive part.
May 11, 2012 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite electric dryer model # 110.64994300\r\n I'm pretty sure I need to replace the push to start switch because it starts when I push it but stops when I take my finger off of it. So I held it...
I don't believe replacing the switch is going to fix the problem. provided the power cord is wired correctly you have a control board issue. Their is a small micro computer in the the console that will cause your exact concern start while holding the button the stops, and no heat.
Sep 22, 2010 | Kenmore Dryers
Clothes Dryer won't stay on after switch is depressed.
some of them dryers have a switch other than the push button located behind the console. it also has an identical heat switch beside it. if that holding switch is bad it will not stay running. of the two identical switches the run switch is on the left. good kuck.
Jan 20, 2010 | Kenmore Dryers
Dryer turns on when botton held down
Motor has a "Run" winding centrifugal switch that may need to be replaced. Start button energizes the starter winding but when the "run" switch fails the motor won't keep running. Switch is easily replaced without taking motor apart.
Aug 12, 2009 | Kenmore Dryers
Kenmore-110.73952101 start button won't work unless its held down
It sounds like you need a start switch located on the motor To replace this you will need to get the 2 screws off where the harness plugs into the motor MAKE SURE THE POWER IS OFF :) Ask you locat parts placeGood luck:)
May 05, 2009 | Kenmore 73952 Gas Dryer
Dryer Only Works When The Start Button Is Held Down
Good news, I don't think it is the circuit board. Recheck to see if you put all the wires back on and securely. You may have the starter wires on backwards. The starter is a momentary contact switch and is used primarily to give power for just a split second to start the motor. Let me know how this turns out.
Dec 06, 2008 | Kenmore 63942 Dryer
Dryer de600e
most likely this is a defective start button stuck inthe on mode. If you know how to check it with an OHM meter, there should be no continuity in the on switch when it is not being held down. do not bypass the buzzer as the on switch needs to be replaced
Feb 27, 2008 | Dryers
Kenmore 74992 Gas Dryer Logo
347 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
