Model 21306908, OM99912 No power to shredder. The
Model 21306908, OM99912 No power to shredder. The head is seated correctly in the basket, but appears to be no juice to the shredder. Any suggestions?
  • 8,404 Answers
Look for a small fuse inside if you can open the power head.
Posted on Sep 07, 2009
Fellows PS-70 shredder basket ajar light is on
Here is some general advice. Shredders have an interlock to be sure they don't run while the basket is not in place. They don't want you holding the head unit and it starts running and shreds your fingers. So you need to look for the switch that tells the head unit that it is in place over the basket. I'm guessing here but it might be something like a little plastic protrusion that pushes into the head unit to activate a swith. It is possible that the little plastic piece is broken and is not activating the head unit. That would explain why the display thinks that the basket is ajar or misaligned. BE CAREFUL if you tinker with the interlock and be sure it is unplugged!! That is an ORDER!
Apr 22, 2014 | Fellowes Powershred PS-70
Aurora paper shredder model AU1050XA
Stan Chandler:
First, unplug the shredder. Remove the shredder head from the basket and turn it upside down. You will see the screws on the bottom side of the shredder head.
Feb 23, 2013 | Aurora Electronics Office Equipment &...
How do you empty the container?
You will first need to unplug your shredder. On either side on the shredder head, there are grooves. These are finger grooves. Place your fingers inside the finger grooves and lift up. This will remove the shredder head from the waste basket. Simply empty the waste basket, replace the shredder head and plug back in.
Jul 10, 2012 | Compucessory CCS 60062 Shredder
The red indicator icon designating full basket is always on and the unit will not work. Nothing in the basket and when you re-insert the basket it still will not accept paper or turn on. I just purchased...
There is a protection that will not allow it to run if it is not seated properly. Make sure it is seated on the basket properly and give a firm push to make sure the safety tab is seated firmly.
Mar 27, 2011 | Fellowes Office Equipment & Supplies
I have a novitech shredder and the light doesnt even come on any more. the machine doesnt work either.doesnt appear to be jammed. Help!
I have a model PS-026/B1 which has a safety switch that detects when you have the shredding head sitting on the basket or not. If not positioned correctly or, if switch is now damaged/defective, this will prevent power from activating anything.
Feb 06, 2011 | Office Equipment & Supplies
Plugged in and is on but nothing works. Is there a light that should come on? Is there a sound that you should hear?
Make sure you have it in the basket correctly. There is a small switch in the shredder head that must be in contact with the nib in the basket. Don't try to bypass it...it is a safety switch.
Oct 07, 2010 | Fellowes (30138) Shredder
Will not shred, but will go in reverse
Sorry don't mean to point out something obvious, but are you being shown any indication lights that the waste basket is not seated correctly in the bin or the head? If not, then you may want to try and check these connections anyway. Lights can burn out.
Aug 22, 2009 | Fellowes PS60-2 Shredder
OM 99727 shredder not working
I had this same problem. This is what I did to fix it.
When I went to ShredCare.com (the recommended web site for technical support of this particular shredder), I read that 'Most models of shredders have a safety interlock switch that is activated by the basket.' Upon looking closely at my basket and the shredder, I found this safetly interlock switch and made sure to align it with the proper position within the basket. There is only ONE way to place the shredder on the basket and have this safety interlock switch activated. The switch is located on the underside of the shredder. Align this switch with the ridge on the inside of the basket. Listen carefully and you will hear the switch 'click' when in the right position. Mine is very touchy. I've even had to press in on the side of the basket while shredding to make sure that the ridge and the switch are making contact.
Hope this helps!
Aug 15, 2008 | OfficeMax 0M96431 Shredder
Red light on will not run in forward
Check to make sure the shredder is sitting on the paper bin properly. Most shredders have a sensor switch that disables the unit if it's not properly seated on the paper bin.
Jan 21, 2008 | Office Equipment & Supplies
152 people viewed this question
k24674
jasbo
jasbo
